DGS-1500-52EOL EOS
48 port 10/100/1000Base-T + 4 100/1000Base-T SFP port ve güç tasarrufu fonksiyonlu Web SmartPro Anahtar
Nereden Alınır
Tanımlama
A series of switches D-Link DGS-1500 SmartPro designed for SMB, requiring functions such as static routing and management on a separate IP-address (Virtual Stacking). The series combines the functions of advanced management and security, which are similar to the same features of a managed switch, but less complex. The switches support technology D-Link Green ™ 3.0, providing significant energy savings.
In addition, ports 10/100/1000 Mb / s Switch DGS-1500-28P technology support PoE, providing ease of use and function of green, such as PoE-enabled time-based, which allows off the power at the port at a predetermined time. It is compatible with standard 802.3af and 802.3at, DGS-1500-28P is capable of providing PoE power up to 30 watts on all ports with installed DPS-700. DPS-700 allows you to have a switch DGS-1500-28P redundancy in the system and provides 1 +1 PoE power up to 740 watts. By itself, DGS-1500-28P has a power handling 370 watts, so it can provide up to 15.4W on all ports simultaneously.Control functions include SNMP, management of a Web-based interface, SmartConsole Utility, and Compact Command Lines. The series also supports features such as ACL filtering and D-Link Safeguard Engine. Switches DGS-1500-20 and DGS-1500-28 are in the fan-less design. The fanless design allows them to emit less noise than standard switches, extending the useful life of equipment and ensuring its compliance with the terms of office.
Technology D-Link Green ™ V3.0
D-Link is a leader in the development of innovative energy-saving technology that does not sacrifice operational performance or functionality of the device. Switches DGS-1500 Series support the technology D-Link Green ™ 3.0, allowing the use of energy-saving mode, the technology smart fan, as well as reduce the heat and the length of the cable. Energy saving features allow you to set a schedule according to which the LEDs and ports will be turned off when not in use, and according to which the switch will go into sleep mode. The technology provides an automatic change in the level of the transmitted signal depending on the length of cables to be connected (20 meters).
Switches DGS-1500-28P and DGS-1500-52 are equipped with built-in fan with automatic speed control, providing continuous, reliable and environmentally friendly operation of the switch. Using the temperature sensors that monitor the change in temperature, the fans can respond appropriately and use different speeds for different temperatures.
Advanced Features
Switches DGS-1500 Series supports advanced features such as Virtual Stacking and static routing. Virtual Stacking reduces the number of IP-addresses needed for use in the network by combining up to 32 logical devices in one, with one IP-address.This simplifies network management for small workgroups and allows you to add switches to the existing architecture without additional cabling. In a static IP-routing routes are manually entered into the routing table. Switches DGS-1500 Series supports static routing, which creates an opportunity for communication between different groups of people in different segments of the VLAN in the network. Switches can fully control the routing between the VLAN, providing a faster and more efficient network.Since the switches can manage internal routing, processing only the external routing network traffic, you can instruct the router.
Extensive Layer 2
Switches DGS-1500 series supports Layer 2 features including IGMP Snooping, Port Mirroring, Spanning Tree and Link Layer Discovery Protocol (LLDP). IEEE 802.3x Flow Control allows servers to directly connect the switch for fast, reliable data transfer. By keeping at 2000 Mb / s in full duplex mode, the switches support high speed performance for servers with minimum data transfer loss. The switches support function and Cable Diagnostics function Loopback Detection. Loopback Detection is used to determine the loop and automatically disable the port or VLAN, in which a loop was detected. Cable Diagnostics is designed to determine the quality of the copper cables and the type of cable error.
VLAN and bandwidth control
Switches DGS-1500 Series supports Auto Surveillance VLAN (ASV), and Auto Voice VLAN, and is an ideal solution for deploying VoIP and video surveillance. Auto Surveillance VLAN - this is a new, industry-leading technology, built-in switches Smart D-Link. This technology combines data and video transmission through a single switch SmartPro, thus reducing the cost of facilities and equipment. ASV also ensures high-quality video in real time and control without compromising the transmission of conventional network data. The automatic determination of the connected equipment allows you to place VoIP "voice" traffic to a dedicated VLAN. Due to higher priority and individual VLAN, this feature guarantees the quality and secure transfer of VoIP-traffic. In addition, DSCP marks packets with Ethernet-purpose network traffic of different services. In addition, the function of bandwidth management allows network administrators can reserve bandwidth for a variety of applications that require high bandwidth or might have high priority.
Network Security
Function D-Link Safeguard Engine protect the switches against traffic flooding caused by virus attacks. Authentication is based on the 802.1X port allows you to use an external RADIUS server to authenticate users. In addition, the function list contains a complete access control (ACL) feature enhances network security and helps to protect your network by filtering traffic from unauthorized MAC-addresses, or IP-addresses.
