DEM-310GM2
High Performance Multimode Transceiver Up to 2km on Standard Multimode Fiber
Nereden Alınır
Tanımlama
D-Link’s new line of Gigabit Interface Converters (GBICs) and Small Form-Factor Pluggables (SFPs) transceivers represent an industry leading combination of performance and affordability.  D-Link’s new Gigabit transceivers are available in two form-factors: standard (GBIC) or (SFP)/mini-GBIC.
The DEM-310GM2 is a high performance 1310nm multimode GBIC transceiver. Supporting full duplex, Gigabit speeds on multimode fiber for distances of up to 2km on 62.5µm or 50µm fiber.  The unit features a metal housing to reduce EMI and to increase durability.  The DEM-310GM2 is hot pluggable and is backed by a standard 3-year product warranty and free technical support.
Genel Özellikler
Performance
Data Rate Gigabit
1.250Gbps (Bi-Directional)
Data Rate Fiber Channel
1.062Gbps (Bi-Directional)
Optical Receiver Sensitivity
-12dBm (Max)
Transmission Range
- 62.5/125µm:  Up to 2km
- 50.0/125µm:  Up to 2km
Connector Type
SC  Type
IEEE
802.3
Fiziksel Özellikler
Supply Voltage
3.1-3.5V
Max Voltage
6.0V
Max Current
300mA
Dimensions (WxDxH)
1.19x0.47x2.25 in
Safety Certifications and Environmental Information
Class 1 Laser
EN 60825-1
FDA 21
1040.10 & 1040.11
Operating Temperature
0°- 70° C (32° - 158° F)
Storage
-40° - 85° C (-40° - 185° F)
Humidity Operating
10% to 85%
Çözümler
Sipariş Bilgisi
Görseller
DEM-310GM2
Front view
İndir
Destek Merkezi
