DGS-1510-52XProje
48 10/100/1000 Mbps, 4 10G SFP+ port ve güç tasarrufu fonksiyonlu Gigabit Stackable Web SmartPro Anahtar
Nereden Alınır
Tanımlama
The DGS-1510 Series is D-Link’s latest generation of SmartPro switches with 10G port connectivity, making them ideal for deployment in SME/SMB core environments. The DGS-1510 Series provides a reliable, scalable, and modular interconnection between core switches and edge switches with rich capabilities and simplified flexibility. Available in 16, 24 or 48 10/100/1000 Mbps port models, these switches also include 4 10G SFP+ ports.
Power over Ethernet
The DGS-1510-28P’s 10/100/1000 Mbps ports are PoE-enabled for powering devices such as IP cameras, VoIP phones and wireless access points. Compliant with 802.3af and 802.3at, the DGS-1510-28P supports up to 30W of power output on any particular PoE port up to 193W, providing flexibility in power allocation for a variety of powered devices, including new 802.11ac wireless access points that require 802.3at power for full functionality. Time based PoE enables power to a port to be shut off at a scheduled time, reducing power usage and increasing security by powering off devices that should not be in use during non-business hours.
Two 10G SFP+ Stacking/Uplink Ports
Depending on whether linear or fault-tolerant ring stacking is implemented, users can use one or two 10-Gigabit SFP+ ports to create a physical stack. Six units or 288 Gigabit ports can be configured as a stack using optional direct attach cables to provide high bandwidth on the DGS-1510 Series with cost efficiency. Users can mix from any of the DGS-1510 SmartPro series in a single stack to allow simultaneous and easy configuration, management and troubleshooting.
Flexibility and Scalability
The DGS-1510 Series supports virtual stacking via D-Link’s Single IP Management (SIM), allowing up to 32 devices to be managed via a single IP. This simplifies management of small workgroups or wiring closets while allowing the network to be scaled to handle increased bandwidth demand.  SIM reduces the number of IP address needed in the network and allows switches to be stacked together over Ethernet instead of using physical uplink or stacking ports. This eliminates the need for specialized stacking cables and removes distance barriers that can limit topology options when using other stacking technology.
Extensive Layer 2 Features
The DGS-1510 Series switches are equipped with a complete lineup of Layer 2 features including IGMP Snooping, Port Mirroring, Spanning Tree, and Link Layer Discovery Protocol (LLDP). The IEEE 802.3x Flow Control function allows servers to directly connect to the switch for fast, reliable data transfer. At 2000 Mbps Full Duplex, the Gigabit ports provide high-speed data pipes to servers with minimum data transfer loss. Network maintenance features include Loopback Detection and Cable Diagnostics. Loopback Detection is used to detect loops created by a specific port or VLAN and automatically shut down the affected port or VLAN. The Cable Diagnostics feature, designed primarily for administrators and customer service representatives, can quickly discover the type of error on cables and determine the cable quality.
QoS, Bandwidth Control
The DGS-1510 Series supports Auto Surveillance VLAN (ASV) and Auto Voice VLAN, which are best suited for VoIP and video surveillance deployments. Auto Surveillance VLAN is a new, industry-leading technology built into D-Link Smart Switches. This technology consolidates data and surveillance video transmission through a single SmartPro switch, sparing businesses the expense of maintaining expensive dedicated hardware and facilities.  ASV also ensures the quality of real-time video for monitoring and control without compromising the transmission of conventional network data.  The Auto Voice VLAN technology enhances VoIP service by automatically placing voice traffic from an IP phone to an assigned VLAN. With higher priority and an individual VLAN, these features guarantee the quality and security of VoIP traffic. Furthermore, the DSCP markings on Ethernet packets enable different levels of service to be assigned to network traffic. As a result, these voice and video packets take precedence over other packets.  In addition, with Bandwidth Control, network administrators can reserve bandwidth for important functions that require more bandwidth or might require high priority.
