DES-1005DEOL EOS
5-Port 10/100Mbps Switch for SOHO
Tanımlama
Tanımlama:
5 Auto-sensing 10/100Mbps Ports
Flow Control for Secure Transmission
Auto-negotiation of MDI/MDIX Cross Over
All ports support auto-negotiation of MDI/MDIX cross over. This eliminates the need for cross over cables or uplink ports. Any port can simply plug to a server, a hub or a switch, using the usual straight-through twisted-pair cable.
SOHO Plug-and-Play
Desktop Power
With low-cost connection per-port, the switch can also be set up for direct connection from the PCs. This relieves data bottleneck by giving each workstation a dedicated bandwidth on the network.
