DGS-3308TGEOL EOS
Multi-layer Routing Gigabit Switch
Tanımlama
Wire-speed IP Packet Routing
Using standard-based routing, the DGS-3308TG provides instant support for Windows, Unix and Internet environments. Built-in wire-speed non-blocking switch fabric provides hardware-based packet filtering/forwarding. Packet routing is performed by on-board ASICs, which is many times faster than traditional CPU-based routers.
Seamless Integration
The DGS-3308TG can be instantly integrated into any existing network for seamless integration of Layer 2 and Layer 3 packet switching.  With Layer 2 and Layer 3 support for every port, you can flexibly segment the network into domains and sub-domains, using (1) subnet IDs and user IP numbers to route traffic, and (2) custom filters based on users' physical MAC addresses to filter extraneous traffic. At Layer 2, the switch uses auto-learned and user-defined MAC addresses to discard and forward packets. At Layer 3, it looks at the user-specified routing table to route packets to their destinations.
6 Gigabit Ports Over Existing Twisted-pair Cables
The DGS-3308TG provides 6 1000BASE-T copper Gigabit ports with full/half-duplex support. These ports transmit data at 1000Mbps over your existing Cat. 5 twisted-pair network cable, avoiding for you to the need to install expensive fiber cables. These ports, furthermore, support auto-sensing 10/100/1000Mbps speeds, allowing you to integrate with your existing Ethernet network then instantly upgrade to Gigabit anytime later.
2 GBIC Fiber Ports
For flexible fiber connection, 2 GBIC ports are provided for installation of 1000BASE-SX short/medium-distance and 1000BASE-LX long-distance fiber.  An optional PHY module must be inserted in each of these ports.
Maximum Network Uptime
The switch provides the capability to operate with an optional redundant power supply. This gives you the added reliability against power interruption risks and is important for mission-critical applications.
VLANs for Performance & Security
When operating at Layer 2, you can set up VLANs for different ports to set broadcast domains and segment network traffic to manage available bandwidths and enhance network security.
Port Trunks for Bandwidth Aggregation
The Gigabit ports can be combined together to create a multi-link load-sharing trunk. Up to 4 Gigabit ports can be set up per trunk. The switch supports up to 4 port trunks. Port trunks are useful for switch-to-switch cascading, providing very high full-duplex speeds.
Quality of Service (QoS)
Built-in IEEE 802.1P Priority Queues capability allows your workstations and server to attach to the switch and run delay-sensitive applications like video-conference and IP telephony based on traffic prioritization and queuing mechanism.
IP Multicast (IGMP snooping)
The switch listens to IGMP (Internet Group Management Protocol) messages to build mapping table and associate forwarding filters. It uses GMRP (GARP Multicast Registration Protocol) to dynamically configure the switch ports to forward IP multicast traffic only to those ports associated with multicast hosts.
Port Mirroring
This capability allows you to mirror adjacent ports for the purpose of analyzing incoming  and outgoing packets where packets can be studied.
Genel Özellikler
Standards
- IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
- IEEE 802.3u 100BASE-TX Fast Ethernet (twisted-pair copper)
- IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
- ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
- IEEE 802.1Q VLANs
- IEEE 802.1P Priority Queues
Topology
Star
Protocol
CSMA/CD
Data Transfer Rates
- Ethernet:
  10Mbps (half duplex)
  20Mbps (full duplex)
- Fast Ethernet:
  100Mbps (half duplex)
  200Mbps (full duplex)
- Gigabit Ethernet:
  2000Mbps (full duplex)
Network Cables
- 10BASE-T:
  2-pair UTP Cat. 3, 4, 5 (100 m)
  EIA/TIA-586 100-ohm STP (100 m)
- 100BASE-TX, 1000BASE-T:
  UTP Cat. 5 (100 m)
  EIA/TIA-568 100-ohm STP (100 m)
- 1000BASE-SX:
  62.5/125 micron multi-mode fiber (260 m)
  50/125 micron multi-mode fiber (550 m)
  9 micron single-mode fiber (5 Km)
Full/half Duplex
- Full/half duplex for 10/100Mbps speeds
- Full duplex only for Gigabit speed
Number of LAN Ports
- 6 10/100/1000Mbps ports (RJ-45 connectors)
- 2 GBIC ports
Diagnostic LEDs
- Link/Act (per port)
- 10/100/1000Mbps speed (per twisted-pair port)
- Full/half duple (per twisted-pair port)
- Power (per device)
- Console (per device)
Layer 2 Switching
Switching Method
Store-and-forward
MAC Address Table
8K entries per device
Routing
Routed Packet Type
IP-protocol packets
Routing Protocols
- Static Routing
- RIP-1, RIP-2
Routing Table
2K entries per device
Configuration & Management
Standards
SNMP, RMON, Web-based, Telnet
RMON Groups
1, 2, 3, 9
MIBs
- MIB-II (RFC 1213)
- Bridge MIB (RFC 1493)
- VLAN MIB (RFC 2674)
- RMON MIBs (RFC 1757)
- IF MIBs (RFC 2233)
- IP-Forward MIB (RFC 2096)
- RIP-2 MIB (RFC 1724)
- IGMP MIB
- ID-REC MIB
- IPMROUTE MIB
- PIM MIB
- DVMRP MIB
Priority Queues
4 queues
IP Number Self-identification
- Through DHCP client
- Through Bootp client
User IP Number Assignment
Through DHCP relay agent (user name to IP address mapping supported)
Redundant Backup Bridge Paths
IEEE 802.1D Spanning Tree standard
Firmware Upgrade
TFTP
Console Port
DB-9 RS-232
Çözümler
Sipariş Bilgisi
DGS-3308TG
   6 10/100/1000Mbps copper Gigabit ports (RJ-45 Connectors), 2 GBIC fiber ports
Optional Redundant Power Supply
DPS-1000
    Redundant power supply (chassis + 1 DPS-1001 module)
DPS-1001    Redundant power module for each switch
Görseller
DGS-3308TG/A
View from the right
İndir
Destek Merkezi
