Hızlı Arama
Ürün Özellikleri:
Managed 24-Port 10/100 L2+ Switch, 4 Gigabit Copper Ports + 2 Combo SFP
EOL EOS
Genel Özellikler:
Interface
+ 24 10/100BASE-TX Ports
+ 2 Dual Usage 10/100/1000BASE-T Stacking Ports**
+ 2 Combo 10/100/1000BASE-T Ports/SFP Slots
+ Auto-Negotiation of Network Speeds (RJ-45 Ports
+ Auto-MDI/MDIX (RJ-45 Ports)
+ Gigabit & 100BASE-FX Fiber Support On SFP
+ RS-232 Console Port
Power
+ Internal Power Supply: AC to DC
+ Power Input: 100 to 240VAC, 6.3A (max.), 50 to 60Hz
+ Power Output (per device): 50VDC, 7.5A (max.), 12VDC, 1.4A (max.)
+ Power Output (per PoE port):
    - 30watts (max.), Ports (1-8)
    - 15.4watts (max.), Ports (9-24)
+ Power Consumption: 505.1watts (max.)
+ Optional Redundant Power Supply
Performance
+ Switching Capacity: 12.8Gbps
+ Max. 64-Byte System Packet Forwarding Rate: 9.5Mpps
+ MAC Address Table: 16K
Software Features
Diagnostic LEDs
+ 10Mbps or 100Mbps Speed (per Ethernet port)
+ 10/100Mbps or 1000Mbps Speed (per Gigabit port)
+ Link/Activity (per port)
+ Power, Console, (per device)
+ RPS (per device)
Stackability
+ Vir tual Stacking:
- Supports D-Link Single IP Management (SIM)
- Up to 32 units per Vir tual Stack
L2 Features
+ Flow Control:
- 802.3x Flow Control
- HOL Blocking Prevention
+ Jumbo Frames suppor t up to 9,216 bytes
+ Spanning Tree Protocol:
- 802.1D STP
- 802.1w RSTP
- 802.1s MSTP
- BPDU Filtering
+ Loopback Detection (LBD)
+ 802.3ad Link Aggregation:
- Max. 8 groups per device, 8 por ts per group
+ Por t Mirroring:
- One-to-one
- Many-to-one
- Flow-based Mirroring
L2 Multicasting
+ IGMP Snooping:
- IGMP v1/v2/v3 Snooping
- Suppor ts 256 groups
- IGMP Snooping Fast Leave
+ Limited IP Multicasting (IGMP Filtering):
- Up to 24 IGMP Filtering Profiles, 128 ranges per profile
+ MLD Snooping:
- MLD v1/v2 Snooping
- MLD Snooping Fast Leave
VLAN
+ VLAN Group:
- Max. 4K VLAN
+ GVRP:
- Max. 256 Dynamic VLAN
+ 802.1Q Tagged VLAN
+ Por t-based VLAN
+ 802.1v Protocol VLAN
+ Double VLAN (Q-in-Q):
- Por t-based Q-in-Q
- Selective Q-in-Q
+ VLAN Translation
+ MAC-based VLAN
+ ISM VLAN
+ Asymmetric VLAN
Quality of Service (QoS)
+ 802.1p Quality of Service
+ 8 queues per por t
+ Queue Handling:
- Strict Priority
- Weighted Round Robin (WRR)
- Strict + WRR
+ CoS based on:
- Switch Por t
- VLAN ID
- 802.1p Priority Queues
- MAC Address
- IPv4/v6 Address
- DSCP
- Protocol Type
- IPv6 Traffic Class
- IPv6 Flow Label
- TCP/UDP Por t
- User-defined packet content
+ Actions for flows:
- Remark 802.1p Priority Tag
- Remark TOS/DSCP Tag
- Bandwidth Control
- Flow Statistics
- Committed Information Rate (CIR), min. granularity 64Kbps
+ SRED Congestion Control
+ Bandwidth Control:
- Por t-based (Ingress/Egress, min. granularity 64Kbps)
- Flow-based (Ingress, min. granularity 64Kbps)
+ Time-based QoS
Access Control List (ACL)
+ Up to 768 Access Rules
+ ACL based on:
- 802.1p Priority
- VLAN ID
- MAC Address
- Ether Type
- IPv4/v6 Address
- DSCP
- Protocol Type
- TCP/UDP Por t Number
- IPv6 Flow Label
- User Defined packet content
+ ACL Statistics
+ Time-based ACL
+ CPU Interface Filtering
Security
+ SSH v2
+ SSL v1/v2/v3
+ Por t Security:
- Up to 64 MAC addresses per por t
+ Broadcast/Multicast/Unicast Storm Control
+ Traffic Segmentation
+ IP-MAC-Por t Binding (IMPB):
- ARP Packet Inspection
- IP Packet Inspection
- DHCP Snooping
- Supports 500 Address Binding Entries per device
