Hızlı Arama
Ürün Değişikliği:
Ürün Özellikleri:
Unmanaged Standalone Switch (wiht build in security of ports)
EOL
Tanımlama:
The 7-Port 10/100BASE-TX + 1-Port 100BASE-FX Fast Ethernet switch is a high performance switch with a low cost/high performance ratio and easy migration to bandwidth-critical environment. It supports auto-negotiation between 10Mbps Ethernet and 100Mbps Fast Ethernet at full or half-duplex operation on copper ports.
This switch used high-performance switch controller, which consists one Fast Ethernet fiber transceivers to extend the connecting capacity. Low price and desktop sized of switch is suitable for small-sized workgroup environment, which help users easily migrate from traditional shared LANs to switched networks. Each full/half duplex port can be connected directly to powerful user such as workstation or other switch and hub to guarantee high-bandwidth and high-flexibility demands.
Ürün Değişikliği
Ürünler | Destek  | Haberler  | Hakkında |
