Hızlı Arama
Ürün Özellikleri:
12 adet Combo SFP / 1000Base-TX L3 Yığınlanabilir L3 Anahtar
EOL
Genel Özellikler:
Fiziksel Özellikler
Interfaces • 12 Combo ports 1000BASE-T/SFP port • 1 console port RS-232 for • 1 port out of band management RJ-45 connector Performance • Fabric: 24 Gbps • The forwarding rate of packets: 17,86 million packets • Processor: 266 MHz • Buffer: 1 MB • Flash memory: 32 MB • MEMORY DRAM: 128 MB Food • Internal power supply • AC: 100~240 V, 50/60 Hz • DC: 36~72 In Software OAM • Function Loopback Diagnostics • Cable diagnostics • In connection 802.3 AH Ethernet OAM • D-link Unidirectional connection Detection (DULD) • Protection from broadcast/ lot-address/unicast storm • Gasps • 802.1 AG connectivity fault management (CFM) • ITU-T Y. 1731 Features D-Link Green • Reduced energy consumption on the basis of the connection status • 802.3 AZ energy efficiency Ethernet Management • Web-based GUI (Supports IPv4/V6) • Command line interface the command line interface CLI • Telnet server (Supports IPv4/V6) • Telnet client (Supports IPv4/V6) • TFTP client (Supports IPv4/V6) • Zmodem Protocol • SNMP v1/v2c/V3, • SNMP over IPv6 • SNMP traps • System Log • RMON V1: - Supports 1,2,3,9 groups • RMON v2: - Supports ProbeConfig group • support sflow • Protocol lldp • A bootp and DHCP client • Autoconfiguration via DHCP • DHCP relay (Support IPv4/V6) • DHCP relay option 60, 61, 82 • DHCP-server • Support for multiple copies • Support for multiple versions of configurations • Monitoring the CPU usage • DNS relay • Sntp • Password recovery • Password encryption • Microsoft® NLB (network load Balancing) • Ping (Support for IPv6/V4) • Trace (IPv6/V4) Safety • The SSH Protocol v2 and • SSL version 3 • Port Security • Protection from broadcast/ lot-address/unicast storm • Traffic segmentation • IP-Mac-port binding - Check ARP packets - Verification of IP packets - DHCP snooping - IPv6 ND snooping - Supports up to 500 entries per device • D-Link Motor Protection • Filtering NetBIOS/Netbeui • DHCP server screening • Protection against attacks BDPU • Attack prevention ARP Spoofing AAA • 802.1 x - Access control port-based - Access control based on host - Authentication Database Failover - The policy on the basis of the identification data (VLAN, configure the ACL or QoS) for • Access control web-based (WAC): - Access control port-based - Access control based on host - Authentication Database Failover - The policy on the basis of the identification data (VLAN, configure the ACL or QoS) for • Access control based on MAC-addresses (MAC): - Access control port-based - Access control based on host - Authentication Database Failover - The policy on the basis of the identification data (VLAN, configure the ACL or QoS) for • Integrated Authentication • Guest VLAN with • Microsoft®NAP • Supports 802.1 X nap • Radius • Tacacs servers • XTACACS • Servers tacacs+ • Radius Accounting • Accounts with 3 levels of access rights • Trusted Host Layer 3 features • Max. number of IPv4/V6-interfaces: 32 • Detect IPv6 neighbors (ND) The layer 3 routing Up to 32 static routes for IPv4/V6 Quality of service (QoS)for • IEEE 802.1 p • Dscp field • Up to 8 queues per port • Mechanisms of queue processing - Strict Priority Cyclic weighted algorithm (wrr) - Strict + wrr speed limit • Соs on the basis of: - switch port - THE VLAN IDENTIFIER - priority queue 802.1 p - Mac-address - IPv4/V6 addresses in - Field dscp - Protocol type - class of IPv6 traffic - IPv6 flow label in - TCP or udp port - the contents of the package, user-defined • Supports following actions for flows - Add tag priority 802.1 p - Add tag priority TOS/dscp for - Bandwidth management - Flow statistics • Three color marker - trTCM - srTCM • Bandwidth management - based on the port (Inbound/ Outbound, min. step up to 64 Kbit/s) - on the basis of the flow (Inbound/ Outbound, min. step up to 64 Kbit/s) • QoS time-based The access control lists (ACL) for • Up to 1500 access rules • ACL based on: - Priority 802.1 p - THE VLAN IDENTIFIER - Mac-address Ether Type - IPv4/V6 addresses in - Field dscp - Protocol type - the number of the TCP or udp port - class of IPv6 traffic - IPv6 flow label in - the contents of the package, user-defined • Statistics for ACL • ACL based on time • CPU Interface filtering Stacking • Virtual stacking: Technology D-link single IP Management (SIM) - Up to 32 devices in a virtual stack Layer 2 features • Table MAC-addresses: 16K • Flow control - Flow control 802.3 x - Prevent lock hol • The Jumbo frame up to 13,312 bytes • Spanning Tree - 802.1 D STP WITH - 802.1 W RSTP - 802.1 s MSTP - Filtering BDPU - Root Restriction • Detection Loopback • 802.3 AD link aggregation - Max. 6 groups per device, 8 ports per group • Port mirroring - One-to-one - Many-to-one - Per-flow - RSPAN • Ethernet ring protection switching (ERPs) • Protocol tunneling layer 2 Multicast layer 2 • IGMP snooping - IGMP V1/V2/v3 snooping - Supports 1024 IGMP groups - Quickly leave port-based/host • MLD snooping - MLD V1/V2 snooping - Supports up to 1024 groups - Quickly leave port-based/host • IGMP/mld proxy reporting • IGMP filtering for - up to 60 profiles filtering IGMP - 128 ranges per profile VLAN • Group VLAN - Max. 4K VLAN groups • Enhanced performance - Support 4K dynamic VLAN groups • 802.1 Q tagged VLAN • Double VLAN (Q-in-Q) - Port-based Q-in-Q - Selective Q-in-Q • VLAN translation for packets with one/two marks with VLAN • Voice VLAN • VLAN based on MAC addresses • VLAN-based subnet • ISM VLAN MIB • RFC1065, 1066, 1155, 1156, 2578 MiB structure • RFC1212 concise MIB definitions • RFC 1213 MIB II • RFC4022 MiB for TCP • RFC4113 MiB for udp • RFC4293 IPv6 SNMP mgmt interface MiB • RFC 1493 bridge MiB • Snmpv3 MiB RFC 2571-2576 • RFC271, 1757, 2819 RMON MIB CAN • RFC 2021 RMONv2 MIB • RFC 1398, 1643, 1650, 2358, 2665 ether-like MiB • RFC2668, 4836 802.3 MAU " MIB • RFC 2674, 4363 q-bridge / P-bridge MIB • RFC4318 RSTP MIB • RFC 2233, 2863 the interfaces Group MiB • Link aggregation LAG-MIB • IEEE8021 PAI MIB • RFC2618 RADIUS • Authentication client MIB • RFC 2620 Radius accounting client MiB • RFC 2925 ping & Traceroute MIB • LLDP MIB • SUPPORT LLDP-EXT-DOT1MIB • SUPPORT LLDP-EXT-DOT3MIB • SUPPORT LLDP-EXT-MED " MIB • DOT3 OAM MIB • D-link private MiB Standards compliance RFC • RFC768 UDP • RFC 791 IP • RFC792 ICMPv4 • RFC2463, 4443 icmpv6 • RFC4884 in Extended ICMP to support Multi-part messages • RFC793 TCP • RFC826 ARP • RFC1981 path mtu • Opening for IPv6 • RFC2462, 4862 IPv6 stateless persons • Address Auto-Configuration • RFC2464 IPv6 over Ethernet and definition • RFC3513, 4291 IPv6 • Addressing Architecture • RFC2893, 4213 IPv4 / IPv6 dual stack function • RFC2474, 3168, 3260 IPv6 • Differentiated services field • IPv6 ready logo phase 2 router mode • MEF9,14 EPL AND EVPL, ELAN WITH The physical parameters and operating conditions Sizes 441 x 210 x 44 mm Weight 3.4 kg Operating temperature From 0 to 65, Storage temperature -40 to + 70C Operating humidity 10% to 90% non-condensing Storage humidity 5% to 90% non-condensing Emission (EMI) FCC class A, CE, C-Tick, VCCI Safety cul, CB Max. power consumption • 28 W at 110 VAC • 27 W at 48 VDC Certificates IPv6 ready logo phase 2 and mef 9,14 EPL and EVPL, Elan with
Ürünler | Destek  | Haberler  | Hakkında |
