Quick find
Product features:
NetDefend UTM Firewall
EOL EOS
General features:
Interfaces
• 6 configurable 10/100/1000 ports
• 2 USB ports (reserved)
• Console: 1 DB-9 RS-232
System Performance*
• Firewall throughput**: 1.2 Gbps
• VPN throughput***: 350 Mbps
• IPS throughput****: 400 Mbps
• Antivirus throughput****: 225 Mbps
• Concurrent sessions: 600000
• New sessions (per second): 15000
• Policies: 4000
Firewall system
• Transparent mode
• NAT, PAT
• Dynamic routing protocol: OSPF
• H.323 NAT Traversal
• Time-scheduled policies
• Application Layer Gateway (ALG)
• Proactive end-point security: ZoneDefense
Networking
• DHCP server/client
• DHCP relay
• Policy-based routing
• IEEE 802.1q VLAN: 1024
• Port-based VLAN
• IP Multicast: IGMP v3
Virtual Private Network (VPN)
• Encryption methods (DES/3DES/Twofish/Blowfish/CAST-128)
• Dedicated VPN tunnels: 2500
• PPTP/L2TP server
• Hub and Spoke
• IPSec NAT Traversal
• SSL VPN (will be available in the future)
Traffic load balancing
• Outbound load balancing
• Server load balancing
• Outbound load balance algorithms: Round-robin, Weight-based Round-robin, Destination-based, Spill-over
• Traffic redirect at fail-over
Bandwidth Management
• Policy-based traffic shaping
• Guaranteed bandwidth
• Maximum bandwidth
• Priority bandwidth
• Dynamic bandwidth balancing
High Availability (HA)
• WAN fail-over
• Active-Passive mode
• Device failure detection
• Link failure detection
• FW/VPN Session SYN
Intrusion and Detection Prevention System (IDP/IPS)
• Automatic pattern update
• DoS, DDoS protection
• Attack alarm via e-mail
• Advanced IDP/IPS subscription (purchased separately)
• IP blacklist by threshold or IDP/IPS
Content filtering
• HTTP type: URL blacklist/whitelist
• Script type: Java, Cookie, ActiveX, VB
• E-mail type: e-mail blacklist/whitelist
• External database content filtering
Antivirus
• Real-time AV scanning
• Unlimited file size
• VPN tunnel scanning
• Supports compressed files
• Signature licensor: Kaspersky
Power supply
• 80 PLUS Internal power supply
Max. power consumption
• 66.8 watts
Dimensions
• 440 x 400 x 44 mm
• 19-inch standard rack-mount
Operating temperature
• 0° to 40°C
Storage temperature:
• -20°C to 70°C
Operating humidity
• 5% to 95% non-condensing
EMI
• FCC Class A
• CE Class A
• C-Tick
• VCCI
Safety
• cUL, cB
MTBF
• 400000 hours
Products | Support  | News  | About |
