Tanımlama
The DGS-3024 is a manageable Layer 2 switch that provides 24 1000BASE-T Gigabit Ethernet ports with 4 Mini-GBIC (SFP) combo ports. Designed for the departmental and enterprise connection, it is an all-gigabit-port switch for gigabit-to-the-desktop connections. Powerful and versatile, it eliminates network bottlenecks while giving users the capability to fine-tune performance. 1U height and standard rack-mount size is especially suitable for departmental environment, providing users the best performance/price ratio. Clear, at-a-glance per-device/per-port LED indicators help users to easily understand and control network status.
High Performance Wire-Speed Architecture The DGS-3024 supports full duplex forwarding, 8k MAC addresses and the ability to classify and mark traffic based on 802.1p into (4) priority queues. The DGS-3024 can be used as a cost-effective Gigabit to the desktop solution or a high performance backbone aggregation device.
Network Management D-Link's DGS-3024 addresses today's diverse business and IT requirements through its robust support of standards based network management protocols (SNMP/RMON/BOOTP/Telnet/Web) and port mirroring. By supporting standards-based network management protocols, the DGS-3024 can be easily integrated with most third-party network management products.
Advanced Enterprise Features The DGS-3024 brings advanced Enterprise functions to a new level of affordability without compromising advanced features including: QoS, Multicast, VLANs, Port Trunking, Port Mirroring, Spanning Tree, Security, and Network Management. These features facilitate the deployment of applications across an Enterprise, including: VOIP, streaming media, and multicast content delivery (IP video, software deployment?tc). The DGS-3024 provides advanced security features such as 802.1x port based access control, and support for RADIUS and TACACS+* servers.
Investment Protection With support for up to (4) SFP modules, the DGS-3024 can easily adapt to changes in customer media requirements without the need to perform an expensive ?orklift?upgrade. By supporting SFP/mini GBIC modules, customers can migrate to more advanced solutions in the future, while still protecting a portion of their original investment.
Genel Özellikler
Interface
- 24 10/100/1000BASE-T Ports
- 4 Combo SFP Slots
- 802.3 NWay Auto-Negotiation (Per RJ-45 Port)
- 802.3x Flow Control (Per Port)
- RS-232 Console Port
Performance
Switch Fabric
48Gbps
64-Byte System Packet Forwarding Rate
35.7mpps
MAC Address Table
8K
Packet Buffer Size
512KB
Max. Jumbo Frame Size
9,216 Bytes
Diagnostic LED
- 1000Mbps Speed, Link/Activity (Per RJ-45 Port)
- Link/Activity (Per SFP Slot)
- Power, Console, RPS (P er Device)
Software Functions
VLAN
- IEEE 802.1Q Tagged VLAN
- GVRP
- Max. number of VLANs: total 255 VLANs
QoS (Quality of Service)
- 802.1p Priority Queues
- CoS based on switch port
- Max. No. of queues per port: 4 for DGS-3024, 8 for
- DGS-3048
Security
- 802.1X port-based access control
- External RADIUS, TACACS+ server support
- Broadcast storm control: per port granularity 10 packets per second for DGS-3024, 1 Kbits per second for DGS-3048
- SSL
- SSH
Bandwidth Control 1
Per port granularity 64 Kbits per second
IGMP Snooping
- Max. No. of multicast groups: 64 for DGS-3024, 1K for DGS-3048
- Multicast traffic modes: flooding, filtering
Port Mirroring
- One-to-one
- Many-to-one 2
Spanning Tree2
- 802.1D Spanning Tree
- 802.1w Rapid Spanning Tree
- 802.1s Multiple Spanning Tree
Port Trunk
- Standard: 802.3ad Link Aggregation 3
- Max. No. of trunk groups: 4 for DGS-3024, 8 for DGS-3048
- Max. No. of ports per trunk: 8
- Operation mode: load sharing
Management Support
- SNMP v.1, v .2c, v.3
- Web-based management
- CLI (command line interface)
- RMON monitoring
- SNTP
- SYSLOG
- Web GUI traffic monitoring
- DHCP/Bootp client 2
- SNMP trap on MAC notification3
- Telnet server
MIB
- RFC 1213 MIB-II
- RFC 1493 Bridge MIB
- RFC 1907 SNMP v.2 MIB
- RFC 2819 RMON MIB (previous 1757)
- RFC 2665 Ether-like MIB (previous 1643, 2358) 3
- RFC 2674 802.1p MIB
- RFC 2233 IF MIB*
- RFC 2618 RADIUS Authentication Client MIB
- RFC 2620 RADIUS Accounting Client MIB
- Private MIB
RMON Groups
1, 2, 3, 9 (Alarm, Statistics, History, Event)
Firmware Upgrade
TFTP
1 Bandwidth control function available on 48-port DGS-3048 switch only. Bandwidth control for 24-port DGS-3024 switch available in future firmware upgrade.
2 For DGS-3048 only.
3 Function available in future firmware upgrade.
Çözümler
Sipariş Bilgisi
Managed Gigabit Layer 2 Switch
DGS-3024 24 10/100/1000BASE-T ports, 4 combo SFP, redundant power support
Optional SFP Transceivers
DEM-310GT SFP transceiver for 1000BASE-LX, single-mode fiber, max. distance 10 km, 3.3V
DEM-311GT SFP transceiver for 1000BASE-SX, multi-mode fiber, max. distance 550 m, 3.3V
DEM-312GT2 SFP transceiver for 1000BASE-SX, multi- mode fiber, max. distance 2 km, 3.3V
DEM-314GT SFP transceiver for 1000BASE-LHX, single- mode fiber, max. distance 50 km, 3.3V
DEM-315GT SFP transceiver for 1000BASE-LX, single-mode fiber, max. distance 80 km, 3.3V
DEM-330T SFP transceiver for 1000BASE-LX, single-mode fiber, max. 10 km, 3.3V, WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-330R SFP transceiver for 1000BASE-LX, single-mode fiber, max. 10 km, 3.3V, WDM (Tx: 1310 nm, Rx:1550 nm)
DEM-331T SFP transceiver for 1000BASE-LX, single-mode fiber, max. 40 km, 3.3V, WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-331R SFP transceiver for 1000BASE-LX, single-mode fiber, max. 40 km, 3.3V, WDM (Tx: 1310 nm, Rx:1550 nm)
Optional Redundant Power Supply
DPS-300 90-watt redundant power supply
DPS-500 140-watt redundant power supply
Management Software
DS-510 D-View 5.1 SNMP Network Management
Optional Management Software
DS-510S D-View 5.1 SNMP Network Program (standard version)
DS-510P D-View 5.1 SNMP Network Management
