DGS-1210-52MP/CProje
44 Port 10/100/1000 Mbps Full PoE ve 4-port SFP Web Smart Anahtar
Nereden Alınır
Tanımlama
D-Link’s DGS-1210 Series Web Smart Switches are the latest generation of switches featuring
D-Link Green Technology. The DGS-1210 Series integrates advanced management as
well as security functions that provide performance and scalability. Management options
for the switch include SNMP, Web Management, D-Link Network Assistant Utility,
and compact command lines. The DGS-1210 Series uses Auto Voice VLAN, ensuring bandwidth
is prioritized for a smoother voice performance. The DGS-1210-10/10P/20/28 features a fanless
design that allows for quieter operation and helps to extend the device’s lifetime, while the
DGS-1210-28P/52/52P/52MP feature a smart fan design that powers on after the switch reaches
a certain temperature, saving energy and cutting costs without sacrifiing performance.
Energy Saving
Incorporating D-Link Green technology, the DGS-1210 Series switches are capable of powersaving without sacrifiing operational performance or functionality. Link status drastically
reduces power consumption by automatically toggling ports without a link to sleep mode.
The DGS-1210 Series takes the approach to green IT one step further by incorporating a special
chipset with advanced silicon technology for effient use of energy.
Extensive Management and Layer 2 Features
Equipped with a complete lineup of L2 features, the DGS-1210 Series includes IGMP snooping,
port mirroring, spanning tree protocol and Link Aggregation Control Protocol (LACP). The IEEE
802.3x flw control function allows servers to directly connect to the switch for fast, reliable
data transfers. At 2000 Mbps full duplex, the Gigabit ports provide high-speed data pipes to
servers with minimum impact to data transfer fielity. Network maintenance features include
loopback detection and cable diagnostics. Loopback detection is used to detect loops created
by a specifi port and automatically shut down the affcted port. The cable diagnostic feature,
designed primarily for administrators and customer service representatives, can rapidly discover
errors and determine the cable quality, allowing hassle free diagnostics and maintenance.
QoS, Bandwidth Control
The DGS-1210 Series supports Auto Surveillance VLAN (ASV), and Auto Voice
VLAN, which are best suited for VoIP and video surveillance deployments.
Auto Surveillance VLAN is a new, industry-leading technology that the
DGS-1210 Series Web Smart Switch provides. This technology consolidates
data and surveillance video transmission through a single DGS-1210 Series,
thus sparing businesses the expense of dedicated hardware and facilities.
ASV also ensures the quality of real-time video for monitoring and control
without compromising the transmission of conventional network data.
The Auto Voice VLAN technology enhances the VoIP service by automatically
placing voice traff from an IP phone to an assigned VLAN. With higher priority
and individual VLAN, these features guarantee the quality and security of VoIP
traffi The DSCP markings on Ethernet packets enable diffrent levels of service
to be assigned to network traffi As a result, these voice and video packets take
precedence over other packets. In addition, with bandwidth control, network
administrators can reserve bandwidth for important functions that are higher
priority or require a larger bandwidth.
Secure your Network
D-Link’s innovative Safeguard Engine protects the switches against traff
floding caused by virus attacks. The DGS-1210 Series supports 802.1X port
based authentication, allowing the network to be authenticated through
external RADIUS servers. In addition, the Access Control List (ACL) feature
enhances network security and helps to protect the internal IT network. The
DGS-1210 Series includes ARP spoofig prevention, which protects from
attacks on the network that may allow an intruder to snif data frames, modify
traffi or bring traff to a halt altogether by sending fake ARP messages. To
prevent ARP spoofig attacks, the switch uses packet control ACLs to block
invalid packets that contain fake ARP messages. For added security, the DHCP
server screening feature routes DHCP server packets from user ports to prevent
unauthorized IP assignment.
Versatile Management
The DGS-1210 Series provides a D-Link Network Assistant Utility that enables
administrators to remotely control their network down to the port level. The
D-Link network assistant utility allows customers to easily discover multiple
D-Link Web Smart Switches within the same L2 network segment. With
this utility, users do not need to change the IP address of their PC. It also
simplifis the initial setup by taking switches, within the same L2 network
segment, that are connected to the user’s PC, and displaying them on screen
for instant access. This allows extensive switch confiuration and basic setup
of discovered devices, including password changes and fimware upgrades.
