DVG-3032SEOL
32-Port VoIP Trunk Gateways
Where to buy
Description
The D-Link DVG-3016S/DVG-3032S VoIP trunk gateways connect an IP network to POTS (plain old telephone service) analog lines to send IP voice and data to the conventional phone sets and fax machines. These devices provide 16 or 32 FXO (Foreign eXchange Office) ports for 16 or 32 phone line connections. IP network connection can be through the LAN port or the WAN port, both of which are 10/100BASE-TX Ethernet interfaces.
For Enterprise Use. In a remote IP phone to local analog phone line application, a branch office can take in IP voice calls from a head office, then route them to local destinations equipped with only analog
phones. The long distance calls are sent through the Internet without any phone charge, and the remote office pays only for the local analog phone time. The gateways connect analog callers to the IP network
without involving operators or incurring toll charges from telephone companies
For Service Providers. The DVG-3016S/DVG-3032S VoIP trunk gateways can also be deployed by service providers to interface their VoIP infrastructure with a Public Switched T elephone Network (PSTN). For incoming calls from subscribers, these gateways accept local analog calls and place them on the IP network for sending out over the Internet. The gateways accept dial tone and ring current from the connected equipment, and facilitate the use of conventional phone sets and fax machines on a VoIP network. They allow analog phone callers to place calls, with a small charge, through the long-distance Internet trunk line.
Guaranteed Voice Quality. The DVG-3016S/DVG-3032S gateways deliver clear sound, voice and reliable fax calling through implementation of internationally recognized standards for voice and data networking. They incorporate Quality of Service (QoS) functions to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone.
Convenient Call Features. The DVG-3016S/DVG-3032S gateways support extensive call features, allowing the service providers to offer these functions to their subscribers. Provided that the telephone
sets at the end-users side support these functions, callers can take advantage of these convenient features. Configuration of individual phone connection is easy, using the multi-language Interactive Voice Response (IVR) or the web-based user's interface.
General features
VoIP
Analog Interface
• 32 FXO ports (2 RJ-21 connectors)
• Loop start signaling protocol
• Reversed polarity detection
Voice Features
• SIP (RFC3261) compatible
• SIP method: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, PING, PRACK, PUBLISH, REFER, REGISTER, SUBSCRIBE, UPDATE
• SIP Extension: Session Timer (UPDATE or re-INVITE), Proxy-Require, P-Asserted (RFC3325), MWI (RFC3842)
• Voice CODEC: G.711 a/u law, G.726, G.729A, G.723.1
• CNG (Comfort Noise Generation)
• VAD (Voice Activity Detection)
• Silence suppression/detection
• G.165/G.168 echo cancellation
• Adaptive Jitter Buffer and programmable Gain Control
• In-Band DTMF, Out-Of-Band DTMF relay (RFC2833, SIP INFO)
• Multiple SIP Proxy server entries with fail-over mechanism
• T.30 (G.III)/Real time T.38/Secured T.38 FAX relay
• DTMF, FSK (Bellcore & ETSI) Caller ID detection and generation
• Caller ID Restriction (CLIR) support
• FXO hang-up detection: Busy Tone cadence auto
• learning/detection
• Group hunting function
• Digit Map
• E.164 Numbering & ENUM support
• Recordable greeting message
• Hot-Line, Warm-Line support
Call Features
• Call Hold, Call Waiting, Call Pickup
• Call Forward: Unconditional, Busy, No Answer
• Call Transfer: Unattended, Attended
• Speed Dialing, Repeat Dialing, Three Way Calling (Media Server required)
IP Network
WAN Port
• RJ-45 10/100BASE-TX Ethernet port supporting Nway auto-negotiation, auto-detection/adjustment of MDI/MDIX
• Static IP, PPPoE, PPtP, Bigpond Cable and DHCP address assignment support
• QoS: IP TOS (IP Precedence), DiffServ, Port Priority
• NAT traversal: STUN, UPnP, OUTBOUND PROXY
• Pass-through NAT
• NAP: (Network Time Protocol RFC 1305), accepts up to
• 3 Time Servers Time Zones
• DDNS: DynDns.org, TZO, PeanutHull, 3322.org.
• RTP Packet Summary: packet sent, packet received, packet loss
• MAC address clone
LAN Ports
• NAT/PAT, DHCP Server, DMZ, Virtual Server, MAC/IP/port based filtering
• QoS: port based priority (Hi/Low) with rate limit
• Router or Bridge Mode
DoS Prevention
• Attack prevention based on TCP, UDP, IP, ICMP protocols
• Prevents SYN Flood, IP Spoofing, Ping of Death, Tear Drop DoS attacks
Operation & Maintenance
Management/Configuration
• Web-based & Telnet user interfaces with password authentication
• Configuration, port status, registration status, hardware/software information in web-based & Telnet UI
• IVR (Interactive Voice Response) configuration engine
• Reset button (factory default setting restoration)
• Optional Auto Provisioning Server (APS) for mass deployment with less dispatch
• SNMP v.1/v.2c support
• Ping test
Diagnostic LEDs
• Voice ports
• WAN port
• LAN port
• Run
• Power
• Alarm
Physical & Environmental
Power Input
• 90 to 260 VAC, 50/60Hz internal universal power supply
Dimensions
• 442 x 330 x 43 mm
Weight
• 4.4 kg
Operating Temperature
• 0 to 45 C
Storage Temperature
• -25 to 75 C
Operating Humidity
• Up to 90%RH, non-condensing
EMI
• FCC Class A
• CE
Safety
• UL
Certificates
Order info
DVG-3032S 32-Port VoIP Trunk Gateways
Pictures
DVG-3032S/С
Front view
DVG-3032S
Front view
Downloads
Support Resources
