DPS-2500EOL EOS
Standalone / standby uninterruptible power supply, 300W
Tanımlama
Standalone / standby uninterruptible power supply D-Link DPS-2500 is an efficient and reliable power supply system for use in computer networks. Using an external battery DPS-2500 can provide a long-term operation of network devices and provide stable power to the connected equipment, in addition DPS-2500 provides system administrators time to a safe shutdown of network devices in the event of a power failure, to prevent data loss. Due to the automatic control mode power supply ensures a high reliability, so you can use this device to secure network devices such as routers, switches and access points. Audible alarm and front panel indicators provide information on the nutritional status and battery power.
Control Options
DPS-2500 contains software for the management and protection of network equipment. The device is a USB-port.
The compact design
DPS-2500 is placed in a compact package and provides uninterrupted protection from power surges in the event of a power failure.
Using rechargeable batteries
DPS-2500 has no internal battery. D-Link recommends the use of a standard 12-volt battery with any amperage.
Tip: The majority of car batteries can be used with DPS-2500.
