Description
Everything you need for a home
Get everything from the D-Link DVA-N6670B Wireless N VoIP VDSL2 Modem Router. This all encompassing device includes an integrated high-speed VDSL2 modem, two VoIP phone connections, 802.11n wireless interface, and a 4-port Ethernet switch. This router provides all the functions that your home needs to establish a fast, secure Internet connection, make and receive Internet calls, and wirelessly share the Internet link with your family members.
Fast VDSL speed for clear internet phone
The DVA-N6670B provides VDSL speeds of up to 100 Mbps downstream and 50 Mbps upstream, suitable for Internet phone calls. It combines the industry’s latest Voice over IP technology with advanced communication features, and is compatible with industry-wise phone services. With two FXS phone ports and a FXO lifeline, this router can connect to two ordinary phone sets for two simultaneous phone calls, and relay phone calls to PSTN automatically in case of a power outage, so your phone line will always be available.
Secure wired and wireless connection
The DVA-N6670B provides an integrated 802.11n WLAN supporting wireless speeds of up to 300 Mbps, and four Ethernet ports to connect to four computers through the network cables. It provides WEP data encryption and WPA/WPA2 wireless security, Stateful Packet Inspection (SPI) firewall protection, MAC/IP/ Port access filtering access, and day/time parental control. Traffic prioritization and classification enable your home to experience smooth VoIP and streaming media without concern of traffic congestion.
General features
DEVICE INTERFACES
• 1 RJ-11 VDSL port (to phone line)
• 2 RJ-11 FXS ports (to analog phones)
• 1 RJ-11 PSTN port (lifeline to phone line)
• 4 RJ-45 10/100BASE-TX Ethernet LAN ports with auto MDI/MDIX (to computers)
• 1 USB 2.0 port
• 802.11n WLAN (AP wireless connection to computers)
• Factory reset button
• Power oN/oFF switch
• Wireless on/off switch
• WPS button
VDSL FEATURES
• VDSL Transmission Band Plan: ITU-T G.993.2
• VDSL Duplex Method: Frequency Division Duplexing, FDD for both DS/US
• VDSL Line-code Scheme: Multi-Carrier Modulation (MCM)
• 5-band operation meet ITU-T G.993.2, including U0, DS1, US1, DS2, US2, band from 25 kHz to 17 MHz
• VDSL Handshake Procedure: ITU-T G.994.1 compliant
• VDSL Physical-layer supports “Packet Transport Mode (PTM)”
• Supports Rate Adaptation
• Supports VDSL Line Status
• Performance: 100 Mbps downstream, 50 Mbps upstream
VoIP PROTOCOL SUPPORT
• SIP (RFC 3261)
TELEPHONE FUNCTION SUPPORT
• DTMF dial tone signal support
• Caller ID support
AUDIO CODE
• G.711u-law/A-law
• G.723.1
• G.726
• G.729A/B
ECHO CANCELLATION
• G.168
FAX FUNCTION SUPPORT
• Transparent fax (G.711)
VoIP NAT TRAVERSAL
• SIP
WIRELESS LAN
• 802.11b/g standards
• 802.11n standard
• Wireless speed: up to 54 Mbps (802.11g), 300 Mbps (802.11n)
• Frequency range: 2.4 GHz to 2.484 GHz
• Antennas: dual 2x2 built-in MIMo antennas
• 64/128 bits WEP data encryption
• WPA/WPA2 (Wi-Fi Protected Access)security
• Multiple SSID
• 802.11e Wireless QoS (WMM/WME)
• MAC address-based access control
NETWORK PROTOCOLS & FEATURES
• NAT/NAPT (RFC 1631)
• RIP v1 (RFC 1058)
• RIP v2 (RFC 1389)
• Static Routing
• DNS
• TCP/UDP
• ARP/RARP (RFC 826)
• ICMP (RFC 791)
• DHCP Server/Client (RFC 2131)
• IP Multicast - IGMP Proxy/Snooping
• UPnP Compliant
• Virtual Server/Port Forwarding
• DMZ
• SNTP/NTP
• Printer sharing
FIREWALL/ACCESS SECURITY
• Built-in NAT firewall
• DoS attacks prevention
• Packet filtering based on port, source IP address, destination IP address, MAC address (ICMP/TCP/UDP)
VIRTUAL PRIVATE NETWORK (VPN)
• PPTP/L2TP/IPSec pass-through
QoS
• VLAN port mapping QoS for 4 LAN ports
• Packets classification (IP/MAC/Port and physical port)
• IP ToS
CONFIGURATION/MANAGEMENT
• Quick Installation Wizard
• Web-based GUI for remote/local management
• Firmware upgrade, configuration data upload/download via Web-based GUI
• Telnet server for remote/local management
• Syslog monitoring
• SNMP v.1, v.2c support with built-in MIB-I & MIB-II (RFC 1213)
• TR-069
BANDWIDTH MANAGEMENT
• IGMP Snooping
• VLAN port mapping
DIAGNOSTIC LEDS
• Power
• LAN 1 to 4
• WLAN
• USB
• VoIP 1 and 2
• PSTN
• VDSL
• Internet
• WPS
POWER INPUT
• Through 12 V/1.5 A external power adapter
OPERATING TEMPERATURE
• 0˚ to 40˚C
STORAGE TEMPERATURE
• -20˚ to 70˚C
OPERATING HUMIDITY
• 5% to 95% non-condensing
CERTIFICATIONS
• CE
Certificates
Order info
DVA-N6670B Wireless N VoIP VDSL2 modem router