The DGS-1210 Series also supports D-View 6.0 and Compact Command Line
Interface (CLI) through Telnet. D-View 6.0 is a network management system that
allows for the central management of critical network characteristics such as
availability, reliability, resilience, and security.
Seamless Integration
The DGS-1210 Series comes with Ethernet and Gigabit copper ports capable
of connecting to existing Cat5 twisted-pair cables. Additionally, with
its 8/16/24/48 10/100/1000 Mbps plus four 1G SFP ports for the DGS-1210-
20/28/52 models; plus two 1G SFP ports for the DGS-1210-10/10P and 24/48
10/100/1000 Mbps PoE plus four 1G SFP ports for the DGS-1210-52MP/28P/52P
models, the switch can provide a more flxible solution for upstream or
downstream server connections.
Genel Özellikler
Fiziksel Özellikler
Interfaces
• 44-port 10/100/1000 Mbit / s PoE Ports
• 4 SFP-port
Standards and function ports
• IEEE 802.3i 10BASE-T Ethernet (copper twisted-pair)
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper twisted-pair)
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (copper twisted-pair)
• Compliance with IEEE 802.3az
• Auto-negotiation
• IEEE 802.3x flow control
IEEE 802.3at (1-8 ports) IEEE 802.3af (9-48 ports)
Network Cables
• UTP category. 5, 5e (max. 100 m)
Full / half duplex
• Full / half duplex for speed 10/100 Mbit / s
• Full duplex for Gigabit speed
Enhanced interface
• Auto detection of MDI / MDIX on all ports through twisted-pair
Performance
• Switch Fabric: 104 Gb / s
• Switching Method: Store-and-forward
• MAC-address table: 16 000 entries per device
• Update MAC-addresses: Up to 256 static MAC-address records
• Speed ​​forwarding 64-byte packets: 77.4 Mbit / s
• Packet Buffer: 3.0 MB
• RAM: 128 MB
• Flash-Memory: 16 MB
Software
Layer 2 functions
• MAC-address table: 16K entries
• IGMP Snooping
o IGMP v1 / v2 Snooping
o Support for up to 256 IGMP-groups
o Support for up to 64 static multicast groups
o IGMP on VLAN
o Support for IGMP Snooping Querier
• Loopback Detection is
• 802.3ad Link Aggregation: Max. 14 groups per device / 8 ports per group
• LLDP
• LLDP-MED
• Jumbo-frame
o Up to 9,216 bytes
• Spanning Tree Protocol
o 802.1D STP
o 802.1w RSTP
• Flow Control
o 802.3x
o HOL Blocking Prevention
• Port Mirroring
o One-to-One
o Many-to-One
o Support for mirroring for inbound / outbound / traffic in both directions
• Multicast Filtering
o Forward all unregistered groups
• Filters all unregistered groups
• Customizable Interface MDI / MDIX
o MLD snooping v1 / v2 (256 groups)
VLAN
• 802.1Q
• VLAN Group
o Max. 256 static VLAN-groups
• Custom VID: 1 - 4094
• Asymmetric VLAN
• Auto Voice VLAN
o Max. number of user-defined OUI: 10
o Max. OUI number Default: 8
• Auto Surveillance VLAN
Quality of Service (QoS)
• 802.1p
• 8 queues per port
• Mechanisms queuing
o Strict
o Weighted Round Robin (WRR)
• Bandwidth Management
o On the basis of the port (in / out, with a minimum of 64 kbit / s for 10/100/1000)
• QoS on the basis of:
o 802.1p Priority Queues
o DSCP
o ToS
o IPv6-Class Traffic
o Non TCP / UDP-port
Function level 3
• IP-interface
• Support for 1 interface
Access Control Lists (ACL)
• Max. number of access lists: 50
