DGS-6600-48PEOL EOS
48 ports 10/100/1000 Base-T
PoE module
Tanımlama
PoE module
Genel Özellikler
48 ports 10/100/1000Base-T PoE Module
- 10/100/1000M ports compliant to following standards:
1. IEEE 802.3 compliance
2. IEEE 802.3u compliance
3. IEEE 802.3ab compliance
4. IEEE 802.3af compliance
5. Support Half/Full-Duplex operations
6. IEEE 802.3x Flow Control support for Full-Duplex mode
- PoE Capability
1. Supplies up to 15.4W power per port
2. Auto discovery / classification
3. Auto disable port if the current is over 350mA
4. Provide the power following the classification below
Class Usage Max power used by PD
0 Default 15.4W
1 Optional 4.0W
2 Optional 7.0W
3 Optional 15.4W
4 Reserved 15.4W
5. Follow the PSE pin out standard of Alternative A sending out
power over pin1,2,3,6 of 8 wires of Ethernet cable
6. Compatible with all D-Link 802.3af PDs (Powered Device), and
works with all non-802.3af D-Link AP, IP Cam and IP phone via
DWL-P50
