Quick find
Product features:
Unified Services Router
General features:
Hardware Version
•  B1
Ethernet Interface
•  10/100/1000 Mbps WAN Port
•  8 10/100/1000 Mbps LAN Ports
Wireless Interface
•  802.11 b/g/n (Single Band)
•  2 Detachable 2 dBi Omni-Directional Antennas
USB 2.0 Port
•  1
Console Port
•  RJ-45
Performance*
Firewall Throughput**
•  750 Mbps
Concurrent Sessions
•  20,000
New Sessions (per second)
•  200
Firewall Policies
•  200
Static/Dynamic IP
PPPoE/L2TP/PPTP
Multiple PPPoE
Static Route
Dynamic DNS
Inter-VLAN Route
NAT, PAT
Web Content Filtering
•  Static URL, Keywords, Dynamic WCF (License is required)
Intrusion Prevention System (IPS)
•  Signature Package Included in Firmware
Authentication
•  Internal User Database, Radius, POP3, LDAP, AD, NT Domain
DHCP Server/Client
DHCP Relay
IEEE 802.11q VLAN
VLAN (port-based)
IP Multicast
•  IGMP Proxy, IGMP Snooping
IPv6
3G/4G*** Redundancy
Multiple Service Set Identifier (SSID)
Service Set Identifier (SSID) to VLAN Mapping
Standard
•  802.11 b/g/n
Wireless Security
•  Wired Equivalent Privacy (WEP)
•  Wi-Fi Protect Setup (WPS)
•  Wi-Fi Protected Access – Personal (WPA-PSK)
•  Wi-Fi Protected Access – Enterprise (WPA-EAP)
•  Wi-Fi Protected Access version 2 – Personal (WPA-PSK)
•  Wi-Fi Protected Access version 2 – Enterprise (WPA-EAP)
VPN Tunnels
•  75
IPSec Tunnels
•  25
PPTP/L2TP Tunnels
•  25
GRE
•  10
Encryption Methods
•  DES 56 bit, NULL
IPSec/PPTP/L2TP/OpenVPN Server
IPSec NAT Traversal
Dead Peer Detection
IP Encapsulating Security Payload (ESP)
IP Authentication Header (AH)
VPN Tunnel Keep Alive
Hub and Spoke
Maximum Bandwidth Control
Priority Bandwidth Control
•  Port-based QoS
•  3 Classes
Web-based User Interface
Command Line
SNMP
•  v1, v2c, v3
Power Supply
•  External Power Supply Unit DC 12 V/1.5 A
Max. Power Consumption
•  12.6 W
Dimensions (L x W x H)
•  140 x 203 x 35 mm
Operation Temperature
•  0 to 40 В°C
Storage Temperature
•  -20 to 70 В°C
Operation Humidity
•  5% to 95% non-condensing
EMI/EMC
•  FCC Class B, CE Class B, RCM, IC
Safety
•  cUL, LVD (EN60950-1)
3rd Party Certification
•  IPv6 Ready, Wi-Fi, VPNC AES Interop, VPNC Basic Interop
MTBF
•  250,000 hours
* Actual performance may vary depending on network conditions and activated services.
** Firewall throughput is measured using UDP traffic with a 1,518 bytes packet size, adhering to RFC2544.
*** Available with future firmware upgrade.
Products | Support  | News  | About |
