DES-3810-52EOL EOS
Managed switch with 48-port 10/100 Mbit / s, 2 x 1000 SFP, 2 combo ports 1000BASE-T/SFP and a power saving function
Nereden Alınır
Tanımlama
Switches tertiary DES-3810 series, belonging to the family of D-Link xStack, provide high performance, high functionality, including the level 3. Switches are equipped with 24 and 48 ports. The switch DES-3810-28 is equipped with a 24-port 10/100 Mbit / s Fast Ethernet and 4 combo ports 1000Base-T/SFP Gigabit Ethernet. The switch DES-3810-52 is equipped with a 48-port 10/100 Mbit / s Fast Ethernet, 2 x 1000 and 2 SFP combo ports 1000Base-T/SFP. Fast Ethernet ports provide connections to other switches LAN. Combo ports provide flexible connectivity to the network backbone and core switches.
Standard and Advanced software version
Series Switch DES-3810 supports two different versions of the software - standard version (SI) and the extended version (EI).The standard version supports advanced networking features to scale campus or enterprise, including advanced settings Quality of Service (QoS), traffic shaping, tunneling 802.1Q (Q-in-Q), routing / multicast IPv4, Ethernet OAM and various security functions. Extended version of the software supports the routing of IPv6, the protocol BGP (Border Gateway Protocol) protocol and MPLS (Multi Protocol Label Switching), used in next-generation networks with IPv6 support for applications or VPN / triple play networks in Metro Ethernet. In addition, the extended version also supports Switch Resource Management (SRM). This feature gives users the ability to optimize the allocation of resources for a variety of switch network tasks.
Enhanced network reliability
Switch DES-3810 series are designed for business networking / campus, as well as for users who require a high level of network security and maximum reliability. Both switch DES-3810-28 DES-3810-52 supports external redundant power supply, providing thus a continuous operation. The switches also support functions 802.1D Spanning Tree (STP), 802.1w Rapid Spanning Tree (RSTP) and 802.1s Multiple Spanning Tree (MSTP), Loopback Detection (LBD), and Broadcast Storm Control, that enhance network resilience. Function G.8032 Ethernet Ring Protection Switching (ERPS) provides the switching time less than 50ms. To provide load balancing and backup data using multiple switches / server application, DES-3810 series supports dynamic 802.3ad Link Aggregation Port Trunking.
Advanced Security Features
Switch DES-3810 series supports the latest security features such as multi-level access control lists (ACL), Storm Control, and IP-MAC-Port Binding to the DHCP Snooping. Function IP-MAC-Port Binding binds the IP-addresses of the source to the associated MAC address for a specific port number to increase access security. Thanks to the DHCP Snooping, the switch automatically detects pairs of IP / MAC-addresses, DHCP-tracking packets and saving them in a "white list" IMPB. In addition, the function of D-Link Safeguard Engine identifies and prioritizes packets destined for processing CPU, in order to prevent network attacks and protect the control interface of the switch.
Identity Driven Network Policies
Switch DES-3810 Series supports authentication mechanisms such as 802.1X, Access Control Web-based interface (WAC) and Access Control MAC-based, easy deployment. After authentication, individual policies such as VLAN membership, QoS policies and rules ACL, can be assigned to each host. The switch also supports Microsoft ® NAP (Network Access Protection).NAP technology allows users to restrict access to a network of computers that do not meet the safety requirements.
Traffic Management for Triple Play Services
DES-3810 series provides a set of functions of multi-level QoS / CoS, ensure that critical network services such as VoIP, video conferencing, IPTV and IP-surveillance are served with proper priority. Functions Three Color Marker traffic restriction and provide guaranteed bandwidth for data services when the network is busy. With the support of multicast L2/L3, Switch DES-3810 implements the IPTV-processing applications that require a growing demand in the market. IGMP / MLD Snooping allows host-based connection of multiple clients multicast group to one interface, the function of ISM VLAN sends Multicast streams in a special Multicast VLAN to save bandwidth and improve network security. ISM VLAN profiles allow users to assign / change the preset settings on ports multicast subscribers quickly and easily.
Efficient network management
For the implementation of the Agreement on the level of quality of service SLA (Service Level Agreement), service providers must reduce the mean time to repair the machine is working (Mean Time to Repair (MTTR)) and increase the availability of services. Ethernet OAM features contributes to the solution of these problems, and allows service providers to ensure the best quality of services provided. Switch DES-3810 series supports standardized OAM, including IEEE 802.3ah, IEEE802.1ag and ITU-T Y.1731. Connectivity Fault Management (CFM) provides the functions of monitoring, and troubleshooting networks Ethernet, allowing you to check connectivity, isolate network issues, and identify customers affected by network issues.
