Hızlı Arama
Ürün Özellikleri:
8-port 10/100M Switch Module
EOL
Genel Özellikler:
• 8x auto-sensing 10/100Mbps Ethernet switch ports
• Automatic MDI/MDIX crossover for 10Base-T and 100Base-TX ports
• Auto-negotiation supported
• Back-Pressure-Base flow control on Half-duplex ports
• Pause-Frame-Base flow control on Full-duplex ports
• Store-and-forward technology for abnormal packet filtering
• Non-blocking and Full wire speed forwarding rate
• 4K-entry MAC Address Table
• LED-indicators for 100M, LK/ACT, FD/COL status
Fiziksel Özellikler
Dimensions
178 mm x 152 mm x 25 mm
Weight
213 ~ 283 g
Operating Temperature
0ºC to 45ºC
Operating Humidity
10% to 90% (Non-condensing)
Power Supply
Input rate: 100~240VAC, 50~60Hz
EMI
FCC Class A, CE Mark
Ürünler | Destek  | Haberler  | Hakkında |