+ D-Link Safeguard Engine
+ NetBIOS/NetBEUI Filtering
+ DHCP Server Screening
+ DHCP Client Filtering
+ BPDU Attack Protection
AAA
+ 802.1X:
- Por t-based Access Control
- Host-based Access Control
- Dynamic VLAN Assignment
+ Web-based Access Control (WAC):
+ MAC-based Access Control (MAC):
+ Japanese Web-based Access Contro
+ Guest VLAN
+ Suppor ts Microsoft® NAP
+ RADIUS Accounting
+ RADIUS and TACACS+ Authentication for
Switch Access
+ Three Level User Accounts
Management
+ Web-based GUI
+ Command Line Interface (CLI)
+ Telnet Server
+ TFTP Client
+ ZModem
+ SNMP v1/v2c/v3
+ SNMP Traps
+ System Log
+ RMON v1:
- Suppor ts 1, 2, 3, 9 groups
+ RMON v2
- Suppor ts ProbeConfig group
+ LLDP
+ BootP/DHCP Client
+ DHCP Auto-Configuration
+ DHCP Relay
+ DHCP Relay Option 82
+ PPPoE Circuit-ID Tag Inser tion
+ DHCP Server
+ Dual Image
+ Dual Configuration
+ CPU Monitoring
+ NTP/SNTP
+ Password Recovery
+ Password Encryption
MIB
+ RFC1213
+ RFC1493 Bridge MIB
+ RFC1907 SNMPv2 MIB
+ RFC1757, 2819 RMON MIB
+ RFC2021 RMONv2 MIB
+ RFC1643, 2358, 2665 Ether-like MIB
+ RFC2674 802.1p MIB
+ RFC2233,2863 IF MIB
+ RFC2618 RADIUS Authentication Client MIB
+ RFC2620 RADIUS Accounting Client MIB
+ RFC2925 Ping & TRACEROUTE MIB
+ D-Link Private MIB
IETF® Standard
+ RFC768 UDP
+ RFC783 TFTP
+ RFC791 IP
+ RFC792 ICMP
+ RFC793 TCP
+ RFC826 ARP
+ RFC854 Telnet
+ RFC951, 1542 BootP
+ RFC2068 HTTP
+ RFC2138 RADIUS
+ RFC2139,2866 RADIUS Accounting
+ RFC2474 DiffServ
+ RFC2597 DSCP AF
+ RFC2598 DSCP EF
+ RFC1492 TACACS
+ RFC1157 SNMPv1
+ RFC1901,1908 SNMPv2c
+ RFC2570,2575 SNMPv3
+ RFC3164,3195 Syslog
+ RFC3046 DHCP Relay Option
Optional SFP Transceivers
DEM-310GT SFP transceiver for 1000BASE-LX, singlemode fiber, max. distance 10km, 3.3V
DEM-311GT SFP transceiver for 1000BASE-SX, multi-mode fiber, max. distance 550m, 3.3V
DEM-312GT2 SFP transceiver for 1000BASE-SX, multi-mode fiber, max. distance 2km, 3.3V
DEM-314GT SFP transceiver for 1000BASE-LHX, singlemode fiber, max. distance 50km, 3.3V
DEM-315GT SFP transceiver for 1000BASE-ZX, singlemode fiber, max. distance 80km, 3.3V
DEM-210 SFP transceiver for 100BASE-FX, singlemode fiber,max. distance 15km, 3.3V
DEM-211 SFP transceiver for 100BASE-FX, multimode fiber, max. distance 2km, 3.3V
DPS-200 60-watt redundant power supply
DPS-600 500-watt redundant power supply (for DES-3528P only)
DPS-800 2-slot redundant power supply chassis
DPS-900 8-slot redundant power supply chassis
Optional Management Software*
DV-600S D-View 6.0 Network Management System (Standard Edition)
DV-600P D-View 6.0 Network Management System (Professional Edition)
*Also supports D-View 5.1
Fiziksel Özellikler
Ventilation DC Fans
4 DC Fans
Heat Dissipation
1723 BTU/hour
Dimensions
441 x 310 x 44 mm
Rack Mounting
19-Inch Standard Rack-Mount Width, 1U Height
Weight
5.42 kg (11.94 lbs)
Operating Temperature
0 to 45 C
Storage Temperature
-40C to 70C
Operation Relative Humidity
20 to 80% Non-Condensing
Storage Relative Humidity
10 to 90% Non-Condensing
EMI
CE Class A, FCC Class A, C-Tick, VCCI
Safety
CB, UL / cUL
MTBF
345,226 hours
Acoustic (refer to ISO-7779)
37.7dB at max speed of fan
* Ports 1 to 8 support 802.3af and pre-standard 802.3at, and ports 9 to 24 support 802.3af only.
** Dual usage refers to stacking or standard Gigabit ports.
Ürünler | Destek  | Haberler  | Hakkında |
