Ürün Özellikleri:
28-Port Layer 3 Stackable Managed Gigabit Switch including 4 10GbE Ports |
Genel Özellikler:
Fiziksel Özellikler Technical Specifications Interfaces • 10/100/1000BASE-T Ports • 20 (DGS-3630-28TC) • 44 (DGS-3630-52TC) • Gigabit SFP Ports • 20 (DGS-3630-28SC) • Combo 10/100/1000BASE-T or SFP Ports • 4 (all models) • 10 Gigabit SFP+ Ports • 4 (all models) • Console Port • RJ45 and Mini USB console ports for out-of-band CLI management • Management Port • 10/100/1000BASE-T RJ45 Ethernet for out-of-band IP management • Alarm Port • RJ45 • USB Port • USB 2.0 Type A • Optional Redundant Power Supply • DPS-500A Performance • Switch Capacity • 128 Gbps (DGS-3630-28TC) • 128 Gbps (DGS-3630-28SC) • 176 Gbps (DGS-3630-52TC) • Packet Forwarding Rate • 95.24 Mpps (DGS-3630-28TC) • 95.24 Mpps (DGS-3630-28SC) • 130.95 Mpps (DGS-3630-52TC) • Packet Buffer • 4 MBytes (DGS-3630-28TC) • 4 MBytes (DGS-3630-28SC) • 4 MBytes (DGS-3630-52TC) • MAC Address Table • 68K entries2 (DGS-3630-28TC) • 68K entries2 (DGS-3630-28SC) • 68K entries2 (DGS-3630-52TC) • IPv4 Routing Table • 16K entries (DGS-3630-28TC) • 16K entries (DGS-3630-28SC) • 16K entries (DGS-3630-52TC) • IPv6 Routing Table • 7K entries (DGS-3630-28TC) • 7K entries (DGS-3630-28SC) • 7K entries (DGS-3630-52TC) • IPv4 Forwarding Table • 32K entries2 (DGS-3630-28TC) • 32K entries2 (DGS-3630-28SC) • 32K entries2 (DGS-3630-52TC) • IPv6 Forwarding Table • 16K entries2 (DGS-3630-28TC) • 16K entries2 (DGS-3630-28SC) • 16K entries2 (DGS-3630-52TC) • Jumbo Frame Size • 12 KBytes (DGS-3630-28TC) • 12 KBytes (DGS-3630-28SC) • 12 KBytes (DGS-3630-52TC) Physical and Environmental • MTBF • 300,190 hours (DGS-3630-28TC) • 280,612 hours (DGS-3630-28SC) • 263,936 hours (DGS-3630-52TC) • Acoustics • 52.7 dB(A) (DGS-3630-28TC) • 56 dB(A) (DGS-3630-28SC) • 53.9 dB(A) (DGS-3630-52TC) • Heat Dissipation • 145 BTU/hr (DGS-3630-28TC) • 217 BTU/hr (DGS-3630-28SC) • 212 BTU/hr (DGS-3630-52TC) • Power Input • 100 to 240 VAC, 50/60 Hz • Max Power Consumption • 42.4 W (DGS-3630-28TC) • 63.6 W (DGS-3630-28SC) • 62.0 W (DGS-3630-52TC) • Standby Power Consumption • 28.1 W (DGS-3630-28TC) • 30.1 W (DGS-3630-28SC) • 36.0 W (DGS-3630-52TC) • Dimensions • 17.4 x 10.2 x 1.73 inches (441 x 260 x 44 mm) • Weight • 8.25 lbs (3.74 kg) (DGS-3630-28TC) • 8.36 lbs (3.79 kg) (DGS-3630-28SC) • 8.91 lbs (4.04kg) (DGS-3630-52TC) • Ventilation • 2 Smart Fans3 • Operating Temperature • 23°F to 122°F (-5°C to 50°C) • Storage Temperature • -40°F to 158°F (-40°C to 70°C) • Operating Humidity • 10% to 95% RH • Storage Humidity • 5% to 95% RH • Safety Certifications • cUL, CB, CE, CCC, BSMI • EMI/EMC • CE, FCC Class A, C-Tick, VCCI, BSMI, CCC Software Features Standard Image (SI) Stackability • Physical stacking • Up to 80G stacking bandwidth • Up to 9 switches in a stack • Ring/chain topology support • Virtual Stacking/clustering of up to 32 units • Supports D-Link single IP Management • Up to 20 Gbps stacking bandwidth L2 Features • MAC Address Table : up to 68K entries2 • Flow Control • 802.3x Flow Control when using Full Duplex • HOL Blocking Prevention • Spanning Tree Protocol • 802.1D STP • 802.1w RSTP • 802.1s MSTP • Root Guard • Loop Guard • Jumbo Frame: up to 12 KBytes • 802.1AX Link Aggregation • Max. 32 groups per device, 8 ports per group • ERPS (Ethernet Ring Protection Switching) version 2 • Port Mirroring • Supports One-to-One, Many-to-One • Supports Mirroring for Tx/Rx/Both • Supports 4 mirroring groups • Flow Mirroring • Supports Mirroring for Rx • VLAN Mirroring • RSPAN • L2 Protocol