Secure your Network
D-Link’s innovative Safeguard Engine protects the switches against traffic flooding caused by virus attacks. The switches also support 802.1X port-based authentication, allowing the network to be authenticated through external RADIUS servers. In addition, the Access Control List (ACL) feature enhances network security and helps to protect the internal IT network by screening ingress traffic based on MAC or IP addresses. The DGS-1510 Series includes ARP Spoofing Prevention, which protects from attacks on the Ethernet network that may allow an intruder to sniff data frames, modify traffic, or bring traffic to a halt altogether by sending fake ARP messages to the network. To prevent ARP Spoofing attacks, the switch uses Packet Control ACLs to block invalid packets that contain fake ARP messages. For added security, the DHCP Server Screening feature screens rogue DHCP server packets from user ports to prevent unauthorized IP assignment.
IPv6 Ready
The DGS-1510 Series is IPv6 ready and supports various IPv6 functions such as MLD Snooping, IPv6 ACL/QoS, and IMPBv6 to ensure seamless integration of next generation networks. The DGS-1510 Series also supports a IPv4/v6 dual stack function that allows the switch to act as a bridge between IPv4 and IPv6 networks. Finally, all DGS-1510 Series are certified to be IPv6 Ready Logo Phase 2, which guarantees interoperability for IPv6 environments.
Versatile Management
The DGS-1510 Series provides a D-Link Network Assistant Utility and a web based management interface that enables administrators to remotely control their network down to the port level. The D-Link Network Assistant Utility allows customers to easily discover multiple D-Link SmartPro Switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC. It also simplifies the initial setup of the SmartPro Switches. Switches within the same L2 network segment that are connected to the user’s PC are displayed on screen for instant access.  This allows extensive switch configuration and basic setup of discovered devices including password changes and firmware upgrades. The DGS-1510 Series also supports D-View 6.0 and a fully featured Command Line Interface (CLI) via dedicated out-of-band console port. D-View 6.0 is a Network Management System that allows for the central management of critical network characteristics such as availability, reliability, resilience, and security. CLI management of the switches is possible via console port and Telnet interfaces. This makes it possible to adjust basic settings, passwords, configuration files, and firmware with ease.
Layer 3 Traffic Management
The DGS-1510 Series supports advanced traffic management features, including static routing. In static routing, IP routes are manually entered into a routing table, which allows for communication between different user groups in different VLAN segments in a network. The switch can directly handle inter VLAN routing using multiple interfaces, making the network run faster and more efficiently. Because the switches can manage internal routing, the network router can be assigned to handle external traffic routing only.
Energy Saving
DGS-1510 switches are capable of conserving power without sacrificing operational performance or functionality by using D-Link Green 3.0 technology. Using the 802.3az Energy Efficient Ethernet standard, the network will automatically decrease the power usage when traffic is low with no setup required. For environments not fully supporting the standard, DGS-1510 switches offer advanced power-saving settings including port shutoff, LED shutoff, and system hibernation based on custom scheduling profiles. The profiles can also be applied to the PoE switch so that there is no unnecessary power consumption during off hours.
