DEM-432XT-DDEOL EOS
SFP-Transceiver 1-Port 10GBASE-LR (c DDM) for single mode fiber optic cable, power supply 3.3 V (up to 10 km)
Tanımlama
Series 10G SFP + Module D-Link - it transceivers, hot swappable, which are installed in the ports of SFP + switches and provide job Ethernet networks at 10 Gb / s. Transceivers Series 10G SFP + Module D-Link offers users extensive connectivity to networks of 10-Gigabit Ethernet, and are designed for data center space to accommodate the switching equipment, as well as problem solving providers of telecommunications services.
Superior format Small Form-factor Pluggable
The transceivers use an improved format Small Form-factor Pluggable (SFP +). Form factor SFP + less than other form factors, such as Xenpak, X2 and 10G XFP, and provides a low cost, low power dissipation and high port density. The transceivers provide a signal gain as necessary to transfer data from the port to the network cable, and vice versa, a port for receiving data from the network cable.
Hot Plug
All D-Link transceivers support hot-plug capability. Connect the transceiver to a powered device will not cause any problems.This allows you to connect or disconnect the transceiver without disrupting the rest of the network.
Speed ​​10 Gb / s
The transceivers are designed to work in networks of 10-Gigabit Ethernet, which allows for very fast data transfers. A ten-fold increase compared with 1 Gbit / s allows the switch to faster and in greater volume to handle data streams.
Digital diagnostics DDM
Some of 10G SFP + transceivers 1 are critical tracking function parameters in real time (DDM), including input and output power, temperature, and voltage. This is useful for monitoring the state of the fiber-optic line, and early detection of problems.
Bidirectional (WDM) technology 2
Bidirectional (WDM) technology enables the reception and transmission of data over a single fiber using two different wavelengths. This helps to save additional cost of deploying fiber optic cables, and also provides a more flexible allocation of bandwidth.
1 Only the DEM-431XT-DD, DEM-432XT-DD, DEM-433XT-DD and the DEM-435XT-DD.
2 Models DEM-436XT-BXD and DEM-436-BXU.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DEM-432XT-DD/A
Front view
İndir
Destek Merkezi
