DGS-1100-16/ME
16 adet 10/100/1000 Mbps Port Yönetilebilir L2 Metro Ethernet Anahtar
Nereden Alınır
Tanımlama
D-Link’s Gigabit Metro Ethernet Switches are ideal for Metro Ethernet applications, providing
16/24 copper connections on upgraded Gigabit Ethernet ports along with Gigabit SFP ports for
improved uplink bandwidth if needed. They also offr resilience against electrical spikes with
built-in surge protection, giving you a reliable solution you can count onD-Link Green/Power Saving Performance
Compliant with IEEE802.3az Energy Effient Ethernet, these switches consume less energy by
cutting down on power consumption when port utilization is low. By deploying EEE devices,
users can cut operating costs and even cut down on necessary cooling equipment, helping
small and medium-sized businesses stay within their budgets. The DGS-1100/ME Series also
features D-Link Green Technology that helps automatically save energy. The switches monitor
the link status of every port and will drastically reduce power consumption when a port link is
down
Easy to deploy
The DGS-1100/ME Series support an intuitive D-Link Network Assistant Utility and a command
line management interface. The D-Link Network Assistant Utility allows customers to discover
all D-Link switches within the same L2 network segment. With this utility, users do not need
to change the IP address of their PC, and this also makes initial setup of the switches quick
and easy. Switches within the same L2 network segment that are connected to the user’s PC
are displayed on-screen for instant access. This allows for extensive switch confiuration and
basic setup of discovered devices, including password changes and fimware upgrades. The
command line interface enables network administrators to remotely control their network
down to the port level
QoS and Bandwidth Control
The DGS-1100/ME Series supports Auto Surveillance VLAN (ASV), and Auto
Voice VLAN, which are best suited for VoIP and video surveillance deploymentsAuto Surveillance VLAN consolidates data and surveillance video transmission
through a single DGS-1100/ME Series switch, thus sparing businesses the
expense of dedicated hardware and facilities. ASV also ensures the quality
of real-time video for monitoring and control without compromising the
transmission of conventional network data. The Auto Voice VLAN technology
enhances the VoIP service by automatically placing voice traff from an IP
phone to an assigned VLAN. With higher priority and individual VLAN, these
features guarantee the quality and security of VoIP traffi Bandwidth Control
can reserve bandwidth on a per port basis for important functions that
require larger bandwidth or might have high priority
PoE Support
The DGS-1100-24P/ME delivers Power over Ethernet (PoE) capabilities,
making deployment with IP cameras, VoIP phones, and access points much
easier. Power cords will become a thing of the past, as the DGS-1100-24P/ME
complies with the 802.3af/802.3at standard for PoE and supports a 100 Watt
power budget. The 10/100/1000Base-T Ethernet ports mean that even highquality video is no problem
Easy Troubleshooting
The DGS-1100/ME Series feature Loopback Detection and Cable Diagnostics
to help network administrators fid and solve network problems quickly and
easily. Loopback Detection is used to detect loops created by a specifi port
and automatically shut down the affcted port. The Cable Diagnostics feature
is designed for network administrators to quickly examine the quality of the
copper cables, recognize the cable type, and detect cable errors
Advanced Features
The DGS-1100/ME Series is equipped with advanced security features such
as Static MAC, Storm Control, and IGMP Snooping. Static MAC allows users to