High-performance routing
Series Switch DES-3810 supports three routing functions at the level corresponding to the data transmission medium. For small networks, routing between VLAN, static routing and protocol RIP (Routing Information Protocol) provides an easy way to configure Layer 3 routing. In medium and large enterprises supported protocols Open Shortest Path First (OSPF) and Border Gateway Protocol Version 4 (BGPv4) to ensure the best routing. Policy-based routing (PBR) allows administrators to control the direction of the dynamic routing for load balancing and security.
Multicast Layer 3 Switch DES-3810 supports the PIM (Protocol Independent Multicast), including PIM Sparse Mode (PIM-SM), PIM Dense Mode (PIM-DM), PIM Source-Specific Multicast (PIM-SSM) and PIM Sparse -Dense mode.
Interaction with both IPv4 and IPv6
Switch DES-3810 series are fully compatible with the next-generation networks based on the protocol IPv6. They support remote management of IPv6 through telnet, HTTP, or SNMP. The switch supports the dynamic IPv6-routing, such as RIPng and OSPFv3. In addition, this device supports IPv4/v6 dual stack and tunneling IPv6, allowing the switch DES-3810 to act as a bridge between IPv4 and IPv6.
To ensure the safety of IPv6-network series switches DES-3810 supports features IPv6 ACL, IPv6 RADIUS, DHCPv6 Snooping and Neighbor Discovery (ND) Snooping to protect the network from non IPv6-customers.
VPN-tunneling service for businesses
Series Switch DES-3810 supports many advanced features such as VLAN translation, Selective Q-in-Q and Virtual Private Wire Service (VPWS), which allow users to organize VPN-tunnels Layer 2 data transmission backbone MPLS. The function L2 Protocol Tunneling (L2PT) provides corporate clients transparency level 2 in the provider network, significantly reducing costs by centralizing network management.
Genel Özellikler
Interface
• 48-port 10/100BASE-T
• 2-port SFP 1000
• 2 combo port 10/100/1000 BASE-T / 100/1000 SFP
Optional redundant power supply
DPS-200
The console port
RJ-45
Managing Out-of-band
RJ-45
Performance
• Switch fabric: 17.6 Gbit / s
• The speed of packet forwarding: 13,1 Mpps
• CPU: 800 MHz
• Packet Buffer: 3 MB
• Flash-Memory: 32 MB
• DRAM: 256 MB
Software
The standard version of the software functions
Stacking
• Physical Stacking 2
  - Bandwidth for stacking up to 1 Gbit / s
  - Up to 8 units in a stack
• Virtual Stacking:
  - Technology D-Link Single IP Management (SIM)
  - Up to 32 devices in a virtual stack
Layer 2 Features
• Table of MAC-addresses: 16K
• Flow Control
  - HOL Blocking Prevention
  - 802.3x Flow Control
• Jumbo-frame up to 10,240 bytes
• Spanning Tree
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
  - Filtering BDPU
  - Root Restriction
• The Loopback Detection
• Ethernet Ring Protection Switching (ERPS)
• 802.3ad Link Aggregation
  - Max. 14 groups per device / 8 ports per group
• Port Mirroring
  - One-to-One
  - Many-to-One
  - Based on the flow
  - RSPAN
• Layer 2 Tunneling Protocol
Multicast Layer 2
• IGMP Snooping
  - IGMP v1/v2/v3 Snooping
  - Support for 1024 IGMP groups
  - Fast Leave on the basis of port / flow
• MLD Snooping
  - MLD v1/v2 Snooping
  - Supports up to 1024 groups
• IGMP / MLD Proxy Reporting
VLAN
• Group VLAN
  - Max. 4K VLAN groups
• GVRP
  - Support for 4K dynamic VLAN-groups
• 802.1Q Tagged VLAN
• VLAN port-based
• 802.1v Protocol VLAN
• Double VLAN (Q-in-Q)
• Private VLAN
Layer 3 Features
• Max. 256 IPv4 interfaces 32 IPv6 Interface
• ARP Proxy
• Loopback Interface
• IGMP / MLD Proxy
• VRRP
• Tunneling IPv6
  - Static
  - ISATAP
  - GRE
  - 6to4
Layer 3 routing
• Up to 7286 IPv4 external routes
• Up to 1821 IPv6 external routes
