Hızlı Arama
Ürün Özellikleri:
8-Port 10/100 Mbps Ethernet Switch with Gigabit Uplink
EOL EOS
Genel Özellikler:
Standards
- IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
- IEEE 802.3u 100BASE-TX Fast Ethernet  (twisted-pair copper)
- IEEE 802.3ab 1000BASE-T Gigabit Ethernet  (twisted-pair copper)
- ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
Protocol
CSMA/CD
Data Transfer Rates
- Ethernet:
  10Mbps (half duplex)
  20Mbps (full duplex)
- Fast Ethernet:
  100Mbps (half duplex)
  200Mbps (full duplex)
- Gigabit Ethernet:
  2000Mbps (full duplex)
Topology
Star
Network Cables
- 10BASE-T:
  2-pair UTP Cat. 3, 4, 5 (100 m)
  EIA/TIA-586 100-ohm STP (100 m)
- 100BASE-TX, 1000BASE-T:
  UTP Cat. 5 (100m max.)
  EIA/TIA-568 100-ohm STP (100m max.)
Full/half Duplex
- Full/half duplex for 10/100Mbps speeds
- Full duplex only for Gigabit speed
Media Interface Exchange
1 MDI-II/MDI-X uplink port (shared with Fast Ethernet port 8)
Twisted-pair Rx Reverse Polarity
 Auto-correction
LED Indicators
- Per 10/100Mbps port: 100Mbps speed, Link/Act
- Per Gigabit port: 1000Mbps speed, Link/Act
- Per device: Power, Alert, HTTP, ICQ, SMTP
Transmission Method
Store-and-forward
MAC Address Table
4K entries per device
MAC Address Learning
 Automatic update
Packet Filtering/Forwarding Rates (half duplex)
- Ethernet: 14,880 pps per port
- Fast Ethernet: 148,810 pps per port
- Gigabit Ethernet: 1,488,100 pps per port
RAM Buffer
2MB per device
Fiziksel Özellikler
Input
100  -  240 VAC, 50/60 Hz
Internal universal power supply
Power Consumption
12 watts (max.)
Ventilation
 40 x 40 mm DC fan x 1
Operating Temperature
0-50 C
Storage Temperature
-5 - 50 C
Humidity
5%  -  95% non-condensing
Dimensions
280 x 180 x 44 mm (11 x 7.1 x 1.8 inches) desktop size, 1 U height
Weight
1.7 kg (3.75 lb.)
Emission (EMI)
 - FCC Class B
 - CE Class B
 - C-Tick
 - VCCI Class B
Safety
 - UL/CUL
 - TUV/GS (EN60950)
Ürünler | Destek  | Haberler  | Hakkında |
