DIS-PWR180ACProje
The external AC adapter AC DIS-PWR180AC is an efficient and reliable device that provides power to the DIS-200G-12PS switch.
Nereden Alınır
Tanımlama
Genel Özellikler
Fiziksel Özellikler
Hardware
output power
• 180 W
Range of input voltages
• 90 V to 264 VAC
Frequency range of input mains voltage
• 47 Hz to 63 Hz
Max. input current
• 3.34 A at 100 VAC
• 3.34 A at 240 VAC
Exit
• 54 VDC
Efficiency
• 89% (at 100 V AC)
• 92% (at 240 VAC)
Dimensions (L x W x H)
• 170 x 85 x 42.5 mm
The weight
• 0.86 kg
terms of Use
MTBF (hours)
• 500,000
Temperature
• Operating: 0 to +40 ° C
• Storage: -20 to +80 ° C
Humidity
• During operation: from 20 to 80% (without condensation)
• When stored: from 10 to 90% (without condensation)
Compatibility
• Switch DIS-200G-12PS
Çözümler
Sipariş Bilgisi
Görseller
DIS-PWR180AC
Front view
View from the right
View from the right
View from the right
İndir
Destek Merkezi
