DGS-1210-52MP/MEProje
48 adet 10/100/1000 Full PoE Mbps ve 4 adet SFP Port Yönetilebilir L2 Metro Ethernet Anahtar
Nereden Alınır
Tanımlama
The DGS-1210/ME Series Metro Ethernet Switches are a family of Ethernet switches ideal
for Metro Ethernet applications. These Metro Ethernet Switches provide 8/16/24/48 copper
connections on upgraded Gigabit Ethernet ports, along with Gigabit SFP ports for improved
uplink bandwidth. Surge protection ensures resilience against unexpected electrical spikes,
while a full suite of security and management features keeps your network safe from internal
and external threats.
Gigabit Performance
The DGS-1210/ME Series all come with 10/100/1000 Mbps Ethernet downlink ports for superior
Gigabit performance for your network. All models offr Gigabit SFP uplink ports and the
DGS-1210-10P/ME , DGS-1210-28P/ME, DGS-1210-52P/ME, and DGS-1210-54MP/ME also
offr Power-over-Ethernet (PoE) so network devices such as PoE IP cameras can be installed in
remote locations without immediate access to power outlets. Simply use an Ethernet cable to
connect to these devices at the deployment location and it can act as a conduit not only for
data, but for power as well.
Effient and Resilient
For mission critical environments, the DGS-1210/ME Series Metro Ethernet Switches support
802.1D 2004 edition, 802.1w, and 802.1s Spanning Tree Protocols (STP). STP allows the switch
to be confiured with a redundant backup bridge path, so transmission and reception of
packets can be guaranteed in emergency situations. The switches also support 802.3ad link
aggregation, which enables multiple ports to be grouped in parallel to form a single port,
increasing bandwidth and redundancy for higher availability. These models feature 802.1p
Quality of Service (QoS), allowing for real-time traff classifiation into Weighted Round Robin
(WRR) and strict priority levels mapped to 8 queues. Packet classifiation is based on TOS, DSCP,
MAC, IPv4, VLAN ID, TCP/UDP port number, protocol type, or user-defied packet content for
flxible confiuration for specifi multimedia applications such as VoIP or IPTV
Security & Authentication
DGS-1210/ME Series Metro Ethernet Switches support 802.1X port-based/
host-based access control, guest VLAN, and RADIUS/TACACS+ authentication
for strict access control over the network. The IP-MAC-Port Binding feature
allows administrators to bind a source IP address with an associated MAC
and also to defie the port number to enhance user access control. The builtin D-Link Safeguard Engine™ protects the CPU from broadcast/multicast/
unicast floding by automatically trapping packets and logging events in
these situations. In addition, the Access Control List (ACL) feature enhances
network security and switch performance.
Management Capabilities
A web-based GUI provides a user-friendly interface and easy management,
and DHCP auto-confiuration gives administrators enhanced management
features, allowing them to save confiuration presets to a TFTP server.
Individual switches can then retrieve their IP addresses from the server and
load the preset confiuration. Support for Link Layer Discovery Protocol
(LLDP) allows a network device to advertise its identity and capabilities on the
local network, which helps businesses better manage their network topology.
Also, each port on these switches supports a cable diagnostic feature that
helps detect cable related problems such as length or cable functionality
issues, so the administrator can quickly identify and fi this problem.
Traffic & Bandwidth Control
Integrated bandwidth control allows network administrators to defie
the throughput levels for each port to manage bandwidth. It provides
minimum granularity of 64 Kbps, ingress control for port and flw-based
bandwidth control. The DGS-1210/ME Series also supports traff control,
which optimizes performance by dropping packets beyond the threshold,
and port mirroring helps administrators facilitate traff diagnostics and track
switch performance. The DGS-1210/ME Series also provides IGMP snooping
with IGMP authentication to prune multicast traff and to optimize network
performance.
Multicast Applications
The DGS-1210/ME Series Metro Ethernet Switches feature a full set of L2
multicast functions, including IGMP snooping, IGMP fitering, fast leave, and
multicast traff confiuration for specifi ports. With L2 multicast support,
the DGS-1210/ME Series is ready and capable of handling growing IPTV
applications. Host-based IGMP/MLD snooping allows for multiple multicast
subscribers per physical interface, and ISM VLAN sends multicast streams in
a multicast VLAN, saving bandwidth on the backbone network. ISM VLAN
profies allow users to bind/replace the predefied multicast registration
information to subscriber ports quickly and easily.
