Hızlı Arama
Ürün Özellikleri:
Dlink DGS-6600 serisi şase orta ve geniş ölçekli kurumsal ağlar için tasarlanmıştır. Orta ölçekteki ağlar için omurga switch (Core switch), büyük ölçekli ağlar için dağıtım switch (distribution switch) olarak kullanılabilir.
Genel Özellikler:
Fiziksel Özellikler
·         Switch Fabric Forwarding Capacity
·         Switching Capacity 576 Gbps
·         Max. Packet Forwarding Rate
·         Max Packet Forwarding Rate 428.57 Mpps
·         MAC Address Table Size
·         MAC Address Table 32K
·         Number of Slots
·         4/8 Slots
·         Scalable Expansion
·         144 10/100/1000BASE-T Ports
·         144 PoE Ports
·         144 SFP Ports
·         48 10 Gigabit Ports
·         Hot Swappable Line Cards
·         Replaceable Fan Module
·         Spanning Tree (STP) 802.1d
·         Rapid Spanning Tree (RSTP) 802.1w
·         Virtual Router Redundancy Protocol (VRRP)
·         802.1p Priority Queues
·         L2/L3/L4 Multi-Layer Access Control
·         External RADIUS Authentication Support
·         Status/duplex/speed information LED
L2 Features
·         32K MAC per I/O module
·         Flow Control (802.3x, HOL Blocking Prevention)
·         Jumbo Frame up to 9,732 Bytes
·         IGMP v1/v2/v3 Snooping (1K groups)
·         Spanning Tree (STP, RSTP, MSTP)
·         802.3ad Link Aggregation (128 groups, 8 ports per group)
·         Port Mirroring
·         RSPAN
·         ERPS (Ethernet Ring Protection Switching)
·         MLD v1 Snooping (1K groups)
·         Loopback Detection
·         L2 Protocol Tunneling
VLAN
·         4K VLAN
·         802.1Q Tagged VLAN
·         802.1v Protocol VLAN
·         Port-based VLAN
·         Double VLAN (Q-in-Q)
L3 Features
·         4K IP interface
·         VRRP
·         IPv6 Tunneling (manual, ISATAP, 6to4)
·         IPv6 Ready Phase
·         Proxy ARP
·         Gratuitous ARP
L3 Routing
·         12K hardware routing entries shared by IPv4/IPv6
·         8K hardware L3 forwarding entries shared by IPv4/IPv6
·         Policy-based Route
·         RIP v1/v2, RIPng
·         OSPF v2, v3
·         BGP v4, BGPv4+
L3 Multicasting
·         1K hardware multicast groups
·         PIM-DM
·         PIM-DM v6
·         PIM-SM
·         PIM-SM v6
·         PIM Sparse-Dense Mode
·         IGMP v1/v2/v3
·         DVMRP v3
QoS (Quality of Service)
802.1p Class of Service (CoS)
8 queues
Queue Handling:
·         Strict
·         Weighted Round Robin (WRR)
·         Strict+WRR
·         Deficit Round Robin (DRR)
·         Strict+DRR
CoS Based on:
·         Switch Port
·         VLAN ID
·         MAC Address
·         IPv4/v6 Address
·         DSCP
·         Protocol Type
·         IPv6 Traffic Class
·         IPv6 Flow Label
·         TCP/UDP Port
·         User-defined Packet Content
Supports following actions for flows:
·         Remark 802.1p Priority Tag
·         Remark TOS/DSCP Tag
·         Bandwidth Control
·         Committed Information Rate (CIR), min. granularity 64Kbps
·         Port-based Bandwidth Control (Ingress/Egress, min. granularity 64 Kbps)
Time-based QoS
ACL (Access Control List)
Ingress / Egress ACL
ACL Based on
·         802.1p Priority
·         VLAN ID
·         MAC Address
·         IPv4/IPv6 Address or IP Prefix
·         DSCP/IP Precedence
·         IP Protocol Type
·         TCP/UDP Port Number
·         Combination of the above
·         Time-based ACL
Security
·         SSH v2
·         Port Security up to 16 MAC address per port
·         Broadcast/Multicast/Unicast Storm Control
·         DoS Attack Prevention
·         IP-MAC-Port Binding
·         ARP Spoofing Prevention
·         D-Link Safeguard Engine
AAA
802.1X
·         Port-based Access Control
·         MAC-based Access Control
·         Dynamic VLAN Assignment
3-Level user account
RADIUS Authentication for Switch Access
Guest VLAN
Web-based Access Control (WAC)
·         Host-based Access Control
MAC-based Access Control (MAC)
Management
·         Command Line Interface (CLI)
·         Telnet Server
·         Telnet Client
·         TFTP
·         DHCP Server
·         DHCP Relay
·         DHCP Relay option 82
·         SNMP v1/v2c/v3
·         SNMP Trap
·         System Log
·         RMON v1 (1,2,3,9 Groups)
·         Flash File System
·         Multiple Images
·         Multiple Configurations
·         Debug command
·         SNTP
·         Trusted Host
·         Microsoft® NLB Support
·         LLDP
·         sFlow
Green
·         Power Saving by Link status
·         Time-based PoE
Ürünler | Destek  | Haberler  | Hakkında |
