Quick find
Product features:
VPN Firewall
General features:
Interface Ethernet
• 2 10/100/1000 Mbps WAN Ports
• 4 10/100/1000 Mbps LAN Ports
USB
1 USB 2.0
Console
RJ-45
System Performance8
• Firewall Throughput7: 70 Mbps
• VPN Throughput9: 35 Mbps
• Concurrent Sessions: 30,000
• New Sessions (per second): 300
• Firewall Policies: 300
Internet Connection Type
• Static/ Dynamic IP
• PPPoE/ L2TP/ PPTP
• Multiple PPPoE
Firewall System
Static Route
• Dynamic Route: RIPv1, RIP v2, OSPF6
• Dynamic DNS
• Inter-VLAN Route
• NAT, PAT
• Web Content Filtering: Static URL, Keywords
• Intrusion Prevention System (IPS): Signature package included in Firmware
Networking
• DHCP Server/Client
• DHCP Relay
• IEEE802.1q VLAN
• VLAN (Port-Based)
• IP Multicast IGMP Proxy
• IPv6
• Route Failover
• 3G Redundancy
• Outbound Load Balancing
Virtual Private Network (VPN)
• VPN Tunnels: 35
• Encryption Methods: DES, 3DES, AES, Twofish, Blowfish, CAST-128, NULL
• IPSec/PPTP/L2TP Server
• IPSec NAT Traversal
• Dead Peer Detection
• IP Encapsulating Security Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
SSL Virtual Private Network (SSL VPN)
• SSL VPN Tunnel: 10
• SSL Encryption Methods: DES, 3DES, AES
• SSL Message Integrity: MD5, SHA1
Bandwidth Management
• Max. Bandwidth Control
• Priority Bandwidth Control
  Port-Based QoS
  3 Classes
System Management
• Web-based User Interface: HTTP, HTTPS
• Command Line
• SNMP v1, v2c, v3
Power Supply Internal
• Power Supply Unit
• DC 12 V / 2.5 A
Max. Power Consumption
15.6 W
Dimensions (L x W x H)
180 x 280 x 44 mm
Operation Temperature
0 to 40 °C
Storage Temperature
-20 to 70 °C
Operation Humidity
5% to 95% Non-condensing
EMI/EMC
FCC Class B, CE Class B, C-Tick
Safety
cUL, LVD(EN60950-1)
MTBF
260,000 hours
6 Available with future firmware upgrade.
7 The maximum Firewall plaintext throughput is based on RFC2544 testing methodologies.
8 Actual performance may vary depending on network conditions and activated services.
9 VPN throughput is measured using UDP traffic with a 1420 byte packet size, adhering to RFC2544.
Products | Support  | News  | About |
