DES-1008A/E1EOL EOS
8-Port 10/100 Switch
Nereden Alınır
Tanımlama
The DES-1008A 8-Port 10/100 Switch is an 8-port 10/100Mbps Fast Ethernet switch that allows you to quickly set up a wired network. Connect the DES-1008A to multiple computers together to share files and folders, or connect it to a router to share an Internet connection.
Auto-sensing 10/100 Ports
The D-Link DES-1008A 8-Port 10/100 Switch uses auto-sensing 10/100Mbps ports, allowing a small workgroup to flexibly connect to Ethernet and Fast Ethernet devices to create an integrated network. These ports detect the network speed and auto-negotiate between 10BASE-T and 100BASE-TX, as well as full and half-duplex, allowing you to get the maximum speed possible for each device connected to your network.
Auto MDI/MDIX CrossOver
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
Flow Control for Secure Transmission
802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full. This gives you a more reliable connection for all of your connected devices, ensuring smooth and uninterrupted network connection.
Genel Özellikler
Device Interfaces
• Eight 10/100 Fast Ethernet LAN ports
Functionality
Advanced Features
• Green Ethernet
• 1.6Gbps switching fabric
• Auto MDI/MDIX crossover for all ports
• Secure store-and-forward switching scheme
• Compliance with IEEE802.3az EEE power saving
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x Flow Control
• Plug-and-play installation
• RoHS compliant
• Supports 2048-byte Jumbo Frames
Protocol
• CSMA/CD
Data Transfer Rates
Ethernet:
• 10Mbps (half duplex)
• 20Mbps (full duplex)
Fast Ethernet:
• 100Mbps (half duplex)
• 200Mbps (full duplex)
Transmission Method
• Store-and-forward
MAC Address Table
• 2K
MAC Address Learning
• Automatic Update
Packet Filtering/Forwarding Rates
• Ethernet: 14,880pps per port
• Fast Ethernet: 148,800pps per port
RAM Buffer
• 96KB per device
Media Interface Exchange
• Auto MDI/MDIX adjustment for all ports
Fiziksel Özellikler
LED Indicators
• Per port: Link/Activity
• Per device: Power
Dimensions
• 141.5 x 78.5 x 23.8mm
Power
• 5V/0.55A Power Adapter
Heat Dissipation
• Power On (Standby): AC input: 2.0472Btu/h
• Maximum: AC input: 7.47228Btu/h
Power Consumption
• Power On (Standby): DC input: 0.36 watts, AC input: 0.6 watts
• Maximum: DC input: 1.78 watts, AC input: 2.19 watts
• Link Up: EEE mode: DC input: 0.75 watts AC input: 1.1 watts
Temperature
• Operating: 0 to 40°C
• Storage: -10 to 70°C
Humidity
• Storage: 5% to 90% non-condensing
MTBF
• 2,137,319 hours
Certifications
• CE Class B
• FCC Class B
• cUL
• CB
• VCCI Class B
Çözümler
Sipariş Bilgisi
DES-1008A/E1  8-Port 10/100 Switch
Görseller
DES-1008A/E1
View from the right
Back view
Front view
Front view
İndir
Destek Merkezi