• Max. number of rules for IPv4, MAC and IPv6: 768
• Each rule can be bound to the same port
• ACL based on:
o VLAN
o MAC-address
• Ether type
• IP-address
• DSCP
• Type of protocol
• Non TCP / UDP-port
• IPv6-Class Traffic
Security
• Protection from the broadcast / multi-address / unicast storm
• D-Link Safeguard Engine
• DHCP Server Screening
• Binding IP-MAC-Port (Intelligent bindings)
o Support 512 entries bindings
o Inspection ARP-packet
o Inspection ARP-packets + IP-packet
o Support for DHCP Snooping
• Access Control 802.1X port-based
• Prevent ARP Spoofing Attacks
o Max. number of records: 64
• Segmentation of traffic
• SSH v2
• SSL
o Support for v1 / v2 / v3
• Port Security
o Support for up to 64 MAC-addresses per port
• Detection of problems associated with the coincidence of network addresses
AAA
• Authentication 802.1X:
o Support local database / RADIUS-server
o Support for access control based on ports
• Support for EAP, OTP, TLS, TTLS, PEAP
• RADIUS-server with support for IPv6
• Support for MD5 authentication
Standard MIB / RFC
• RFC 783 TFTP
• RFC 951 BootP / DHCP Client
• RFC 1157 SNMP v1, v2, v3
• RFC 1213 MIB II
• RFC 1350 TFTP
• RFC 1493 Bridge MIB
• RFC 1769 SNTP
• RFC 1542 BootP / DHCP Client
• RFC 1901 SNMP v1, v2, v3
• RFC 1907 SNMP v2 MIB
• RFC 1908 SNMP v1, v2, v3
• RFC 2131 BootP / DHCP Client
• RFC 2138 RADIUS Authentication
• RFC 2139 RADIUS Authentication
• RFC 2233 Interface Group MIB
• RFC-2246 SSL
• RFC 2475
• RFC 2570 SNMP v1, v2, v3
• RFC 2575 SNMP v1, v2, v3
• RFC 2598 CoS
• RFC 2618 RADIUS Authentication
• RFC 2819 RMON v1
• RFC 2865 RADIUS Authentication
• RFC 3164 System Log
• RFC 3195 System Log
• RFC 3411-17 SNMP
• D-Link Private MIB
• LLDP MIB
• Zone Defense MIB
• 2233 Interface Group MIB
OAM
• Diagnostic cable
• Restore the factory default settings
Management
• Web-interface
• Utility D-Link Network Assistant
• Command Line Interface (CLI)
• Telnet-server
• TFTP-client
• Configurable MDI / MDIX
• SNMP
o Support for v1 / v2c / v3
• SNMP Trap
• Backup / software update
• The Wizard Smart Wizard
• Download / upload the configuration file
• System log
o Max. count of log entries: 500
• BootP / DHCP-client
• SNTP
• ICMP v6
• Support protocol stack IPv4 / v6
• Automatic configuration via DHCP
• Setting the time
o SNTP
• RMONv1
• Trusted Host
Technology Green V3.0
• Energy savings based on:
o Identify the connection status
o PoE schedule
• Turn off the indicators
• Sleep mode
• Turning off the port
Fiziksel Özellikler
Power Input
100-240 VAC, 50-60 Hz, internal universal power supply
Power consumption in standby mode
483.1 W / PoE On - 48.9 W / PoE Off
The noise level
50.1 dB (A)
Heat Dissipation
912.96 BTU / h
Operating Temperature
From -5 ° to 50 ° C
Storage Temperature
From -20 ° to 70 ° C
Operating Humidity
From 0% to 95% non-condensing
Storage Humidity
Dimensions
440 mm x 430 mm x 44 mm
Weight
5.66 kg
Indicators
Link / Activity / Speed ​​(at 10/100/1000 Mbit / s)
Certificates
• CE Class A
• VCCI Class A
• FCC Class A
• BSMI
• CCC
• C-Tick
MTBF (hours)
360000
Security
• cUL
• CE (LVD)
• CSS
Çözümler
Sipariş Bilgisi
Görseller
DGS-1210-52MP/C/F
Back view
View from the right
Front view
İndir
Destek Merkezi