Genel Özellikler
Software Features
Stackability
 • Virtual Stacking Support
     • D-Link Single IP Management
     • Up to 32 devices per virtual stack
     • Up to 20G stacking bandwidth
 • Physical Stacking
     • Supports Duplex Chain/Ring topology
     • Up to 40G stacking bandwidth full duplex
     • Up to 6 units per stack
L2 Features
 • MAC Address Table: 16K
 • Flow Control
     • 802.3x Flow Control
     • HOL Blocking Prevention
 • Jumbo Frame up to 9000 Bytes
 • IGMP Snooping
     • IGMP v1/v2/v3 Snooping
     • IGMP v3 awareness
     • Supports 512 IGMP groups
     • Supports 128 static multicast addresses
     • IGMP per VLAN
     • Supports IGMP Snooping Querier
     • Host-based IGMP Snooping Fast Leave
 • MLD Snooping
     • Supports MLD v1/v2 awareness
     • Supports 512 groups
     • Supports 128 Static Multicast Addresses
     • Per VLAN MLD Snooping
     • Host-based MLD Fast Leave
     • MLD Snooping Querier
 • Spanning Tree Protocol
     • 802.1D STP
     • 802.1w RSTP
     • 802.1s MSTP
 • Loopback Detection
 • 802.3ad Link Aggregation
     • Max. 32 groups per device/8 ports per group
 • Port Mirroring
     • Support 4 mirroring groups
     • One-to-One, Many-to-One
     • Supports Mirroring for Tx/Rx/Both
 • Multicast Filtering
     • Forwards all unregistered groups
     • Filters all unregistered groups
 • LLDP, LLDP-MED
VLAN
• 802.1Q Tagged VLAN
• 4K VLAN Groups
• Configurable VID: 0~4094
• MAC-based VLAN
• Asymmetric VLAN
• ISM VLAN
• Auto Voice VLAN
• Auto Surveillance VLAN
Quality of Service (QoS
 • 802.1p Quality of Service
 • Queue Handling
     • Strict
     • Weighted Round Robin (WRR)
 • 8 queues per port
 • Bandwidth Control
     • Port-based (Ingress/Egress, min. granularity for 10/100/1000 BASE-T ports is 64 Kb/s)
 • CoS based on
     • 802.1p priority
     • VLAN
     • MAC address
     • Ether type
     • IP address
     • DSCP
     • Protocol type
     • TCP/UDP port number
     • DSCP of IPv6 Traffic Class
     • IPv6 flow label
L3 Features
 • ARP
     • 256 Static ARP
     • Supports Gratuitous ARP
 • IPv6 Neighbour Discovery (ND)
 • Default Routing
 • Static Routing
     • 64 IPv4 Static Route Entries
     • 32 IPv6 Static Route Entries
 • ACL based on
     • 802.1p priority
     • VLAN
     • MAC address
     • Ether type
     • IP address
     • DSCP
     • Protocol type
     • IPv6 flow label
 • ACL Actions
     • Permit
     • Deny
 • Max. 256 access list
 • Max. 768 rules
 • Single or multiple ports (each rule)
 • Time-based ACL
 • ACL Statistics
Security
 • Port Security
     • Supports up to 128 MAC addresses per port
 • Broadcast/Multicast/Unicast Storm Control
 • Dynamic ARP Inspection
 • Static MAC
 • D-Link Safeguard Engine
 • DHCP Server Screening
 • ARP Spoofing Prevention
     • Max. 64 entries
 • SSH
     • Supports v2
     • Supports IPv4/IPv6
 • SSL
     • Supports v1/v2/v3
 • Traffic Segmentation
 • IP-MAC-Port Binding
     • DHCP snooping
     • IP Source Guard
     • Dynamic ARP inspection
     • DHCPv6 Guard
     • RA Guard
     • IPv6 Snooping
     • IPv6 Source Guard
 • DoS Attack Prevention
AAA
 • Compound Authentication
