DVG-2102SEOL EOS
2-PORT VOIP TELEPHONE ADAPTER
Where to buy
Description
INTERNET PHONE MADE FOR HOME & SOHO
The D-Link DVG-2102S 2-port VoIP Telephone Adapter (TA) allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over IP network technology with advanced communication features, and is compatible with industry wise phone service. With 2 FXS phone ports, this VoIP TA connects you to an ordinary phone set to let you make Internet phone calls.
SUPERIOR VOICE QUALITY
The DVG-2102S incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference, phone book, speed dialing and hot lines to make it convenient to dial out or answer phone calls.
COMPLETE SECURITY
The DVG-2102S supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It also provides various types of DOS protection in an attempt to make computer resources unavailable to its intended users.
General features
DEVICE INTERFACES
+ 2 RJ-11 FXS phone ports
+ 1 RJ-45 10/100BASE-TX LAN port with auto-MDI/MDIX
GENERAL FEATURES
+ 3-way call conference (local mixer)
+ Call-parking
+ Call Back on Busy
+ Digit Map
+ Direct IP-to-IP Call without SIP Proxy
+ Echo cancellation (Echo tail 64ms)
+ Hot Line and Warm line calling
+ Includes a phone book with speed dial
+ Music on hold
+ MWI
+ Multi SIP Account (up to 3 proxy)
+ Need to support IP-IP call (P2P: RTP connection) without proxy (ex. phone book)
+ VMWI-Via FSK
CALL FEATURES
+ Anonymous Call Blocking
+ Call Block and Filter
+ Call Forwarding - Always
+ Call Forwarding - Busy
+ Call Forwarding - No Answer
+ Call Forwarding - Follow Me
+ Call Forwarding - Unconditional
+ Call Forwarding - Unavailable
+ Call History (Call status)
+ Call Hold
+ Caller ID (Proxy support)
+ Caller ID blocking
+ Call Pick Up
+ Call Return
+ Call Transfer (Proxy support)
+ Call Time
+ Call Park & retrieve
+ Call Waiting
+ Do Not Disturb
TELEPHONY FEATURES
+ I Codec: G711μ/A-law, G729A/B/AB, G.723(6.3/5.3 kbps), G.726(40)
+ Echo cancellation
+ Voice Activity Detection (VAD) for G.711/723/729
+ Comfort Noise Generation (CNG) for G.711/723/729
+ Out of Band DTMF event
+ Gain Control (incoming/outgoing)
+ Automatic voice/fax/data detection and switching up to 33.6Kbps
+ Echo Canceller
+ Adaptive Jitter Buffer
+ G3/Super G3 T.38 up to 14.4 kbps
+ DTMF detection and generation
+ Caller ID detection and generation: Bellcore type1 and 2, ETSI type 1 and 2
+ Caller ID detection mode: DTMF + FSK auto detection at same time
+ Tone / Multi tone detection: 300~2KHz
+ T.38 real time FAX/T.30 FAX bypass through G.711
+ CPT: 1 continuous cadence steps, 16sets (Optional)
+ FXS support 12/16 Khz (Optional)
+ Terminating Impedance Agnostic – 8 Settings
MANAGEMENT
+ Automatic Provisioning (Firmware Update / TR-069/104(Optional) )
+ (SNMP v2 and standard provisioning functions removed when this option is selected)
+ Confguration Backup/Restore
+ DHCP / PPPoE /Static / PPtP / L2TP / MAC Clone on WAN
+ DNS and Dynamic DNS
+ Firmware upgrade through Web interface
+ Flat Call Detail Record (CDR)
+ WAN IP and Net Mask Specifcation
+ Network Time Protocol time synchronization and confgurable time zone
+ Password Security (WebUI)
+ SNMP v2
+ System event
+ Syslog
+ TFTP/FTP/HTTP Client and TFTP repository maintenance
ACCOUNT MANAGEMENT
+ By port registration
+ By device registration (share account)
+ Mixed mode (Hunt number for inbound, by port number for outbound)
+ Invite with Challenge
+ Register by SIP Server IP Address or Domain Name
+ Support RFC3986 SIP URI format
DIAGNOSTIC LEDs
+ Power
+ Phone (x2)
+ WAN
QoS
+ TOS
+ 802.1P Priority Queues (8 queues)
+ Diffserv (DSCP)
VLAN
+ VLAN Tagging in voice
DIMENSIONS
135 x 96 x 40 mm
WEIGHT
160 grams
POWER REQUIREMENT
12VDC 1A
POWER INPUT
100-240Vac, 50/60Hz, 1A,
POWER CONSUMPTION
+ 4.8W
OPERATING TEMPERATURE
0˚ to 45˚C (32˚ to 113˚ F)
STORAGE TEMPERATURE
-20˚ to 65˚C (-4˚ to 149˚ F)
OPERATING HUMIDITY
10% to 90% non-condensing
STORAGE HUMIDITY
5% to 95% non-condensing
EMISSION (EMI CERTIFICATIONS)
+ FCC Class B
+ CE
TELECOM CERTIFICATIONS
+ FCC Class B
+ CE
MTBF
+ 115486 Hrs
Certificates
Order info
DVG-2102S  2-PORT VOIP TELEPHONE ADAPTER
Pictures
DVG-2102S
Back view
Front view
Front view
Downloads
Support Resources
