Description
Plug and Play
Most PCs manufactured today support Plug-and-Play (PnP) ISA industry specifications. These adapters support PnP , so on PnP systems, the only thing to do is drop the adapter into an ISA slot. During bootup, the computer examines all installed hardware and assigns necessary, conflict-free resources for the adapter.
Easy to Use
For older PCs that do not support PnP , these adapters provide an easy-to-use menu-driven program with on-line help that makes configuration setup an effortless task.
Most Economic Choise
With very low prices, these adapters are the most economic choice for connecting desktops ona 10Mbps network.
