DAP-1160EOL EOS
WIRELESS G ACCESS POINT
Where to buy
Description
CONNECT HOME AND SOHO TO A WIRELESS NETWORK
Create a wireless network for your home and offce using the D-Link DAP-1160 is an 802.11g standard Wireless Access Point. Connect this Access Point to a broadband modem and wirelessly share your Internet connection. Enjoy surfng the web, checking e-mail, and chatting with family and friends online.
PROTECT WIRELESS NETWORK AND DATA
The DAP-1160 provides 64/128-bit WEP encryption and WPA/WPA2 security to protect your network and wireless data. In addition, it also provides MAC address fltering and the Disable SSID Broadcast function to limit outsiders’ access to your home and offce network.
FLEXIBLY CONFIGURE YOUR AP FOR DIFFERENT APPLICATIONS
The DAP-1160 can be confgured to operate as (1) an Access Point to act as a central hub for wireless users, (2) an AP Client to connect to another Access Point, (3) a Bridge to joint two wireless workgroups together, (4) a Bridge with AP to act as wireless hub and a bridge at the same time, (5) a Repeater to extend the wireless coverage to cover all “dead” spots, (6) a WISP Client Router to let wireless Internet service subscribers share Internet connection with home/offce Ethernet-enabled computers without the need for an extra router, or (7) a WISP Repeater to let WISP subscribers share Internet connection with wireless computers without any extra router.
EASY TO INSTALL AND USE
With D-Link Setup Wizard, you can set up your wireless network in minutes. It confgures your DAP-1160’s operation mode, makes it easy to add new wireless devices onto the network, and helps you create a simple wireless network for your home and offce.
General features
NETWORK STANDARDS
+  802.11g wireless LAN
+  802.11b wireless LAN
+  802.3/802.3u 10BASE-T/100BASE-TX Ethernet
+  ANSI/IEEE 802.3 NWay auto-negotiation
DEVICE INTERFACES
+  2 10/100BASE-TX Ethernet LAN ports
MEMORY
+  4MB Flash Memory
+  16MB DRAM
OPERATING FREQUENCY
+  2.4 to 2.4835 GHz
OPERATING CHANNELS
+  FCC: 11
+  ETSI: 13
RADIO & MODULATION SCHEMES
+  DQPSK, DBPSK, CCK, OFDM
OPERATION MODES
+  Access Point
+  AP Client
+  Bridge
+  Bridge with AP
+  Repeater
+  WISP Client Router
+  WISP Repeater
ANTENNA
+  2dBi Gain detachable omni-directional antenna with RP-SMA connector
NETWORK STANDARDS
DEVICE INTERFACES
MEMORY
+  4MB Flash Memory
+  16MB DRAM
OPERATING FREQUENCY
+  2.4 to 2.4835 GHz
OPERATING CHANNELS
+  FCC: 11
+  ETSI: 13
OPERATION MODES
+  Access Point
+  AP Client
+  Bridge
+  Bridge with AP
+  Repeater
+  WISP Repeater
ANTENNA
RECEIVE SENSITIVITY
+  For 802.11b, at 8% PER:
  11Mbps: -80dBm
  5.5Mbps: -84dBm
  2Mbps: -87dBm
  1Mbps: -88dBm
+  For 802.11g, at 10% PER:
  54Mbps: -65dBm
  48Mbps: -66dBm
  36Mbps: -70dBm
  24Mbps: -74dBm
  18Mbps: -77dBm
  12Mbps: -79dBm
  9Mbps: -81dBm
  6Mbps: -82dBm
TRANSMIT OUTPUT POWER
+  16dBm (typical)
SECURITY
+  64/128-bit WEP data encryption
+  WPA-PSK, WPA2-PSK
+  WPA-EAP, WPA2-EAP
+  TKIP, AES
+  MAC address fltering
+  SSID broadcast disable function
QUALITY OF SERVICE (QOS)
+  Wi-Fi Multimedia (WMM)
DEVICE MANAGEMENT
+  Web-based management through Internet Explorer v.6 or later, Netscape Navigator v.6 or later or other Java-enabled browser
DIAGNOSTIC LED
+  Power
+  Status
+  Link/Act
+  WEP/WPA
+  MAC Ctrl
+  BRIDGE / REPEATER
+  LAN1
+  LAN2
POWER INPUT
+  5VDC 2A
+  External power adapter
DIMENSIONS
+  144 (W) x 109 (D) x 30 (H) mm
  (5.67 x 4.29 x 1.18 inches)
WEIGHT
+  229grams (0.5 lb)
OPERATING TEMPERATURE
+  0˚ to 55˚ C (32˚ to 131˚ F)
STORAGE TEMPERATURE
+  -10˚ to 70˚ C (14˚ to 158˚ F)
OPERATING HUMIDITY
+  10% to 90% non-condensing
STORAGE HUMIDITY
+  5% to 95% non-condensing
CERTIFICATION
+  FCC Class B
+  CE
+  C-Tick
+  Wi-Fi
54Mbps maximum wireless signal rate derived from IEEE standard 802.11g specifcations. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffc, building materials and construction, and network overhead, may lower actual throughput rate. Environmental factors will adversely affect wireless signal range, maximum throughput based on 802.11g devices.
Certificates
Order info
DAP-1160   802.11g Wireless Access Point with Advanced Features
Pictures
DAP-1160
Front view
Back view
Downloads
Support Resources
