Hızlı Arama
Ürün Özellikleri:
Unmanaged 20-Port 10/100/1000BASE-T with 4 GBIC Expansion Ports
EOL
Tanımlama:
The DGS-1024TG unmanaged Layer 2 switch provides (20) 1000BASE-T Gigabit Ethernet ports and (4) Open GBIC-Based ports. The DGS-1024TG is designed to meet the needs of the most demanding departmental and enterprise connection applications.
High Performance Wire-Speed Architecture
The DGS-1024TG delivers superior performance with exceptional value.  The DGS-1024TG supports full duplex wire-speed forwarding, making it an ideal solution for the most demanding bandwidth intensive applications.
Operational Simplicity
The DGS-1024TG supports a wide array of plug-in-play features:
• 10/100/1000BASE-TX auto sensing
• Universal UTP cable recognition for straight-through or crossover cables
• Full/Half duplex support
• IEEE 802.3x Flow Control
• IEEE 802.3z Compliance
Investment Protection
The DGS-1024TG provides exceptional value and flexibility.  With support for up to (4) GBIC modules, the DGS-1024TG can easily adapt to changes in customer media requirements without the need to perform an expensive “fork-lift” upgrade.  By supporting GBIC modules, customers can migrate to other more advanced solutions in the future, while still protecting a portion of their original investment. The DGS-1024TG is also protected by a limited 5 year warranty on electronics and a 3 year warranty on fans/power supplies (see support website for more details) The D-Link DGS-1024TG is a flexible, high performance, value-oriented solution for a wide range of Gigabit solutions.  The DGS-1024TG can be used in a variety of desktop and backbone Gigabit solutions, for companies from 24 employees to more than 350 employees.
Ürünler | Destek  | Haberler  | Hakkında |
