DFE-560FX
Optical Fiber Fast Ethernet Adapter
Where to buy
Description
D-Link's DFE-560FX Optical Fiber Fast Ethernet Adapter connects your desktop PC to a reliable fiber network. The card plugs into a PCIe expansion slot inside your PC, transmitting data at 200 Mbps full-duplex. Supporting advanced functions including traffic priority queues and VLAN, this adapter provides a secure environment to let you run bandwidth-demanding applications, such as IP telephony and video conferencing.
Reliability and Performance
The DFE-560FX card allows you to establish a secure fiber link for your PC. It can be used to set up a workstation or a server with a direct fiber connection to a Fast Ethernet switch. Capable of running at 200 Mbps full-duplex, this card serves well in a high electromagnetic interference environment, providing data transmission over a cable distance of up to 2 km to the switch. Along with PCI Express v1.1 bus master operation, this card provides the highest possible performance. The bus master transfers data directly between the card and the host at multi-megabits per second, bypassing the host CPU to alleviate its workload.
Flow Control to Minimize Packet Loss
The card's embedded flow control feature provides a means to protect against possible data loss during transmission on the network. When connected to a Fast Ethernet switch that supports flow control, the card receives signals from the switch regarding buffer overrun during peak usage periods. It then delays transmission until the switch is ready again to accept new data.
VLAN to Improve Performance and Security
The card supports IEEE 802.1Q multiple Virtual LAN, allowing you to segment the network to smaller domains for improved performance and security. Dissemination of broadcast and unnecessary computer-to-computer packets can be restricted to reduce extraneous traffic. The card provides a VLAN table for the following functions: filtering packets by recognizing VLAN tags, stripping VLAN tags on receive, and inserting VLAN tags on transmit.
PXE Remote Boot Option
Remote boot is available as an option. Administrators can choose to set up a security scheme for diskless workstations to boot from servers using Intel's Preboot Execution Environment (PXE). Stations with boot ROMs installed on the onboard socket can boot an OS such as Windows, Linux, and NetWare installed on servers to run applications designated by the administrator.
General features
Standards
• IEEE 802.3u 100Base-FX
• IEEE 802.3ah 100Base-LX10/-BX10
• IEEE 802.3x Flow Control
• IEEE 802.1Q VLAN tagging, 32 groups
• PCI Express v1.1 2.5 GT/s
• Advanced Configuration and Power Interface (ACPI) v.1.0
Network Data Transfer Rate
• 200 Mbps (full-duplex)
Network Cable
• 62.5/125 or 50/125 micron multimode fiber-optics (up to 2 km at full-duplex)
Fiber Connector
• SC
Diagnostic LEDs
• Link
• Activity (Tx/Rx)
Cache Buffer
• 2 Kbytes receive FIFO
• 2 Kbytes transmit FIFO
Flow Control
• IEEE 802.3x flow control in full-duplex operation
IRQ
• Allocated by system
I/O Address
OS Support
• Microsoft Windows 8 32/64-bit Edition
• Microsoft Windows 7 32/64-bit Edition
• Microsoft Windows Vista 32/64-bit Edition
• Microsoft Windows XP 32/64-bit Edition
• Microsoft Windows Server 2012
• Microsoft Windows Server 2008
• Microsoft Windows Server 2003
• Microsoft Windows 2000
• Windows XP Embedded  and KITL (sample driver available post-production)
• Windows CE (sample driver)
• RHEL 4.6/5.1
• Linux Kernel version 2.4.36.2 to 2.6.24
• SLES 9 SP4 to 10 SP1
• DOS NDIS2
• FreeBSD 7.0
• SCO OpenServer 6/UnixWare 7.1.x
• Novell Netware 6.5
• Supports PXE and iSCSI Boot
Boot ROM Address
• Searched by system BIOS
Boot Servers Supported
• Intel PXE 2.1 Boot
• iSCSI Boot
Physical Parameters
Dimensions
• 115 x 69 mm
Power Consumption
• Maximum Power Consumption: 0.5 watts
Temperature
• Operating: 0В° to 40В°C
• Storage: -25В° to 55В°C
Humidity
• Operating: 5% to 90% non-condensing
Certifications
• CE Class B
• FCC Class B
Certificates
Order info
Pictures
DFE-560FX
View from the right
Front view
Downloads
Support Resources
