DES-102FEOL EOS
Tanımlama
The DES-102F is a two-port Ethernet module design to support the DSS-24+ Switch as an optional slide in module, which provides a two port 100BASE-FX Fast Ethernet connection. As an expansion module, the DES-102F increases connection distances without requiring signal regeneration using a repeater to re-boost the signal. With the two SC type port connectors, connection utilizing a fiber link can be initiated to servers or backbone switches for network expansion. DES-102F is targeted at small and medium businesses.
The DES-102F is compliant with IEEE 802.3u 100BASE-FX standard, supporting both auto-negotiation at full duplex modes and flow control signaling on each individual port. Being an expansion module, the DES-102F endorses all of the Layer 2 functionalities of the DSS-24+.
Genel Özellikler
| Specifications |
| EMI | Based on the DSS-24+ EMI
| Weight | 0.56 Lbs |
| Dimensions | 7 Ѕ x 10 Ѕ x 2.0 |
Çözümler
Sipariş Bilgisi
DES-102F 2-Port 100BASE-FX Fiber Module for DSS-24+