Tunneling VLAN • 802.1Q • 802.1v Protocol-based VLAN • Double VLAN (Q-in-Q) • Port-based Q-in-Q • Selective Q-in-Q • Port-based VLAN • MAC-based VLAN • Subnet-based VLAN • Private VLAN • VLAN Group • Max. 4K VLAN groups • Max. 4094 VIDs • Multicast VLAN (ISM VLAN for IPv4/IPv6) • Voice VLAN • Auto Surveillance VLAN • VLAN Trunking • GVRP: Up to 4K dynamic VLANs • Asymmetric VLAN L2 Multicast • MLD Snooping • MLD v1/v2 Snooping • Supports up to 4K MLD groups2 • Host-based MLD Snooping Fast Leave • Supports 64 static MLD groups • MLD Snooping Querier • Per VLAN MLD Snooping • MLD Proxy Reporting • IGMP Snooping • IGMP v1/v2/v3 • Supports up to 8K MLD groups2 • Supports 64 static IGMP groups • Per VLAN IGMP Snooping • IGMP Snooping Querier • Host-based IGMP Snooping Fast Leave • PIM Snooping L3 Features • IPv4 ARP/IPv6 ND: support up to 32K/16K2 • 512 Static ARP • Gratuitous ARP • IP Interface • Supports 256 interfaces • Loopback Interface • Proxy ARP • Support local ARP proxy • IPv6 Tunneling • Static • ISATAP • GRE • 6to4 • VRRP v2/v3 • IP Helper L3 Routing • Supports 16K hardware routing entries shared by IPv4/IPv6 • 1 entry consumed by each IPv4 route • 2 entries consumed by each IPv6 route • Supports up to 32K hardware L3 forwarding entries shared by IPv4/IPv62 • 1 entry consumed by each IPv4 route • 2 entries consumed by each IPv6 route • Static Route • Max. 512 IPv4 entries • Max. 256 IPv6 entries • IPv4/IPv6 Default Route • PBR (Policy-based Route) • Null Route • Route Preference • Route Redistribution • Graceful Restart (GR) Helper • BFD (Bidirectional Forwarding Detection) • IPv4/v6 Static Route • RIP • VRRP • RIPv1/v2/ng L3 Mulitcast • IGMP/MLD Filtering QoS (Quality of Service) • 802.1p • 8 queues per port • Queue Handling • Strict Priority (SP) • Weighted Round Robin (WRR) • Strict + WRR • Weighted Deficit Round Robin (WDRR) • Congestion Control • Weighted Random Early Detection (WRED) • 802.1Qbb Priority-based Flow Control (PFC) for 10 GbE port • Bandwidth Control • Port-based (Ingress/Egress, min. granularity 8 Kb/s) • Flow-based (Ingress/Egress, min. granularity 8 Kb/s) • Per queue bandwidth control (min. granularity 8 Kb/s) • Policy Map • Remark 802.1p priority • Remark IP precedence/DSCP • Time based QoS • CoS based on: • Switch Port • Inner/ outer 802.1p Priority • Inner/ outer VID • MAC address • Ether Type • IP address • ToS/IP Preference • DSCP • Protocol Type • TCP/UDP port • IPv6 Traffic Class • IPv6 Flow Label • Three Color Marker • trTCM • srTCM ACL (Access Control List) • ACL based on: • 802.1p priority • VID • MAC address • EtherType • LLC • VLAN • IP address • IP preference/ToS • DSCP mask • Protocol type • TCP/UDP port number • IPv6 Traffic Class • IPv6 Flow Label • Max. ACL entries: • Ingress (hardware entries): 4K • Egress (hardware entries): 1K • VLAN Access Map Numbers: 3K • Time-based ACL Green • Energy Effeciency Ethernet (EEE) • Power Saving By Link Status • Power Saving By Cable Length • Power Saving By LED Shut-Off • Power Saving By Port Shut-Off • Power Saving By System Hibernation Security • Port Security • Supports up to 12K MAC addresses per port/VLAN/system • Broadcast/Multicast/Unicast Storm Control • D-Link Safeguard Engine • DHCP Server Screening • Dynamic ARP Inspection • IP Source Guard • DHCP Snooping • IPv6 Snooping • Dynamic ARP Inspection (DAI) • DHCPv6 Guard • IPv6 Route Advertisement (RA) Guard • IPv6 ND Inspection • Duplicate Address Detection (DAD) • ARP Spoofing Prevention • Max. 64 entries • L3 Control Packet Filtering • Unicast Reverse Path