Hızlı Arama
Ürün Özellikleri:
Managed 24-Port Gigabit L2 Switch, 4 Combo SFP, 3 10-Gig Slots
Proje
Tanımlama:
The xStack DGS-3400 series of next generation switches delivers performance, flexibility, security, multi-layer Quality of Service (QoS) and redundant power option for the SMB and enterprises. With high Gigabit port densities for desktop connections, SFP fiber connectivity, 10-Gigabit uplink options and enhanced Layer 2+ functions, these switches comprise the workgroup access-layer stack for seamless integration with L3 core switches to form part of a multi-level network structured with high-speed backbone and centralized servers.
Unparalleled Flexibility. Any switch in the DGS-3400 series can operate as a stand-alone device or part of a scalable stack. Embedded with Single IP Management capability, a stand-alone switch can form part of a virtual stack, where intra-stack traffic flows through the usual network wires, doing away with the costly stacking cables. Without stacking cables, cable distance barriers and physical stacking limitations, a virtual stack can comprise units that are located anywhere on the network that minimizes the impact of any single point of failure.
Redundant Ring Stacking.
Alternatively , optional 10-Gigabit modules can be installed in the open slots to create a physical stack. Up to 12 units or 576 Gigabit ports can be configured 1 for a stack. Users can install one or two single-port modules, depending on whether the linear or fault-tolerant Ring stacking is implemented. With each of these ports providing 20Gbps full duplex transmission on the cost-effective coaxial cable, the DGS-3400 series provides not only high-bandwidth stacking but also cost control capability that allows users to add ports strictly on a per need basis. Modules with single 10-Gigabit XFP can also be installed in any of the open slots for uplink to servers or a fiber backbone.
More Intelligent Than Simple Layer 2 Switches. The DGS-3400 series provides a complete set of security features, which includes L2/L3/L4 multi-layer Access Control Lists and 802.1x user authentication via TACACS+ and RADIUS servers. In addition, it offers suppression capabilities and Layer 3 IP v.4/v .6 Static Routing to increase network performance and security. Built-in D-Link ZoneDefense technology allows business to integrate the switch stack with D-Link NetDefend firewalls to implement a full coverage, proactive security architecture.
Security, Performance & Availability. The DGS-3400 series provides extensive VLAN support including GARP/GVRP and 802.1Q VLAN to enhance security and performance. To support converged applications including VoIP , ERP, Intranet and video conference, a robust set of L2/L3/L4 QoS/CoS features ensures that critical network services are served with proper priority. For prevent malicious flooding traffic caused by worm/virus infections, the DGS-3400 series provides D-Link Safeguard Engine to increase the switch's reliability, serviceability and availability. Bandwidth Control can be flexibly set for each port using pre-defined thresholds to assure a committed level of service for end users. For advanced applications, per-flow bandwidth control allows easy fine-tuning of service types based on specific IP addresses or protocols.
Ürünler | Destek  | Haberler  | Hakkında |
