Hızlı Arama
Ürün Özellikleri:
5-port 10/100Base-TX Yönetilmeyen Anahtar
Genel Özellikler:
Fiziksel Özellikler
The main function
• Cost-effective Fast Ethernet for home networks and SOHO
• 5-port 10/100 Mbit / s Fast Ethernet
• Auto MDI / MDIX on all ports
• Switching Method: store-and-forward
• Modes of semi-and full-duplex speeds for Ethernet / Fast Ethernet
• IEEE 802.3x Flow Control
• Jumbo Frames: 2045 bytes
  - Supports 802.1p QoS: 2 queues, Strict Mode
• Compliance with the RoHS Directive
• Installing the Plug-and-play
Switching matrix
1.0 Gbit / s
Standards
• Auto-negotiation of ANSI / IEEE 802.3 NWay
Protocol
CSMA / CD
Data transfer rate
• Ethernet
  - 10 Mbit / s (half duplex)
  - 20 Mbit / s (full duplex)
• Fast Ethernet
  - 100 Mbit / s (half duplex)
  - 200 Mbit / s (full duplex)
Topology
Star
Interfaces transmission medium
Automatic detection of MDI / MDIX on all ports
Network Cables
• 10BASE-T:
  - UTP Cat. 3/4/5/5e (100m max.)
  - EIA/TIA-586 100-ohm STP (100m max.)
• 100BASE-TX:
  - UTP Cat. 5/5e (100m max.)
  - EIA/TIA-568 100-ohm STP (100m max.)
Indicators
• Per Port: Link / Activity
• On the device: Power
Switching Method
Store-and-forward
MAC-address table
2K
Study MAC-address
Automatic Update
Speed ​​Packet Filtering / Forwarding
• Ethernet: 14,880 packets per second. the port
• Fast Ethernet: 148,800 packets per second. the port
Buffer RAM
384KB per device
Fiziksel Özellikler
Power Input
External power adapter, 5 V / 1 A
Power consumption
• Power on. (Standby):
  - Power Input: 0.35 W DC 0.7 W AC
• Maximum:
  - Input Power: 1.9 W DC 2.7 W AC
Heat release
  - Power Input (AC): 2,3884 BTU / h
• Maximum:
  - Power Input (AC): 6,4828 BTU / h
Operating temperature
From 0 to 50 C
Storage temperature
-10 To 70 C
Operating Humidity
From 10% to 90% non-condensing
Humidity
From 5% to 90% non-condensing
Measurements
100 x 98 x 28 mm
Certificates
• FCC Class B
• ICES-003 Class B
• CE Class B
• C-Tick Class B
• VCCI Class B
• cUL
• CB
Ürünler | Destek  | Haberler  | Hakkında |
