DPS-600EOL EOS
Redundant Power Supply, 500 Watt
Nereden Alınır
Tanımlama
DPS-600 - this is a redundant power supply (RPS), designed for use with Ethernet and Gigabit switches D-Link. RPS is made in a sturdy metal case with a connector for connection to a source of AC or DC (depending on model), and a connector for the power supply to the internal switch. RPS is an inexpensive device that allows to ensure uninterrupted power supply in the event of an unexpected failure, internal power switch that may lead to shutdown of the switch devices connected to its ports, or an entire network. Providing necessary for the switch output, RPS will improve the reliability of power supply unit.
Power redundancy
Each RPS D-Link continuously monitors the internal power supply. In the event of a power failure to immediately start a backup power source, so the LAN switch and the connected device can continue to work. This increases the fault tolerance of the network infrastructure and protection is performed by interrupting the network connection due to a failure of one power source of the network device.
Easy and flexible installation
Installing a series of DPS does not require any changes in the settings of LAN switch. DPS-600 is equipped with an internal power supply and can be connected to any AC power source from 85 to 264 volts AC with a frequency of 47 to 63 Hz with a standard power cord.
Power supplies that are installed in the rack
DPS-600 is a power supply, plugged into a standard 19-inch rack, and is designed to increase flexibility in the operation of the equipment that supports PoE (Power over Ethernet).
Genel Özellikler
Fiziksel Özellikler
Output power
500 W
The input voltage range
From 85 to 264 VAC
The range of the input line voltage
47 Hz to 63 Hz
Max. input current
10 A at 115 VAC
5 A for 230 V AC
Max. starting current
30 A 115 V AC
60 A at 230 VAC
Performance
75%
The physical parameters
Operating temperature
0 to 50 C
Storage temperature
-40 To 85 C
Operating Humidity
From 10% to 90% relative humidity
The MTBF
598,664 hours
Measurements
441 mm x 165 mm x 44 mm
Weight
3.51 kg
Çözümler
Sipariş Bilgisi
Görseller
DPS-600/A
Front view
Back view
İndir
Destek Merkezi
