Hızlı Arama
Ürün Özellikleri:
Redundant Power Supply, 589 Watt
Genel Özellikler:
Fiziksel Özellikler
Output power
589 W
The input voltage range
From 90 to 264 VAC
The range of the input line voltage
47 Hz to 63 Hz
Max. input current
7.5 A at 115 VAC
3.7 A at 230 VAC
Max. starting current
30 A 115 V AC
30 A at 230 VAC
Performance
80%
The physical parameters
Operating temperature
From 0 to 65 C
Storage temperature
-40 To 85 C
Operating Humidity
From 5% to 95% relative humidity
The MTBF
624,961 hours
Measurements
441 mm x 199.4 mm x 44 mm
Weight
3.65 kg
Ürünler | Destek  | Haberler  | Hakkında |
