Hızlı Arama
Ürün Özellikleri:
20 port 10/100/1000 Mbps port ve 4 combo port 100/1000 Base-T / SFP ve 2 port 10G SFP+ Yığınlanabilir L2+ Anahtar
Genel Özellikler:
Fiziksel Özellikler
nterface
Type of Ports available
  •  20-Port 10/100/1000 Base-T
  •  4-Port Combo 10/100/1000BASE-T/SFP
  •  2-Port 10G SFP+
Performance
Switching Capacity
  • 88 Gbps
64 Byte Packet Forwarding Rate
  •  65.48 Mpps
MAC Address Table Size
  • 16K
Web-Based GUI
  • Yes
DRAM for CPU
  • 128 MB
Packet Buffer Memory
  • 1.5 MB
Flash Memory
  • 32 MB
Jumbo Frame
  • 12,288 Bytes
Physical
MTBF(hours)
  • 472842.5 h
Heat Dissipation
  • 100.94 Btu/h
Power Input
  • AC Input 100 to 240 V AC, 50 to 60 Hz Internal Universal Power Supply
Max Power Consumption
  • 29.6 W
Dimensions
  •  (W x D x H) 441 x 209.9 x 44 mm
Weight
  • 2.05 kg
Ventilation
  • Smart Fan
  • (High Speed at > 40°C; Low Speed at < 35°C)
Power Surge Protection
  •  All Ethernet ports support IEC61000-4-5 10/700us 6 kV surge protection
Operation Temperature
  • 0 to 50°C (32 to 122°F)
Storage Temperature
  •  -40 to 70°C (-40 to 158°F)
Operation Humidity
  •  10% to 90% RH
Storage Humidity
  • 5% to 90% RH
Emission (EMI)
  • CE, FCC, IC, C-Tick, VCCI, BSMI
Safety
  • CB, UL/cUL, BSMI
Certifications
  • IPv6 Ready Logo
Ürünler | Destek  | Haberler  | Hakkında |