Forwarding (URPF) • Traffic Segmentation • SSL • Supports TLS 1.0/1.1 • Supports IPv4/IPv6 access • SSH • Supports SSH v2 • Supports IPv4/IPv6 access • BPDU Attack Prevention • DOS Attack Prevention • NetBIOS/NetBEUI filtering AAA • 802.1X Authentication • Supports Port/Host-based access control • Identity-driven Policy Assignment • Dynamic VLAN Assignment • Bandwidth Control Assignment • ACL Assignment • Web-based Access Control (WAC) • Supports Port/Host-based access control • Identity-driven Policy Assignment • Dynamic VLAN Assignment • Bandwidth Control Assignment • ACL Assignment • Support IPv4/IPv6 access • Support HTTPS • Compound Authentication • MAC-based Access Control (MAC) • Supports Port/Host-based access control • Identity-driven Policy Assignment • Dynamic VLAN Assignment • Bandwidth Control Assignment • ACL Assignment • Guest VLAN • Microsoft® NAP • Support 802.1X NAP • Support DHCP NAP • Privilege Level for Management Access • RAIDUS and TACACS+ Authentication • Authentication Database Failover • RADIUS/TACACS+ Accounting OAM (Operations, Administration and Maintenance) • Cable Diagnostics • 802.3ah Ethernet Link OAM • D-Link Unidirectional Link Detection (DULD) • Dying gasp • 802.1ag Connectivity Fault Management (CFM) • Y.1731 OAM • Optical Transceiver Digital Diagnostic Monitoring (DDM) Management • NTPv3/v4 • Precision Time Protocol (PTP) • Web-based GUI • Support IPv4/IPv6 access • Support SSL (HTTPS) • Command Line Interface (CLI) • Telnet Server for IPv4/IPv6 access • Telnet Client for IPv4/IPv6 • SNMP • Support v1/v2c/v3 • Support IPv4/IPv6 access • SNMP Trap • TFTP Client for IPv4/IPv6 • FTP Client for IPv4/IPv6 • IPv4 SFTP Server • RCP • System Log for IPv4/IPv6 Syslog Server • SMTP • RMONv1 • Supports 1,2,3,9 groups • RMONv2 • Supports ProbeConfig group • Command Logging • LLDP/LLDP-MED • D-Link Discover Protocol (DDP) • DHCP Client option 12 • DHCP Auto-configuration • DHCP Auto-image • DHCP Relay option 60/61/62/18/37/125 • DHCP/DHCPv6 Local Relay • DHCP Server • Support IPv4/IPv6 address assignment • DHCPv6 Prefix Delegation (PD) • Multiple Images/ Multiple Configurations • DNS Relay for IPv4/IPv6 • DNS Client for IPv4/IPv6 • Debug Command • Password Recovery/ Encryption • Ping/ Traceroute for IPv4/IPv6 • Microsoft® Network Load Balancing (NLB) • Switch Resource Management (SRM) • sFlow • D-Link License Management System (DLMS) Enhanced Image (EI) (includes all SI features plus the following) VLAN • Super VLAN L3 Routing • BGP • BGPv4/v4+ • 4bytes AS • Text/MD5 for BGPv4 • VRF-Lite • IPv4 Static Route • RIPv1/v2 • OSPFv2 • BGPv4 • Bidirectional Forwarding Detection (BFD) for OSPF • OSPF • OSPF v2/v3 • OSPF passive interface • Stub/NSSA area • OSPF equal cost route • Text/MD5 for OSPFv2 L3 Mulitcast • IGMPv1/v2/v3 • MLDv1/v2 • IGMP/MLD Proxy • DVMRPv3 • PIM-DM/SM/SSM/SDM • SSM Mapping for IPv4/IPv6 • Multicast Source Discovery Protocol (MSDP) MIB/IETF Standards • RFC1065, RFC1066, RFC1155, RFC1156, RFC2578 MIB Structure • RFC1212 Concise MIB Definitions • RFC1213 MIBII • RFC1215 MIB Traps Convention • RFC1493, RFC4188 Bridge MIB • RFC1157, RFC2571, RFC2572, RFC2573, RFC2574, RFC2575, RFC2576 SNMP MIB • RFC1442, RFC1901, RFC1902, RFC1903, RFC1904, RFC1905, RFC1906, RFC1907, RFC1908, RFC2578, RFC3418, RFC3636 SNMPv2 MIB • RFC271, RFC1757, RFC2819 RMON MIB • RFC2021 RMONv2 MIB • RFC1398, RFC1643, RFC1650, RFC2358, RFC2665, RFC3635 Ether-like MIB • RFC2668 802.3 MAU MIB • RFC2674, RFC4363 802.1p MIB • Interface Group MIB • RFC2618 RADIUS Authentication Client MIB • RFC4022 