Switches DGS-1500 Series support the prevention of attacks ARP Spoofing, protecting against attacks an Ethernet, which can cause a change in traffic or delay by sending false ARP-messages. To prevent ARP Spoofing attacks, the switch uses the Packet Control ACLs to block packets containing false ARP-posts. For added security, the function of DHCP Server Screening, prohibiting access to unauthorized DHCP-servers.
Management flexibility
Using Web-based Management Series Switches DGS-1500 and SmartConsole utility allows network administrators to remotely manage the port level. The SmartConsole supports automatic detection and display switches the D-Link Web Smart, belonging to the same network segment L2. Web-based interface provides access to the switch from anywhere on the network without the need to enter the IP-address or a subnet mask that allows you to perform a basic installation and configuration of devices found, including changing the password and update the software. Switches DGS-1500 series also support the program D-View 6.0 and Command Line Interface (CLI) through Telnet. D-View 6.0 is a network management system that lets you control the most important parameters such as performance, reliability, flexibility and security. Manage the command-line interface (CLI) is possible via Telnet. This makes it easy to configure basic settings, passwords, configuration files and software
Genel Özellikler
Fiziksel Özellikler
Standards and function ports
• IEEE 802.3 10BASE-T Ethernet (copper twisted-pair)
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper twisted-pair)
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (copper twisted-pair)
• Auto-negotiation
• Supports IEEE 802.3x flow control for full-duplex mode
Number of Ports
48-port 10/100/1000 Mbit / s, 4-speed ports SFP
Network kabeliUTP category
• 5, 5e (max. 100 m)
• EIA/TIA-568 100-ohm STP (max. 100 m)
Full / half duplex
• Full / half duplex for 10/100 Mbit / s
• Full duplex for Gigabit speed
Media Interface
Auto-detect MDI / MDI-X
Performance
Throughput of the switch
104 Gbit / s
Switching Method
Store-and-forward
Table MAC-addresses
16 K entries per device
Study of MAC-addresses
• Up to 256 static MAC-address records
• Enable / disable auto-learning of MAC-addresses
The maximum packet forwarding rate of 64 bytes
77.4 Mpps
Packet buffer memory
1 MB on the device
Software
D-Link Single IP Management
• Virtual Stacking / Clustering of up to 32 devices
Layer 2 Features
• Table of MAC-addresses: 16K entries
• Flow Control
  - 802.3x Flow Control
  - HOL blocking prevention
• IGMP Snooping
  - IGMP v1/v2 Snooping
  - Supports up to 256 IGMP-groups
  - Support for up to 64 static multicast groups
  - IGMP on VLAN
  - Supports IGMP Snooping Querier
• Spanning Tree Protocol
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP 3
• Loopback Detection
• 802.3ad Link Aggregation: max. the number of groups on the device 26/8 ports per group
• Port Mirroring
  - One-to-One
  - Many-to-One
  - Supports Mirroring for Tx / Rx / Both
• Cable Diagnostics
• Customizable Interface MDI / MDIX
• Filtering Multicast
  - Redirect all unregistered groups
  - Filters all unregistered groups
• Support for Jumbo-frames to 10000bayt
• LLDP
• LLDP-MED
VLAN
• 802.1Q
• Group VLAN
  - Max. 4K static VLAN groups
  - Max. VID 4094
• GVRP VLAN up to 256 dynamic VLAN
• Asymmetric VLAN
• Auto Voice VLAN
  - Max. 10 user defined OUI
  - Max. 8 default specific OUI
• Auto Surveillance VLAN
QoS (Quality of Service)
• 802.1p Quality of Service
• 4 queues per port
• Processing Queues
  - Strict
  - Weighted Round Robin (WRR)
• CoS based
  - 802.1p Priority Queues
  - DSCP
  - ToS 3
  - IPv6 Traffic Class 3
  - IPv6 flow label 3
  - TCP / UDP port 3
• Bandwidth Management
  - Port-based (Ingress / Egress, with a step up to 10/100/1000 64 Kb / s)