• Up to 3575 IPv4 external routes
• Up to 256 static routing entries for IPv4, 128 entries for IPv6
• Policy-based routing
• Route Redistribution
• RIP v1/v2
• OSPF
  - Support for OSPF v2
  - Passive OSPF interface
  - Stub / NSSA Area
  - OSPF Equal Cost Route
Multicast Layer 3
• Up to 1024 IPv4 multicast groups
• Up to 256 IPv6 multicast groups
• IGMP filtering
  - Up to 60 IGMP-filtering profiles, 128 ranges of addresses to profile
  - IGMP v1, v2, v3
  - DVMPR v3
  - PIM-DM
  - PIM-SM
  - PIM-SSM
  - PIM Sparse-Dense Mode
Quality of service (QoS)
• IEEE 802.1p
• DSCP
• 8 queues per port
• Queue management
  - Strict Priority
  - Smoothed Deficit Weighted Round Robin (SDWRR)
  - Strict + SDWRR
• CoS based
  - The switch port
  - VLAN ID
  - 802.1p Priority Queues
  - MAC-address
  - IPv4/IPv6-adresa
  - DSCP
  - The type of protocol
  - IPv6-class traffic
  - IPv6 flow label
  - TCP / UDP-port
  - The contents of the package, the user-defined
• Support for the following streams
  - 802.1p Priority Tagging
  - Adding a priority tag TOS / DSCP
  - Bandwidth Management
  - Statistics of flow
• Three Color Marker
  - TrTCM
  - SrTCM
• Bandwidth Management
  - Port-based (Ingress / Egress, min. Pitch of up to 64 kbit / s)
  - Flow-based (Ingress / Egress, min. Step up to 1 kbit / s)
  - According to the outgoing queue (at least step up to 64 kbit / s)
• QoS based on the time
Access Control Lists (ACL)
• Up to 1,024 access rules
• RMON v2:
  - Support for groups 1, 2, 3, 9
• ACL-based
  - 802.1p priority
  - VLAN ID
  - MAC-address
  - Ether Type
  - IPv4/IPv6-adresa
  - DSCP
  - Rooms are TCP / UDP-port
  - IPv6 flow label
• Statistics ACL
• ACL on the basis of the time
• Filtering CPU interface
• SSH v2
• SSL v1/v2/v3
• Port Security
• Control of broadcast / много-адресных/одноадресных storms
• Traffic Segmentation
• IP-MAC-Port Binding (IPv4/IPv6)
  - Checking the ARP-Packet
  - Check the IP-packet
  - DHCP Snooping
  - IPv6 ND Snooping
  - Up to 500 entries per device
• D-Link Safeguard Engine
• Filtering NetBIOS / NEtBEUI
• DHCP Server Screening
• Protection against attacks BDPU
• Prevention of ARP Spooofing
• L3 Control Packet Filtering
AAA
• 802.1X
  - Access control based on port
  - Control access to host-based
  - Authentication Database Failover
  - Identity-Driven Policy (VLAN, ACL, or QoS) assignment
• Control access to Web-based (WAC)
  - Based Access Control Host
  - Dynamic VLAN Assignment
  - Identity-Driven Policy (VLAN, ACL or QoS) assignment
• Access Control MAC-based (MAC)
• Access control based on the Japanese Web-based interface (JWAC host-based)
• Compound Authentication
• Guest VLAN
• Microsoft ® NAP
  - Support for 802.1X NAP
  - Support for DHCP NAP
• RADIUS
• TACACS
• XTACACS
• TACACS +
• Record keeping RADIUS
• Accounts with three entries privileges
• A trusted host
Performing Operations, Administration and Management (OAM)
• Loopback Diagnostic
• Diagnostic cable
• 803.2ah Ethernet Link OAM
• D-Link Unidirectional Link Detection (DULD)
• Managing the broadcast / много-адресным/одноадресным storm
• Dying Gasp
• 802.1ag Fault Management Connection (CFM)
• ITU-T Y.1731
DDM (Digital Diagnostics Monitoring)
Yes
Green Functions
• Energy savings:
  - In various states of connection 3
  - Depending on the length of the cable 3
  - When you turn off the indicators
  - Standby ports
  - In sleep mode, the system
Management
• Managing a Web-based interface (Support Ipv4/IPv6)
• Command Line Interface CLI
• Server Telnet (Support IPv4/IPv6)
• Client Telnet (Support IPv4/IPv6)
• Client TFTP (Support IPv4/IPv6)
• Client FTP (Support IPv4/IPv6)
• Remote Copy Protocol (RCP)
• Adding a tag PPPoE Circuit-ID
• ZModem
• SNMP v1/v2c/v3
