DES-1005A/E2EOL EOS
5-port 10/100BASE-T Yönetilemeyen Anahtar
Tanımlama
Switch DES-1005A 5-port 10/100 Mbit / s allows you to quickly create high-speed, reliable and efficient wired network at home or in the office. Unmanaged Switch DES-1005A is designed to increase the productivity of small working groups, while at the same time a high level of flexibility. This device allows users to simply plug any port to a 10/100 Mbit / s to increase bandwidth, improve performance and quality of work with a lot of traffic. DES-1005A Connect to multiple computers to provide shared access to files and folders, or connect it to a router to share an Internet connection.
High Speed Networking
Switch DES-1005A is equipped with easily accessible ports, 10/100 Mbit / s auto-sensing and indicators for each port, you can quickly identify the status and activity of the compound. These ports detect the speed of the network and perform auto-negotiation between 10BASE-T and 100BASE-TX, as well as between modes half-and full-duplex, to ensure that every device connected to the network the highest possible speed for viewing Web-pages, streaming video and games online. DES-1005A also supports auto polarity MDI / MDIX, that can be directly connected to each port on the server, hub, router, or switch using conventional direct Ethernet-cables twisted pair.
Easy installation with Plug and Play
DES-1005A supports Plug-and-Play, which does not require adjustment, easy installation, through which you can immediately connect multiple computers to share files, music and videos throughout your home or small office, or even create conditions for multiplayer games. 802.3x flow control on each port minimizes packet loss at the input port buffer overflow that provides a secure connection for all connected devices.
Environmentally friendly
Switch DES-1005A uses D-Link Green, can significantly reduce energy consumption. If the computer is not connected to the port or the attached computer is off, the port automatically goes into sleep mode, significantly reducing energy consumption for this port, without interrupting the network. In addition, the switch will automatically detect the length of connected Ethernet-cable and adjust accordingly their energy consumption without affecting this performance. This greatly reduces the overall power consumption, which reduces energy costs and reduce environmental impact.
Compact and quiet operation
DES-1005A has a sleek and compact design, so the switch can be placed in any easily accessible place so that it does not interfere with the users. Located on the rear panel ports and power connector allows you to remove any cables connected to a prominent place. DES-1005A uses a fan so, the switch operates quietly, but effectively, allowing you to watch streaming video without delay or view Web-page.
