Tanımlama
This rack-mount switch offers a cost-effective and flexible way for a workgroup to benefit from the increased bandwidth of Gigabit Ethernet. It provides 24 dedicated copper Gigabit ports for server deployment and other bandwidth-intensive applications. With plug-and-play installation and copper Gigabit ports capable of connecting to your existing Cat. 5 twistedpair cable, this device instantly enhances your workgroup's performance without requiring you to go through complex reconfiguration.
24 Copper Gigabit Ports for Workgroup Connection
The switch provides 24 copper Gigabit ports. The copper Gigabit ports provide an inexpensive alternative solution to fiber-optic. Using your existing low-cost Cat. 5 copper twisted-pair wires as the transmission media, these ports allow you to instantly upgrade your servers to Gigabit capability without requiring you to install new, expensive fiber cables. All ports support 10/100/1000Mbps network speeds auto-sensing and full/half duplex auto-negotiation.
For downstream network expansion, you can also attach these Gigabit ports to 10/100Mbps switches, from which workstations can access the network.
Full-duplex Gigabit Access
The Gigabit ports provide dedicated bandwidths for servers and switch cascading running at 2000Mbps full-duplex. This provides bottleneck-free paths for fast network throughputs.
802.3x Flow Control
This function support allows your servers to directly connect to the switch for fast, reliable data transfer. At 2000Mbps full duplex, the switch provides high-speed data pipes to your servers with minimum data transfer loss.
Auto-negotiation of MDI/MDIX Cross Over
All copper connections support auto-negotiation of MDI/MDIX cross over. This eliminates the need for cross over cables or uplink ports. Any port can simply plug to a server, a hub or a switch, using the usual straight-through twisted-pair cable.
Seamless Integration
The switch integrates seamlessly with your existing network equipment, be it Ethernet, Fast Ethernet or Gigabit Ethernet, dispensing you of the need to replace any hardware or software.
Plug-and-Play Installation
With 10/100/1000Mbps auto-sensing, MDI/MDIX plugand- play for every port, plus the ability to exist with your Cat. 5 wall wiring, network installation is a breeze, all you need to do is plug the cables to the switch, and your network is up and running in a matter of minutes.
Genel Özellikler
Standards
- IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
- IEEE 802.3u 100BASE-TX Fast Ethernet (twisted-pair copper)
- IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper
- ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
Number of Ports
24 10/100/1000BASE-T ports
Protocol
CSMA/CD
Data Transfer Rates
- Ethernet: 10Mbps (half duplex)
20Mbps (full duplex)
- Fast Ethernet:
100Mbps (half duplex)
200Mbps (full duplex)
- Gigabit Ethernet:
2000Mbps (full duplex)
Topology
Star
Network Cables
- 10BASE-T:
UTP Cat. 3, 4, 5 (100 m max.)
EIA/TIA-586 100-ohm STP (100 m max.)
- 100BASE-TX, 1000BASE-T:
UTP Cat. 5, Cat. 5e (100 m max.)
EIA/TIA-568 100-ohm STP (100 m max.)
Full/half Duplex
- Full/half duplex for 10/100Mbps speeds
- Full duplex for Gigabit speed
Media Dependent Interface
Auto MDI/MDIX adjustment for all ports
LED Indicators
- Per port:
Link/Act
1000Mbps speed
100Mbps speed
- Per device:
Power
Transmission Method
Store-and-forward
MAC Address Table
4K entries per device
MAC Address Learning
Automatic update
Packet Filtering/Forwarding Rates (half duplex)
- Ethernet: 14,880 pps per port
- Fast Ethernet: 148,810 pps per port
- Gigabit Ethernet: 1,488,100 pps per port
Çözümler
Sipariş Bilgisi
Copper Gigabit Switch
DGS-1024TL 24 10/100/1000BASE-T ports
