Hızlı Arama
Ürün Özellikleri:
DGS-3120-24TC ver.B1ARI 24-Port Managed 10/100/1000BASE-T/SFP ports L3 Managed Switch
EOL
Sipariş Bilgisi:
DGS-3120-24TC/SI 20 10/100/1000BASE-T ports and 4 Combo 10/100/1000BASE-T/SFP ports with embedded SI image (stacking cable and SD card are not included) DGS-3120-24TC/EI 20 10/100/1000BASE-T ports and 4 Combo 10/100/1000BASE-T/SFP ports with embedded EI image (stacking cable and SD card are not included) DGS-3120-48TC/SI 44 10/100/1000BASE-T ports and 4 Combo 10/100/1000BASE-T/SFP ports with embedded SI image (stacking cable and SD card are not included) DGS-3120-48TC/EI 44 10/100/1000BASE-T ports and 4 Combo 10/100/1000BASE-T/SFP ports with embedded EI image (stacking cable and SD card are not included) DGS-3120-24SC/SI 16 SFP ports and 8 Combo 10/100/1000BASE-T/SFP ports with embedded SI image (stacking cable and SD card are not included) DGS-3120-24SC/EI 16 SFP ports and 8 Combo 10/100/1000BASE-T/SFP ports with embedded EI image (stacking cable and SD card are not included) DGS-3120-24SC-DC/SI 16 SFP ports and 8 Combo 10/100/1000BASE-T/SFP ports with embedded SI image and DC power supply (stacking cable and SD card are not included) DGS-3120-24SC-DC/EI 16 SFP ports and 8 Combo 10/100/1000BASE-T/SFP ports with embedded EI image and DC power supply (stacking cable and SD card are not included) DGS-3120-24PC/SI 20 10/100/1000BASE-T ports and 4 Combo 10/100/1000BASE-T/SFP PoE ports with embedded SI image (stacking cable and SD card are not included) DGS-3120-24PC/EI 20 10/100/1000BASE-T ports and 4 Combo 10/100/1000BASE-T/SFP PoEports with embedded EI image (stacking cable and SD card are not included) DGS-3120-48PC/SI 44 10/100/1000BASE-T ports and 4 Combo 10/100/1000BASE-T/SFP PoE ports with embedded SI image (stacking cable and SD card are not included) DGS-3120-48PC/EI 44 10/100/1000BASE-T ports and 4 Combo 10/100/1000BASE-T/SFP PoE ports with embedded EI image (stacking cable and SD card are not included)
Ürünler | Destek  | Haberler  | Hakkında |