create a MAC whitelist for specifi ports, helping administrators limit network
access to authorized devices only. Storm Control monitors broadcast,
multicast, or unknown unicast traff and will start blocking or discarding
packets which could flod the network when the defied threshold is
exceeded. IGMP Snooping is able to reduce the loading of L3 multicast
routers and save bandwidth in network throughput
Genel Özellikler
Fiziksel Özellikler
Number of Ports
• 16 10/100/1000BASE-TX ports
Standards
• IEEE 802.3 compliance
• IEEE 802.3u compliance
• IEEE 802.3ab compliance
• IEEE 802.3x Flow Control
• IEEE 802.3az compliance
Performance
Switching Capacity
• 32 Gbps
64-byte Maximum Forwarding Rate
• 23.81 Mbps (based on 64 Bytes)
MAC Address Table Size
• 8K Entries
DRAM for CPU
• 128 MB
Packet Buffer
• 512K
Flash Memory
• 8 MB
Jumbo Frame
• Up to 10 Kbytes
LEDs
• Power (per device)
• Link/Activity/Speed (per port)
Power Consumption
Standby Mode
• 7.36 watts
Maximum
• 9.31 watts
Software Features
L2 Features
• MAC Address Table: 8K
• 802.3x Flow Control
  • HOL Blocking Prevention
• Loopback Detection
• Port Mirroring
  • Max 4 Mirror sessions
  • One-to-One
  • Many-to-One
L2 Multicasting
• IGMP Snooping
  • IGMP Snooping v1/v2, v3 Awareness
  • Supports 128 IGMP snooping groups (shared with MLD Snooping)
  • Host-based IGMP snooping Fast Leave
• IGMP Authentication
• MLD Snooping
  • MLD Snooping v1, v2
  • Supports 128 MLD snooping groups (shared with IGMP Snooping)
  • Host-based MLD Snooping Fast Leave
• Limited IP Multicast
VLAN
• 802.1Q Tagged VLAN
• VLAN Group
  • Supports 128 static VLAN groups
• Management VLAN
• Port-based VLAN
• ISM VLAN
• Double VLAN (Q-in-Q)
  • Port-based Q-in-Q
Quality of Service (QoS)
• 4 queues per port
• Queue Handling
  • Strict Priority
  • Weighted Round Robin (WRR)
• Bandwidth Control
  • Port-based (Ingress/Egress, min. granularity 64 Kb/s)
• CoS Based on:
  • 802.1p
  • DSCP
Security
• Port Security
  • Up to 64 MAC addresses per port
• Traffic Segmentation
• Broadcast/Multicast/Unknown Unicast Storm Control
• D-Link Safeguard Engine
AAA
• 802.1X
  • Port-based Access Control
  • Host-based Access Control
• Supports Guest VLAN
• Support Local/RADIUS Servers
• Support RADIUS Accounting
• 3 Levels of User Accounts
OAM
• Cable Diagnostics
• 802.3ah
Management
• Web-based GUI
• Command Line Interface (CLI)
• Telnet Server
• TFTP Client
• SNMP v1/v2c/v3
• SNMP Traps
• System Log
• RMON v1
  • Support 1,2,3,9 Groups
• LLDP
• DHCP Client
• DHCP Auto-Configuration
• DHCP Relay for IPv4/IPv6
• DHCP Relay Option 82
• DHCP Relay Option 37
• PPPoE Circult-ID Tag Insertion
• SNTP
• CPU Monitoring
• Password Encryption
MIB
• RFC1213 MIB II
• RFC1493 Bridge MIB
• RFC1907 SNMPv2 MIB
• RFC1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC 2233, 2863 IF MIB
• Private MIB
IETF Standard
• RFC768 UDP
• RFC791 IP
• RFC792,2463, 4443 ICMPv4
• RFC793 TCP
• RFC826 ARP
• RFC 2474, 3260 Definition of the DS Field in the IPv4 and IPv6 Header
• RFC 1321, 2284, 2865, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC2571, RFC2572, RFC2573, RFC2574 SNMP
• RFC1981, RFC2460, RFC2461,4861, RFC2462,4862, RFC2464, RFC3513,4291, RFC2893,4213
Physical & Enviromental
Power Input
• External Power Adapter: 100 to 240 V AC, 50 to 60 Hz
• Output: 12 V/1 A
Size
• 280 x 180 x 44 mm
MTBF
• 2,827,061 hours
Acoustics
• 0 dB
Heat Dissipation
• 31.77 BTU/hr
Weight
• 1.53kg
Ventilation
• Fanless
Operating Temperature
• -5 to 50 °C (23 to 122 °F)
Storage Temperature
• -40 to 70 °C (-40 to 158 °F)
Operating Humidity
• 10% to 90%
• EMI CE Class B, FCC Class B, VCCI, BSMI
• Safety CE LVD, UL/cUL, CB, BSMI
Çözümler
Sipariş Bilgisi
Görseller
DGS-1100-16/ME/B
Back view
View from the right
Front view
İndir
Destek Merkezi
