Hızlı Arama
Ürün Özellikleri:
24 10/100/1000 Mbps, 2 Gigabit SFP, 2 10G SFP+ port ve güç tasarrufu fonksiyonlu Gigabit Stackable Web SmartPro Anahtar
EOL
Genel Özellikler:
Software Features
Stackability
 • Virtual Stacking Support
     • D-Link Single IP Management
     • Up to 32 devices per virtual stack
     • Up to 20G stacking bandwidth
 • Physical Stacking
     • Supports Duplex Chain/Ring topology
     • Up to 40G stacking bandwidth full duplex
     • Up to 6 units per stack
L2 Features
 • MAC Address Table: 16K
 • Flow Control
     • 802.3x Flow Control
     • HOL Blocking Prevention
 • Jumbo Frame up to 9000 Bytes
 • IGMP Snooping
     • IGMP v1/v2/v3 Snooping
     • IGMP v3 awareness
     • Supports 512 IGMP groups
     • Supports 128 static multicast addresses
     • IGMP per VLAN
     • Supports IGMP Snooping Querier
     • Host-based IGMP Snooping Fast Leave
 • MLD Snooping
     • Supports MLD v1/v2 awareness
     • Supports 512 groups
     • Supports 128 Static Multicast Addresses
     • Per VLAN MLD Snooping
     • Host-based MLD Fast Leave
     • MLD Snooping Querier
 • Spanning Tree Protocol
     • 802.1D STP
     • 802.1w RSTP
     • 802.1s MSTP
 • Loopback Detection
 • 802.3ad Link Aggregation
     • Max. 32 groups per device/8 ports per group
 • Port Mirroring
     • Support 4 mirroring groups
     • One-to-One, Many-to-One
     • Supports Mirroring for Tx/Rx/Both
 • Multicast Filtering
     • Forwards all unregistered groups
     • Filters all unregistered groups
 • LLDP, LLDP-MED
VLAN
• 802.1Q Tagged VLAN
• 4K VLAN Groups
• Configurable VID: 0~4094
• MAC-based VLAN
• Asymmetric VLAN
• ISM VLAN
• Auto Voice VLAN
• Auto Surveillance VLAN
Quality of Service (QoS
 • 802.1p Quality of Service
 • Queue Handling
     • Strict
     • Weighted Round Robin (WRR)
 • 8 queues per port
 • Bandwidth Control
     • Port-based (Ingress/Egress, min. granularity for 10/100/1000 BASE-T ports is 64 Kb/s)
 • CoS based on
     • 802.1p priority
     • VLAN
     • MAC address
     • Ether type
     • IP address
     • DSCP
     • Protocol type
     • TCP/UDP port number
     • DSCP of IPv6 Traffic Class
     • IPv6 flow label
L3 Features
 • ARP
     • 256 Static ARP
     • Supports Gratuitous ARP
 • IPv6 Neighbour Discovery (ND)
 • Default Routing
 • Static Routing
     • 64 IPv4 Static Route Entries
     • 32 IPv6 Static Route Entries
Access Control List (ACL)
 • ACL based on
     • 802.1p priority
     • VLAN
     • MAC address
     • Ether type
     • IP address
     • DSCP
     • Protocol type
     • IPv6 flow label
 • ACL Actions
     • Permit
     • Deny
 • Max. 256 access list
 • Max. 768 rules
 • Single or multiple ports (each rule)
 • Time-based ACL
 • ACL Statistics
Security
 • Port Security
     • Supports up to 128 MAC addresses per port
 • Broadcast/Multicast/Unicast Storm Control
 • Dynamic ARP Inspection
 • Static MAC
 • D-Link Safeguard Engine
 • DHCP Server Screening
 • ARP Spoofing Prevention
     • Max. 64 entries
 • SSH
     • Supports v2
     • Supports IPv4/IPv6
 • SSL
     • Supports v1/v2/v3
 • Traffic Segmentation
 • IP-MAC-Port Binding
     • DHCP snooping
     • IP Source Guard
     • Dynamic ARP inspection
     • DHCPv6 Guard
     • RA Guard
     • IPv6 Snooping
     • IPv6 Source Guard
 • DoS Attack Prevention
AAA
 • Compound Authentication
 • 802.1X Port and MAC-based Authentication
     • Supports RADIUS and Local Server
     • Supports EAP, OTP, TLS, TTLS, PEAP
 • Web-based Access Control (WAC)
