Hızlı Arama
Ürün Özellikleri:
Passive 10G CX4 cable for direct connection to a length of 50 cm
Genel Özellikler:
Fiziksel Özellikler
Connector type
One screw fastening / One fixture with latch
Cable Length
50 cm
AWG wire size
28 AWG
The ability to connect
Cable to connect the Series Switch DGS-3120 media converter with DMC-805X (recommended)
The physical parameters
Voltage
30 VAC
Current
0.5 A
Operating temperature
-40 To 85 C
Certifications
• IEEE802.3ak 10GBASE-CX4
• SFF-8470
• EIA-364
• UL 94
Ürünler | Destek  | Haberler  | Hakkında |
