Hızlı Arama
Ürün Özellikleri:
16 10/100/1000 Base-T portu ile Dahili Güç Kaynaklı Gigabit Ethernet Layer 2 Yönetilemeyen Anahtar
EOL EOS
Tanımlama:
Green Ethernet technology
Gigabit Switch D-Link DGS-1016D 16-Port is a new series of devices for networking SOHO / SMB. The switch supports Green Ethernet, IEEE802.3az EEE and EEE + and saving energy and increasing the life of the product without affecting the performance and functional characteristics. Thanks to the support IEEE802.3az EEE reduced energy consumption during low utilization. EEE + similar IEEE802.3az EEE. However, unlike EEE may use EEE + matter support device connected to the switch, EEE or not. The use of recyclable packaging reduces waste.
Saving energy
Thanks to the support of technology D-Link Green Ethernet Gigabit Switch with 16 ports provides automatic saving of electricity in several ways. If there is no connection to the ports, the power turns off automatically, which can significantly reduce the consumption of electricity by ports that do not have a physical connection, or ports connected to disconnected devices. In addition, the switch determines the length of cable connected and selects the appropriate diet, without compromising network performance.
Environmentally friendly
Gigabit Ethernet switch ports 16 is designed with consideration for the protection of the environment. The switch RoHS compliant restricting the use of hazardous substances. The use of recyclable packaging significantly reduces the amount of waste in accordance with directive WEEE.
Ürünler | Destek  | Haberler  | Hakkında |