 • 802.1X Port and MAC-based Authentication
     • Supports RADIUS and Local Server
     • Supports EAP, OTP, TLS, TTLS, PEAP
 • Web-based Access Control (WAC)
     • Port-based Access Control
     • Host-based Access Control
     • Dynamic VLAN Assignment
 • MAC-based Access Control (MAC)
 • Japan Web-based Access Control (JWAC)
OAM
 • Cable Diagnostics
 • Factory Reset
Management
• CLI
• Telnet Server
• TFTP Client
• IPv6 Neighbor Discovery
• Configurable MDI/MDIX
• SNMP
• Supports v1, v2c, v3
• SNMP Trap
• System Log
• Max. 10,000 log entries
• DHCP Client
• DHCP option 82
• DHCP Server
• DHCP relay
• D-Link Network Assistant support
• SNTP
• Dual images
• Dual Configurations
• ICMPv6
• IPv4/v6 Dual Stack
• DHCP Auto Configuration
• RMON v1
• Secured FTP (SFTP) Client
D-Link Green 3.0 Technology
 • Power Saving by:
     • Link Status
     • LED or Port Shutoff
 • System Hibernation mode
 • Time-based PoE (PoE model only)
Optional SFP Transceivers
 • DEM-310GT 1000BASE-LX, single-mode, 10 km
 • DEM-311GT 1000BASE-SX, multi-mode, 550 m
 • DGS-712 1000BASE-T to SFP transceiver
Optional SFP+ Transceivers
 • DEM-431XT-DD 10GBASE-SR SFP+ Transceiver (with DDM), 80m: OM1 & OM2 MMF, 300m: OM3 MMF
 • DEM-432XT-DD 10GBASE-LR SFP+ Transceiver (with DDM), 10km
 • DEM-435XT-DD 10GBASE-LRM SFP+ Transceiver (with DDM), 220m
Optional SFP+ Direct Attach Stacking Cables
 • DEM-CB100S 10-GbE SFP+ 1 m Direct Attach Cable
 • DEM-CB300S 10-GbE SFP+ 3 m Direct Attach Cable
 • DEM-CB700S 10-GbE SFP+ 7m Direct Attach Cable
Ordering Information
Model number
 / Description
DGS-1510-20 / 20-port Gigabit SmartPro Switch including 2 SFP ports & 2 10GbE SFP+ ports
DGS-1510-28 / 28-port Gigabit SmartPro Switch including 2 SFP ports & 2 10GbE SFP+ ports
DGS-1510-28P / 28-port Gigabit SmartPro PoE Switch including 2 SFP ports & 2 10GbE SFP+ ports  DGS-1510-52 / 52-port Gigabit SmartPro Switch including 2 SFP ports & 2 10GbE SFP+ ports
Fiziksel Özellikler
Physical & Environmental
AC Input
 • 100 to 240 VAC 50/60 Hz internal universal power supply
Maximum Power Consumption
 • DGS-1510-52X:  38.4 W
Standby Power Consumption
 • DGS-1510-52X:  27.6 W
Smart Fan Quantity
 • DGS-1510-52X:  2
Acoustics
 • DGS-1510-52X:  44.2 dB(A)
Heat Dissipation
 • DGS-1510-52X:  130.944 BTU/hr
Operation Temperature
 • 23 to 122 ˚F (-5 to 50 ˚C)
Storage Temperature
 • -4 to 158 ˚F (-20 to 70˚C)
Operation Humidity
 • 0% to 95% non-condensing
Storage Humidity
Dimensions
 • DGS-1510-52X:
     • 17.36 x 9.84 x 1.73 inches (440 x 250 x 44 mm)
     • 19” standard rack mounting width, 1U height
Weight
 • DGS-1510-52X:  2.41 kg
Diagnostic LEDs
 • Power/Stacking ID/Fan (per device),
 • Link/Activity/Speed (per 10/100/1000 Mbps port),
 • Link/Activity/Speed (per Gigabit SFP port),
 • Link/Activity/Speed (per 10G SFP+ port)
Certifications
 • CE, FCC, C-Tick, VCCI, BSMI, CCC
 • Safety cUL, CB
Çözümler
Sipariş Bilgisi
DGS-1510-52X 48 10/100/1000 Mbps, 4 10G SFP+ port ve güç tasarrufu fonksiyonlu Gigabit Stackable Web SmartPro Anahtar
Görseller
DGS-1510-52XA2
Front view
View from the right
Back view
DGS-1510-52XA1
Front view
View from the right
Back view
İndir
Destek Merkezi