  - SNMP over IPv6
• SNMP Traps
• System Log
• SMTP
• RMON v1
  - Support groups 1,2,3,9
• RMON v2
  - Support group ProbeConfig
• sFlow
• LLDP
• BootP / DHCP-Client
• Auto-configuration DHCP
• DHCP Relay (Support IPv4/IPv6)
• DHCP Relay Option 60, 61, 82
• DHCP-server
• Flash File System
• Support for multiple copies of the software (Multiple Images)
• Support for multiple copies of the configurations (Multiple Configurations)
• Monitoring the CPU
• DNS Relay
• SNTP
• Password Recovery Recovery
• Password Encryption
• Microsoft ® NLB (Network Load Balancing)
• Ping (Support IPv4/IPv6)
• Traceroute (Support IPv4/IPv6)
MIB
• RFC1065, 1066, 1155, 1156, 2578 MIB structure
• RFC1212 MIB definitions
• RFC1213 MIB II
• RFC1493 Bridge MIB
• RFC1157, 2571-2576 SNMP MIB
• RFC1901-1908, 1442, 2578 SNMPv2 MIB
• RFC1757, 2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC2674, 4363 802.1p MIB
• RFC2233, 2863 Interface Group MIB
• RFC2925 Ping & Traceroute MIB
• D-Link Private MIB
• RFC2787 VRRP MIB
• RFC1724 RIPv2 MIB
• RFC1850 OSPF MIB
• RFC2932 IPv4 Multicast Routing MIB
• RFC2934 IP Forwarding Table MIB
Compliance with standards
• RFC768 UDP
• RFC791 IP
• RFC792 ICMPv4
• RFC2463, 4443 ICMPv6
• RFC793 TCP
• RFC826 ARP
• RFC1321, 2284, 2865, 2716, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC2571 SNMP Framework
• RFC2572 SNMP Message Processing and Dispatching
• RFC2573 SNMP Applications
• RFC2574 User-Based Security Model for SNMPv3
• RFC1981 Path MTU Discovery for IPv6
• RFC2460 IPv6
• RFC2461, 4861 Neighbor Discovery for IPv6
• RFC2462, 4862 IPv6 Stateless Address Auto-Configuration
• RFC2464 IPv6 over Ethernet and defnition RFC2021 RMON v2
• RFC3513 IPv6 Addressing Architecture
• RFC2893 IPv4/IPv6 dual stack function
• IPv6 Ready Logo phase 2 router mode
• RFC3056 IPv6 Tunneling
• RFC2328, 3101 OSPF
• RFC1112, 2326, 3376 IGMP
• RFC3973 PIM-DM
• RFC4601 PIM-SM
• RFC3569 PIM-SSM
• RFC1112, 2236, 3376, 4605 IGMP Proxy
• RFC4541 Proxy Reporting
• RFC4363 802.1v
• RFC1027 ARP Proxy
• RFC2338 VRRP
• RFC1058, 1388, 1723, 2453 RIP
• RFC2475 Priority Queue Mapping
• RFC2475, 2598 Class of Service (CoS)
• RFC2597, 2598 QoS Flow Actions
• RFC2697, 2698 Three Color Marker
• RFC2246 SSL
• RFC3580 802.1X
• RFC2866 RADIUS Accounting
• RFC2138, 2139, 2865, 2618 RADIUS Auth for Mgmt Access
• RFC1492 TACACS + Auth for Mgmt Access
• RFC2068, 2616 Web-based GUI
• RFC854 Telnet Server
• RFC1519 CIDR
• RFC 2474, 3168, 3260 Definition of the DS Field in the IPv4 and IPv6 Headers
• RFC783, 1350 TFTP Client
• RFC1157, 1901, 1908, 2570, 2574, 2575 SNMP
• RFC3164 System Log
• RFC2819 RMON v1
• RFC3176 sFlow
• RFC951, 1542, 2131, 3046 BOOTP / DHCP Client
• RFC2131 DHCP Server
• RFC1769 Time Setting
• RFC2821 SMTP
• ITU-T Y.1731
• ITU-T G.8032
• IPv6 Ready Logo Phase 2 router mode
Functions of an enhanced version of the software
• Advanced Layer 3 routing
   - BGP v4 2
• Dynamic routing IPv6
   - RIPng
   - OSPFv3 2
• MPLS
   - LDP
   - MPLS Label Management
   - VPWS
• Management
  - Switch Resource Management (SRM)
Fiziksel Özellikler
MTBF (Hours)
375.189 h
Noise level
<33 C: 32.6 dB
> 33 C: 42.3 dB
Heat release
123,78 BTU / hr
Power Input
100-240 VAC, 50-60 Hz, internal universal power supply
Max. power consumption
38.8 W
Measurements
441 x 309 x 44 mm
Weight
4.1 kg
Fans
1 fan Smart
(Low speed by default)
Operating temperature
0 to 50 C
Storage temperature
-40 To 70 C
Operating Humidity
From 5% to 90% non-condensing
Storage humidity
From 5% to 90% RH
Emission (EMI)
FCC Class A, CE, C-Tick, VCCI
Safety
cUL, CB
Certifications
2 Available in future releases
3 For the Gigabit
Çözümler
Sipariş Bilgisi
Görseller
DES-3810-52
Front view
Back view
İndir
Destek Merkezi