Genel Özellikler
Fiziksel Özellikler
Interface
Size
Width for 19 "standard rack, 1U height
Interface
• 48-port 10/100BASE-TX PoE
• 4-port 100/1000 SFP
The console port
RJ-45
Performance
• Switch fabric: 56 Gbit / s
• The speed forwarding 64-byte packets: 41.77 Mpps
• Size of the MAC Address Table: 16K
• SDRAM for CPU: 128 MB
• Packet Buffer: 1.5 MB
• Flash-Memory: 32 MB
• Jumbo-frame: 9216 bytes
Software
Layer 2 Features
• MAC Address Table: 16K
• Flow control:
  - 802.3x Flow Control
  - HOL blocking prevention
• Jumbo-size frames: 9216 bytes
• Spanning Tree:
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
  - Filtering BDPU
  - Root Restriction
• The Loopback Detection
• Aggregation:
  - Compatible with 802.3ad
  - Max. number of groups - 8, 8 ports per group
• Port mirroring:
  - Support group 1 mirroring
  - Modes: One-to-One, Many-to-One, Flow-based (ACL)
Multicast Layer 2
• IGMP Snooping:
  - IGMP v1/v2/v3 Snooping
  - Support for 256 groups
  - IGMP Snooping Fast Leave host-based
• IGMP Autentiifkatsiya
• Limit multicast to IP-addresses
• MLD Snooping:
  - MLD v1/v2 Snooping
  - MLD Snooping Fast Leave host-based
VLAN
• 802.1Q Tagged VLAN
• Group VLAN:
  - Max. 4K VLAN
• VLAN port-based
• GVRP:
  - Max. 255 Dynamic
VLAN
• VLAN Trunking
• ISM VLAN
• Double VLAN (Q-in-Q)
 - Q-in-Q Port-Based
Quality of service (QoS)
• Bandwidth Management:
  - Port-based (Ingress / Egress, with steps down to 64 kbit / s)
• 8 queues per port
• Processing of queues:
  - Strict Priority
  - Weighted Round Robin (WRR)
• CoS based on:
  - Switch Port
  - 802.1p
  - VLAN ID
  - The MAC address
  - IP-address
  - DSCP
  - The type of protocol
  - TCP / UDP-port
  - High traffic
• Support for the following streams:
  - Set the 802.1p priority tags
  - Add a tag TOS / DSCP
  - Bandwidth Management
Access Control Lists (ACL)
• Up to 256 Access Rules
• ACL based on:
  - Switch Port
  - 802.1p Priority
  - VLAN ID
  - The MAC address
  - Ether Type
  - IPv4-address
  - DSCP
  - Non TCP / UDP port
  - The contents of the package, the user-defined
• Statistics ACL
• Filtering CPU interface
Safety
• SSH v2
• SSL v3
• Port Security
  Up to 64 MAC addresses per port
• Protection from a broadcast / multicast / unicast storm
• Traffic Segmentation
• IP-MAC-Port Binding (IMPB):
  - Checking the ARP packets
  - Check the IP packet
  - DHCP Snooping
• D-Link Safeguard Engine
• DHCP Server Screening
• Filtering DHCP-client
• Prevent ARP Spoofing
• Prevention BPDU attacks
• Prevent DoS attacks
AAA
• 802.1X:
  - Access control based on port
  - Based Access Control Host
• Guest VLAN
• Local / RADIUS /
TACACS + servers
• Record keeping RADIUS
• 4 levels of user account
OAM
• Cable Diagnostics
• 802.3ah D-link Unidirectional Link Detection (DULD) 2
Management
• Web-interface
• Command Line Interface (CLI)
• Telnet-server/klient
• TFTP-client
• SNMP v1/v2c/v3
• SNMP Traps
• The system log
• RMON v1:
  - Support for groups 1, 2, 3, 9
• RMON v2:
  - Support Group
ProbeConfig
• LLDP
• BootP / DHCP-Client
• DHCP automatically
• DHCP Relay
• DHCP Relay Option 12
• DHCP Relay Option 82
• Adding a tag PPPoE Circuit-ID
• Dual Configurations
• SNTP
• CPU Monitoring
• Encrypt passwords
MIB
• RFC RFC1065, 1066, 1155, 1156, 2578 MIB Structure
• RFC 1212 Concise MIB
Definitions
• RFC1213 MIB II
1215 • RFC MIB Traps
Convention
• RFC1493 Bridge MIB
• RFC1157, 2571-2576 SNMP MIB
• RFC1907 SNMPv2 MIB
• RFC1757, 2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, 1643, 1650, 2358, 2665 Ether-like MIB
RFC
• RFC2674 802.1p MIB
• RFC 2233, 2863 IF MIB
• RFC 2925 Ping and Traceroute MIB
• Private MIB
Standard IETF ®
• RFC 768 UDP
• RFC 791 IP
• RFC 792, 2463, 4443
ICMPv4
• RFC 793 TCP
• RFC 826 ARP
• RFC 2474, 3168, 3260
Determination of the DS field in the IPv4 header and IPv6
• RFC1321, 2284, 2865, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC2571, RFC2572, RFC2573, RFC2574 SNMP
Fiziksel Özellikler
Indicators
• Power (per device)
• Link / Activity / Speed
MTBF
257.252 hours
Noise level
50.1 dB
Heat release
1648,9 BTU / h
Input voltage
100-240 VAC, 50-60 Hz, max. 0,27 A
Power consumption
• PoE On: 483.1 Watts
• PoE Off: 48.9 Watts
Measurements
440 x 430 x 44 mm
Ventilation system
Passive
Surge protection
All Ethernet ports support the standard IEC61000-4-May 10 / 700us integrated surge protection 6 kV
Operating temperature
-5-50 ° C
Storage temperature
-40-70 ° C
Operating Humidity
10% ~ 90% RH
EMI
FCC class A, CE class A, VCCI, C-Tick, BSMI, CCC
Safety
CCC, CE LVD, UL/cUL
Çözümler
Sipariş Bilgisi
Görseller
DGS-1210-52MP/ME/A
Front view
View from the right
Back view
İndir
Destek Merkezi
