Quick find
Product features:
Wireless AC600 Dual Band Mini Router
EOL
General features:
Device Interfaces
• 2.4 GHz band:
  • 802.11 b/g/n Wireless LAN, up to 150 Mbps*
• 5GHz band:
  • 802.11 a/n/ac Wireless LAN, up to 433 Mbps*
• WPS button
• Reset button
• WAN/LAN 10/100 Ethernet port
LEDs
• Power/Status
Standards
• IEEE 802.11ac (draft)
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3x
• IEEE 802.3u
• USB 2.0
Internet Modes
• Router mode
• AP mode
Wireless Frequency Range
• IEEE 802.11a: 5150 MHz~5250 MHz, 5725 MHz~5850 MHz
• IEEE 802.11b: 2400~2497 MHz in ISM band
• IEEE 802.11g: 2400~2483.5 MHz in ISM band
• IEEE 802.11n (5 GHz): 5150 MHz~5250 MHz, 5725 MHz~5850 MHz
• IEEE 802.11n (2.4 GHz): 2400~2483.5 MHz в диапазоне ISM
• IEEE 802.11ac (draft) (5 GHz): 5150 MHz~5250 MHz, 5725 MHz~5850 MHz
Wireless Speed
• IEEE 802.11a: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit/s
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
Transmitter output power
• IEEE 802.11a:
  15 dBm (+/-2 dB) at 18, 12, 9, 6 Mbit/s
  15 dBm (+/-2 dB) at 24 Mbit/s
  15 dBm (+/-2 dB) at 36 Mbit/s
  15 dBm (+/-2 dB) at 48 Mbit/s
  15 dBm (+/-2 dB) at 54 Mbit/s
• IEEE 802.11b: 17 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
  17 dBm at 18, 12, 9, 6 Mbit/s
  17 dBm at 24 Mbit/s
  17 dBm at 36 Mbit/s
  17 dBm at 48 Mbit/s
  17 dBm at 54 Mbit/s
• IEEE 802.11n (2.4 GHz band):
  HT-20
  16 dBm (+/-2 dB) at MCS0
  16 dBm (+/-2 dB) at MCS1
  16 dBm (+/-2 dB) at MCS2
  16 dBm (+/-2 dB) at MCS3
  16 dBm (+/-2 dB) at MCS4
  16 dBm (+/-2 dB) at MCS5
  16 dBm (+/-2 dB) at MCS6
  16 dBm (+/-2 dB) at MCS7
  HT-40
• IEEE 802.11n (5 GHz band):
  HT-20
  14 dBm (+/-2 dB) at MCS0/8
  14 dBm (+/-2 dB) at MCS1/9
  14 dBm (+/-2 dB) at MCS2/10
  14 dBm (+/-2 dB) at MCS3/11
  14 dBm (+/-2 dB) at MCS4/12
  14 dBm (+/-2 dB) at MCS5/13
  14 dBm (+/-2 dB) at MCS6/14
  14 dBm (+/-2 dB) at MCS7/15
  HT-40
• IEEE 802.11ac (draft) (5 GHz band):
  VHT-20
  14 dBm (+/-2 dB) at MCS8
  VHT-40
  14 dBm (+/-2 dB) at MCS9
  VHT-80
Receiver Sensitivity
• IEEE 802.11a:
  –82 dBm at 6 Mbit/s
  –81 dBm at 9 Mbit/s
  –79 dBm at 12 Mbit/s
  –77 dBm at 18 Mbit/s
  –74 dBm at 24 Mbit/s
  –70 dBm at 36 Mbit/s
  –66 dBm at 48 Mbit/s
  –65 dBm at 54 Mbit/s
• IEEE 802.11b:
  –76 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
  –82 dBm at 6 Mbit/s
  –81 dBm at 9 Mbit/s
  HT-20
  -82 dBm at MCS0/8
  -79 dBm at MCS1/9
  -77 dBm at MCS2/10
  -74 dBm at MCS3/11
  -70 dBm at MCS4/12
  -66 dBm at MCS5/13
  -65 dBm at MCS6/14
  -64 dBm at MCS7/15
  HT-40
  -79 dBm at MCS0/8
  -76 dBm at MCS1/9
  -74 dBm at MCS2/10
  -71 dBm at MCS3/11
  -67 dBm at MCS4/12
  -63 dBm at MCS5/13
  -62 dBm at MCS6/14
  -61 dBm at MCS7/15
  HT-20
  -82 dBm at MCS0/8
  -79 dBm at MCS1/9
  -77 dBm at MCS2/10
  -74 dBm at MCS3/11
  -70 dBm at MCS4/12
  -66 dBm at MCS5/13
  -65 dBm at MCS6/14
  -64 dBm at MCS7/15
  HT-40
  -79 dBm at MCS0/8
  -76 dBm at MCS1/9
  -74 dBm at MCS2/10
  -71 dBm at MCS3/11
  -67 dBm at MCS4/12
  -63 dBm at MCS5/13
  -62 dBm at MCS6/14
  -61 dBm at MCS7/15
  HT-20
  -82 dBm at MCS0
  -79 dBm at MCS1
  -77 dBm at MCS2
  -74 dBm at MCS3
  -70 dBm at MCS4
  -66 dBm at MCS5
  -65 dBm at MCS6
  -64 dBm at MCS7
  -59 dBm at MCS8
  HT-40
  -79 dBm at MCS0
  -76 dBm at MCS1
  -74 dBm at MCS2
  -71 dBm at MCS3
  -67 dBm at MCS4
  -63 dBm at MCS5
  -62 dBm at MCS6
  -61 dBm at MCS7
  -56 dBm at MCS8
  -54 dBm at MCS9
  HT-80
  -76 dBm at MCS0
  -73 dBm at MCS1
  -71 dBm at MCS2
  -68 dBm at MCS3
  -64 dBm at MCS4
  -60 dBm at MCS5
  -59 dBm at MCS6
  -58 dBm at MCS7
  -53 dBm at MCS8
  -51 dBm at MCS9
Antennas
• Internal antennas
Security
• Wi-Fi Protected Access (WPA/WPA2)
• WEP 64/128-bit encryption
• WPS 2.0 (PBC)
Device Management
• User-friendly web UI with desktop
Dimensions
• 63 x 44 x 23 mm
Weight
• 29.72 g
Power
• Powered by USB port
Temperature
• Operating: 0 to 40 °C
• Storage: -10 to 45 °C
Humidity
• Operating: 10% to 75% non-condensing
• Storage: 5% to 75% non-condensing
Certifications
• FCC
• CE
• CSA
* Maximum wireless signal rate derived from IEEE standard specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Products | Support  | News  | About |