Layer 3 Features
• ARP
  - 64 static ARP
  - Supports Gratuitous ARP
• IPv6 Neighbor Discovery (ND) 3
• IP-interface: 4 Interfaces
Layer 3 routing
• Default Routing
• Static Routing
  - Max. the number of entries of static IPv4 routes 32
  - Max. IPv4 hosts a number of routes 128
  - Max. the number of entries static IPv6 routes 16 3
  - Max. The number of routes IPv6 hosts 64 3
Access Control Lists (ACL)
• DGS-1500-52:
  - 50 profiles (maximum)
  - Max. 450 Access Rules
  - Each rule can be bound to a specific port
• ACL on the basis of
  - MAC-addresses
  - IPv4-address (ICMP / IGMP / TCP / UDP)
  - VLAN ID
  - 802.1p
  - Type Ethernet DSCP
Safety
• Access Control 802.1X port-based
• Port Security
  - Supports up to 64 MAC-addresses per port
• Management of broadcast / multicast / unicast storm
• D-Link Safeguard Engine
• The DHCP Server Screening
• Binding IP-MAC-Port 3
  - Supports 512 address binding entries
  - ARP mode
  - Treatment of ACL
  - Support for DHCP Snooping
• Prevent ARP Spoofing Attacks
  - Max. 64 records
• Segmenting traffic
• SSL
  - Support v1/v2/v3
  - Support for IPv6 3
AAA
• 802.1X Authentication
  - Support for local / RADIUS database
  - Support for the port-based
  - Support for EAP, OTP, TLS, TTLS, PEAP
• RADIUS-server IPv6 3
MIB
• 1213 MIB II
• 1493 Bridge MIB
• 1907 SNMP v2 MIB
• 1215 Trap Convention MIB
• 2233 Interface Group MIB
• D-Link Private MIB
• LLDP MIB
• Power-Ethernet MIB 4
Compliance with RFC
• RFC 783 TFTP
• RFC 854 Telnet-server
• RFC 951 BootP / DHCP-Client
• RFC 1157 SNMP v1, v2, v3
• RFC 1191 Path MTU Discovery
• RFC 1213 MIB II
• RFC 1350 TFTP
• RFC 1493 Bridge MIB
• RFC 1769 SNTP
• RFC 1542 BootP / DHCP-Client
• RFC 1901 SNMP v1, v2, v3
• RFC 1907 SNMP v2 MIB
• RFC 1908 SNMP v1, v2, v3
• RFC 2068 FCS
• RFC 2131 BootP / DHCP-Client
• RFC 2138 RADIUS Authentication
• RFC 2139 RADIUS Authentication
• RFC 2233 Interface Group MIB
• RFC 2246 SSL
• RFC 2475
• RFC 2570 SNMP v1, v2, v3
• RFC 2575 SNMP v1, v2, v3
• RFC 2598 CoS
• RFC 2616 FCS
• RFC 2618 RADIUS Authentication
• RFC 2819 RMON v1
• RFC 2865 RADIUS Authentication
• RFC 3164 System Log
• RFC 3195 System Log
• RFC 3411-17 SNMP
• RFC 3621 Power Ethernet MIB
OAM
• Cable Diagnostics
• Return to factory settings
Management
• Web-based GUI
• Single IP Management
• Compact CLI through Telnet
• Telnet-server
• TFTP-client
• SNMP
 - Support v1/v2/v3
• SNMP Trap
• Trap for SmartConsole Utility
• The system log
 - Max. 500 log entries
• BootP / DHCP-Client
• SNTP
• ICMP v6 3
• IPv4/IPv6 Dual Stack 3
• Automatic configuration of DHCP
• Debug
• Setting the time
  - SNTP
• RMONv1
• A trusted host
• User Account
• Upload / download configuration file
• Backup / Update Software
• Smart Wizard
Technology Green ™ V3.0
• Energy savings:
  - In various states of connection
  - Depending on the length of the cable
  - When you turn off the indicators
  - In standby ports
  - In sleep mode, the system
Fiziksel Özellikler
Power Input
100-240 VAC, 50/60 Hz internal universal power supply
The maximum power consumption
43.5 W
Power consumption in standby mode
• 20,68 In W/100
• 22,05 In Vt/240
Number of fans
2 smart fan
Acoustics
47.1 dB (max.)
Heat release
148,42 BTU / hr
Operating temperature
-5 ° to 50 ° C
Storage temperature
-20 ° to 70 ° C
Operating Humidity
From 0% to 95% non-condensing
Humidity
Dimensions (L x W x H)
440 mm x 250 mm x 44 mm (size for installation in a standard 19-inch rack, the height of 1U)
Weight
4.1 kg
Diagnostic Lights
• Power (per device)
• Fan (per device)
• Link / Activity / Speed ​​(per port 10/100/1000 Mbit / s)
• Link / Activity / Speed ​​(Per Port SFP)
Certifications
• FCC Class A
• CE Class A
• ICES-003
• VCCI Class A
• C-Tick
• BSMI
MTBF
201.517 h
Safety
cUL, LVD
Çözümler
Sipariş Bilgisi
Görseller
DGS-1500-52/A
Back view
Front view
İndir
Destek Merkezi
