DGS-1016D/G1EOL EOS
16-Port Unmanaged Gigabit Switch
Nereden Alınır
Tanımlama
The D-Link DGS-1016D 16-Port Unmanaged Gigabit Switch offers an economical way for SOHO and small to medium businesses (SMB) to deploy an energy-efficient switch that features the increased bandwidth of Gigabit ports.
Gigabit on Every Port
The 16-Port Unmanaged Gigabit Switch series brings the speed of Gigabit Ethernet to each and every port for a truly high-speed network. If your network has a mix of legacy and modern computing capabilities, each port allows for standard Ethernet, Fast Ethernet, or Gigabit Ethernet connections. You have the latest technology available to every computer and device connected to your network.
Innovative Design
The metal case of the DGS-1016D and a compact desktop style help generate heat dissipation levels that allow for a fanless design, making the switches silent, as well as economical. The 16-Port Unmanaged Gigabit Switch is small, lightweight, wall-mountable, and ideal for any business with big needs and a small budget.
Conserves Energy
The 16/24-Port Unmanaged Gigabit Switch series helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save substantial amounts of power by cutting power usage for unused ports or any ports connected to computers that have been shut down. It can also detect connected cable lengths, and adjusts power usage accordingly, helping you save energy without affecting networking performance.
Think Green
The DGS-1016D Unmanaged Gigabit Switch series makes use of D-Link Green Ethernet technology, providing more energy savings and a longer product life, without sacrificing operational performance or functionality. These environmentally friendly switches are also RoHS compliant, use recyclable packaging, and minimize the use of harmful substances.
Genel Özellikler
Number of Ports
• Sixteen 10/100/1000 Gigabit ports
Standards
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX Fast Ethernet
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.3x Flow Control
Data Transfer Rates
• Ethernet:
  • 10 Mbps (half duplex)
  • 20 Mbps (full duplex)
• Fast Ethernet:
  • 100 Mbps (half duplex)
  • 200 Mbps (full duplex)
• Gigabit Ethernet:
  • 2000 Mbps (full duplex)
Network Cables
• 10BASE-T:
• UTP CAT 3, 4, 5/5e (100 m max)
• EIA/TIA-586 100-ohm STP (100 m max)
• 100BASE-TX, 1000BASE-T:
• UTP CAT 5/5e (100 m max)
• EIA/TIA-568 100-ohm STP (100 m max)
Functionality
D-Link Green Features
• IEEE 802.3az Energy Efficient Ethernet (EEE)
• Link status detection power saving
• Cable length detection power saving
• RoHS Compliance
LAN Features
• Back pressure at half-duplex operation
• Auto MDI/MDIX
• Wire speed reception and transmission
• Store-and-Forward switching method
• 8K MAC addresses
• 4Mbits RAM for data buffering
• Jumbo Frames: 9216 Bytes
• Switching Capacity: 32Gbps
Port Packet Filtering
• 10M: 14,880 pps
• 100M: 148,800 pps
• 1000M: 1,488,000 pps
Fiziksel Özellikler
LEDs
• Power LED
  • 16 Link/Activity/Speed LEDs (one per port)
Power Inputs
• 100 to 240V AC Input
Power Consumption
• Standby: 4.48 watts
• Maximum: 9.84 watts
Heat Dissipation
• Standby: 15.2768 Btu/h
• Maximum: 33.5544 Btu/h
MTBF
• 795,539 hours
Dimensions
• 280 x 125 x 44 mm (11.02 x 4.92 x 1.73 inches)
Weight
• 1.06 kg (2.34 lbs)
Operating Temperature
• 0 to 40 °C (32 to 104 °F)
Storage Temperature
• -10 to 70 °C (14 to 158 °F)
Humidity
• 5% to 90% non-condensing
Certifications
• FCC Class A
• ICES-003 Class A
• CE Class A
• C-Tick Class A
• CB
• cUL
Çözümler
Sipariş Bilgisi
DGS-1016D/G1  16-Port Unmanaged Gigabit Switch
Görseller
DGS-1016D/G1/G2
Front view
View from the right
Back view
DGS-1016D/G1/G3
Front view
View from the right
Back view
DGS-1016D/G1/G1
Front view
View from the right
Back view
İndir
Destek Merkezi