     • Port-based Access Control
     • Host-based Access Control
     • Dynamic VLAN Assignment
 • MAC-based Access Control (MAC)
 • Japan Web-based Access Control (JWAC)
OAM
 • Cable Diagnostics
 • Factory Reset
Management
• CLI
• Telnet Server
• TFTP Client
• IPv6 Neighbor Discovery
• Configurable MDI/MDIX
• SNMP
• Supports v1, v2c, v3
• SNMP Trap
• System Log
• Max. 10,000 log entries
• DHCP Client
• DHCP option 82
• DHCP Server
• DHCP relay
• D-Link Network Assistant support
• SNTP
• Dual images
• Dual Configurations
• ICMPv6
• IPv4/v6 Dual Stack
• DHCP Auto Configuration
• RMON v1
• Secured FTP (SFTP) Client
D-Link Green 3.0 Technology
 • Power Saving by:
     • Link Status
     • LED or Port Shutoff
 • System Hibernation mode
 • Time-based PoE (PoE model only)
Optional SFP Transceivers
 • DEM-310GT 1000BASE-LX, single-mode, 10 km
 • DEM-311GT 1000BASE-SX, multi-mode, 550 m
 • DGS-712 1000BASE-T to SFP transceiver
Optional SFP+ Transceivers
 • DEM-431XT-DD 10GBASE-SR SFP+ Transceiver (with DDM), 80m: OM1 & OM2 MMF, 300m: OM3 MMF
 • DEM-432XT-DD 10GBASE-LR SFP+ Transceiver (with DDM), 10km
 • DEM-435XT-DD 10GBASE-LRM SFP+ Transceiver (with DDM), 220m
Optional SFP+ Direct Attach Stacking Cables
 • DEM-CB100S 10-GbE SFP+ 1 m Direct Attach Cable
 • DEM-CB300S 10-GbE SFP+ 3 m Direct Attach Cable
 • DEM-CB700S 10-GbE SFP+ 7m Direct Attach Cable
Ordering Information
Model number
 / Description
DGS-1510-20 / 20-port Gigabit SmartPro Switch including 2 SFP ports & 2 10GbE SFP+ ports
DGS-1510-28 / 28-port Gigabit SmartPro Switch including 2 SFP ports & 2 10GbE SFP+ ports
DGS-1510-28P / 28-port Gigabit SmartPro PoE Switch including 2 SFP ports & 2 10GbE SFP+ ports  DGS-1510-52 / 52-port Gigabit SmartPro Switch including 2 SFP ports & 2 10GbE SFP+ ports
Fiziksel Özellikler
Physical & Environmental
AC Input
 • 100 to 240 VAC 50/60 Hz internal universal power supply
Maximum Power Consumption
 • DGS-1510-20:  20.3 W
 • DGS-1510-28:  24 W
 • DGS-1510-28P:  238.7 W (PoE on), 29 W (PoE off)
 • DGS-1510-52:  38.4 W
Standby Power Consumption
 • DGS-1510-20:  12.2 W
 • DGS-1510-28:  15.2 W
 • DGS-1510-28P:  21 W
 • DGS-1510-52:  27.6 W
Smart Fan Quantity
 • DGS-1510-20:  1
 • DGS-1510-28:  1
 • DGS-1510-28P:  2
 • DGS-1510-52:  2
Acoustics
 • DGS-1510-20:  43.8 dB(A)
 • DGS-1510-28:  47.5 dB(A)
 • DGS-1510-28P:  46.4 dB(A)
 • DGS-1510-52:  44.2 dB(A)
Heat Dissipation
 • DGS-1510-20:  41.602 BTU/hr
 • DGS-1510-28:  72.292 BTU/hr
 • DGS-1510-28P:  813.967 BTU/hr
 • DGS-1510-52:  130.944 BTU/hr
CPU Speed
 • 400MHz
DRAM Size
 • 256MB
Flash Memory Size
 • 32MB
Operation Temperature
 • 23 to 122 ˚F (-5 to 50 ˚C)
Storage Temperature
 • -4 to 158 ˚F (-20 to 70˚C)
Operation Humidity
 • 0% to 95% non-condensing
Storage Humidity
Dimensions
 • DGS-1510-20:
     • 11 x 7.09 x 1.73 inches (280 x 180 x 44 mm)
     • 19” standard rack mounting width, 1U height
 • DGS-1510-28:
     • 17.36 x 8.26 x 1.73 inches (440 x 210 x 44 mm)
 • DGS-1510-28P:
 • DGS-1510-52:
     • 17.36 x 9.84 x 1.73 inches (440 x 250 x 44 mm)
Weight
 • DGS-1510-20:  2.7 lbs (1.24 kg)
 • DGS-1510-28:  4.4 lbs (2.00 kg)
 • DGS-1510-28P:  5.6 lbs (2.54 kg)
 • DGS-1510-52:  5.3 lbs (2.40 kg)
Diagnostic LEDs
 • Power/Stacking ID/Fan (per device),
 • Link/Activity/Speed (per 10/100/1000 Mbps port),
 • Link/Activity/Speed (per Gigabit SFP port),
 • Link/Activity/Speed (per 10G SFP+ port)
Certifications
 • CE, FCC, C-Tick, VCCI, BSMI, CCC
 • Safety cUL, CB
Ürünler | Destek  | Haberler  | Hakkında |
