DPH-150SE/RUEOL EOS
BROADBAND INTERNET IP PHONE
Where to buy
Description
INTERNET PHONE MADE FOR HOME & OFFICE
The DPH-150SE Broadband Internet IP Phone allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over the IP network (VoIP) technology with advanced communication features, and is compatible with industry-wide phone services. This sleek designed IP phone gives you the advantages of VoIP, while retaining the same look and feel of a traditional desktop telephone.
SUPERIOR VOICE QUALITY
The DPH-150SE IP phone incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference and speed dialing to make it convenient to dial out or answer phone calls.
SURF INTERNET WHILE MAKING INTERNET PHONE CALLS
The DPH-150SE comes with two Ethernet ports, one to connect to a DSL or cable modem, or to your broadband router. In an office environment equipped, this port can also connect to a PoE switch and obtain power directly from the network, dispensing you of the need to hook the IP phone to an AC power outlet. Once connected and logged onto the Internet, you are ready to make and receive calls. In addition, this IP phone provides another Ethernet port for connection to your PC, so you can talk on the IP telephone while browsing web sites, send e-mail, transfer files and do other network tasks on your PC.
QUALITY OF SERVICE AND SECURITY
The DPH-150SE supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides priority queues to streamline traffic so web browsing and Internet download will not interfere with voice traffic and degrade Internet phone quality.
General features
NETWORK INTERFACE
+ One RJ-45 10/100BASE-TX Ethernet port, one RJ-45 10/100BASE-TX Ethernet port with 803.2af Power over Ethernet
+ One RJ-45 port can connect to DSL/cable modem, remote router or Ethernet/Gigabit switch, the other RJ-45 port can connect to a PC
SIGNAL, MEDIA & NETWORK PROTOCOLS
+ SIP RFC 3261
+ SDP RFC 3266
+ RTP RFC 1889
+ IP assignment: DHCP, Static IP and PPPoE
+ STUN, UPnP & static port mapping (for NAT traversal)
+ SNTP
+ DNS & DNS SRV
+ TFTP/FTP/HTTP for Auto Provision
+ IP/TCP/UDP/ARP/ICMP
VOICE CODEC
+ G.711a/u (64 kbps)
+ G.729A/B (8kbp)
+ G.723.1 (*Optional)
ADVANCED VOICE QUALITY FEATURES
+ Silence Suppression
+ Acoustic Echo Cancellation (G.167)
+ Voice Activation Detection (VAD)
+ Comfort Noise Generation
+ Jitter Buffer
+ DTMF Transmitter (SIP info, Transparent, RTC 2833 relay)
+ Packet Lost Concealment (PLC)
KEYPAD
+ Menu
+ Phone Book
+ 4 Navigator Keys for navigating in configuration; volume adjustment of Ringer, Speaker phone & Handset; OK & Cancel
+ MWI
+ Conference
+ Mute
+ Function (stay with Mute; integrated with numeric keys for configuration and information)
+ Transfer
+ Redial (Redial and the entry to access call history)
+ Hold
+ Speaker
+ 12 numeric keys with star & pound key
+ 12 programmable keys for Line, One-Touch Dial, Park & DSS/BLF
+ Fixed functional keys: 9
+ Navigator keys: 4
+ Programmable keys: 12
CALL FEATURES
+ Call Forward (Busy, No answer, Unconditional)
+ Call Waiting
+ DND (under three situations: unconditional, busy, no answer)
+ Three Way Conferences
LCD
+ LCD size: 13 characters x 2 lines
+ Black/White
LEDs
+ Status
+ Speaker
+ Hold
SPEAKER PHONE
Built-in Speaker
REMOTE FIRMWARE UPGRADE
FTP or TFTP (Trivial File Transfer Protocol) Via Ethernet
USER INTERFACE/NETWORK MANAGEMENT
+ LCD/Keypad UI in English & Russian versions
+ HTTP (Web) UI in English version
QoS
+ 802.1P Priority Queues
+ DiffServ (DSCP) SEcuRity/ Class of Service
+ 802.1Q VLAN Tag
+ Full range VLAN ID Support
PHONE FEATURES
+ Multi-user (4 SIP accounts)
+ Caller ID display
+ Call History: 20 Missed Calls, 20 Received Calls, 20 Dialed Calls
+ Phone book (up to 200 contact names and phone number)
+ Day/Time display
+ Call timer display
+ 9 Selective Ring tones (4 tones, 4 melodies & one mp3)
+ 10 Speed dial number
+ Incoming call Indicator
+ Password control for Configuration
+ Pre-dial before sending
+ Hot Line
+ Multi-Line
+ Internet Radio
+ MP3 Ringer
INPUT POWER
100~120, 220~240VAC
AC-DC switching power adapter
OUTPUT POWER
9V DC
POWER CONSUMPTION
Typical: 2.8 Watt (Standby)
Max: 3.0 Watt (Talking)
DIMENSIONS
200 x 220 x 100 mm
OPERATING TEMPERATURE
0° to 40°C
STORAGE TEMPERATURE
-20° to 60° C
OPERATING HUMIDITY
20% to 80% non-condensing
STORAGE HUMIDITY
15% to 85% non-condensing
CERTIFICATIONS
+ FCC Class B
+ CE Class B
+ UL/cUL
+ CB (IEC 60950-1)
+ RoHS certified
Certificates
Order info
Pictures
DPH-150SE/RU
Front view
Downloads
Support Resources