MIB for TCP • RFC4113 MIB for UDP • RFC2620 RADIUS Accounting Client MIB • RFC2925 Ping & TRACEROUTE MIB • TFTP uploads and downloads (D-Link MIB) • Trap MIB (D-Link MIB) • RFC4293 IPv6 MIB • RFC4293 ICMPv6 MIB • Entity MIB • RIPv2 MIB • OSPF MIB • IPv4 Multicast Routing MIB • PIM MIB for IPv4 • IP Forwarding Table MIB • RFC4293 IPv6 SNMP Mgmt Interface MIB • DDM MIB (D-Link MIB) • Private MIB • MIB for D-Link Zone Defense • DDP MIB • LLDP-MED MIB • RFC791 IP • RFC768 UDP • RFC793 TCP • RFC792 ICMPv4 • RFC2463, RFC4443 ICMPv6 • RFC826 ARP • RFC1338, RFC1519 CIDR • RFC2474, RFC3168, RFC3260 Definition of the DS Field in the IPv4 and IPv6 Headers • RFC1321, RFC2284, RFC2865, RFC2716, RFC1759, RFC3580, RFC3748 Extensible Authentication Protocol (EAP) • RFC2571 SNMP Framework • RFC2572 SNMP Message Processing and Dispatching • RFC2573 SNMP Applications • RFC2574 User-based Security Model for SNMPv3 • RFC1981 Path MTU Discovery for IPv6 • RFC2460 IPv6 • RFC2461, RFC4861 Neighbor Discovery for IPv6 • RFC2462, RFC4862 IPv6 Stateless Address Autoconfiguration • RFC2464 IPv6 over Ethernet and definition • RFC2767 Dual Stack Hosts using the ‘Bump-In-the-Stack’ Technology • RFC3513, RFC4291 IPv6 Addressing Architecture • RFC2893, RFC4213 IPv4/IPv6 dual stack function • RFC3484 Default Address Selection for Internet Protocol version 6 Ordering Information DGS-3630-28TC/SI 20 10/100/1000BASE-T ports + 4 Combo 10/100/1000BASE-T/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch with Standard Image DGS-3630-28SC/SI 20 SFP ports + 4 Combo 10/100/1000BASE-T/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch with Standard Image DGS-3630-52TC/SI 44 10/100/1000BASE-T ports + 4 Combo 10/100/1000BASE-T/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch with Standard Image Warranty • Lifetime Optional License Upgrades DGS-3630-28TC-SE-LIC DGS-3630-28TC Standard Image to Enhanced Image Upgrade License DGS-3630-28TC-SE-LIC DGS-3630-28SC Standard Image to Enhanced Image Upgrade License DGS-3630-28TC-SE-LIC DGS-3630-52TC Standard Image to Enhanced Image Upgrade License Optional 10 Gpbs SFP+ Optical Transceivers DEM-431XT-DD 10GBASE-SR Transceiver, DDM, 80/300M DEM-432XT-DD 10GBASE-LR Transceiver, DDM, 10KM DEM-435XT-DD 10GBASE-LRM Transciver, DDM, 220M Optional 1 Gpbs SFP Optical Transceivers DGS-712 1000BASE-T SFP Transceiver DEM-310GT 1000BASE-LX SFP Transceiver, 10KM DEM-311GT 1000BASE-SX SFP Transceiver, up to 550M Optional 10 Gpbs Direct Attach Copper (DAC) Cables DEM-CB100S 1M (40”) 10G Direct Attach Cable for Data/Stacking DEM-CB300S 3M (118”) 10G Direct Attach Cable for Data/Stacking Optional Redundant Power Supply DPS-500A Redundant Power Supply Unit, 140 Watt RPSU Optional Management Software DV-700 D-View 7 Network Management System DV-700-N25-LIC D-View 7 NMS - 25 Node License Upgrade DV-700-N50-LIC D-View 7 NMS - 50 Node License Upgrade DV-700-N100-LIC D-View 7 NMS - 100 Node License Upgrade DV-700-N250-LIC D-View 7 NMS - 250 Node License Upgrade DV-700-N500-LIC D-View 7 NMS - 500 Node License Upgrade DV-700-N1000-LIC D-View 7 NMS - 1000 Node License Upgrade DV-700-P5-LIC D-View 7 NMS - 5 Probe License Upgrade DV-700-P25-LIC D-View 7 NMS - 25 Probe License Upgrade 1 Stacking cable and USB flash card not included. 2 Based on maximum value of Switch Resource Management (SRM). 3 By default, the fan speed is low. When the temperature inside the chassis is over 36°C, the fans switch to high speed until the temperature drops below 33°C. 4 Limited Lifetime Warranty available in USA only. |
Destek Merkezi
