DEM-331TEOL EOS
1port 1000BaseLX SM Fiber WDM (40km)
Tanımlama
The DEM-330T/330R and DEM-331T/331R Bidirectional Gigabit SFP Fiber Transceivers are external transceivers designed for insertion in SFP (Small Form-Factor Pluggable) slots of network devices for transmission and reception of data signals on the fber cables. These transceivers provide the Gigabit operation and physical compactness to deliver the speed, reliable long-distance data transfer, and deployment fexibility that today’s fber networks require.
Ideal for Long Distance Application
The DEM-330T/330R and DEM-331T/331R transceivers can be used to connect together switches, servers and fber modules on a campus or metropolitan area network (MAN). Providing up to 10 km (DEM-330T/330R) or 40 km (DEM-331T/331R) of fber cable distance, these highly integrated transceivers offer low jitter performance for extended optical link support without any degradation in performance.
Reliable Transmission
The DEM-330T/330R and DEM-331T/331R transceivers combine transmitting and receiving signals onto one fber strand using two wavelengths. These transceivers are used in pair. At one end, one transceiver uses one wavelength to transmit and a second wavelength to receive. At the other end, the other transceiver fips that relationship.
Standard Compliance
The DEM-330T/330R and DEM-331T/331R transceivers use standard simplex LC connectors for fber cable connection. They conform to industry standards and are interoperable with D-Link Gigabit switches. Hot-swap capability allows network administrators to plug or unplug them from the SFP slots without having to
turn off the power of the connected device.
Durable
The DEM-330T/330R and DEM-331T/331R transceivers are packed in a Small Form Pluggable (SFP) metal housing to increase durability.
Genel Özellikler
Standard
IEEE802.3z 1000BASE-BX-D
Wavelength
Tx: 1550nm, Rx: 1310 nm
Connector
Simplex LC
Fiber Type
9/125um Single-mode Fiber
Maximum Fiber Cable Length
40 km
Transmit Power Range
2 to -3 dBm
Receive Power Range
-1 to -23 dBm
Sensitivity
-23 dBm
Min. Power Budget
20 dB
Max. Power Budget
25 dB
Çözümler
Sipariş Bilgisi
Görseller
DEM-331T/01
Front view
İndir
Destek Merkezi
