Hızlı Arama
Ürün Özellikleri:
Managed 48-Port Gigabit Stackable Layer 2 Switch + 4 combo SFP + 20 Gig Stacking
EOL
Genel Özellikler:
Interface
- 48 10/100/1000BASE-T Ports
- 4 Combo SFP
- RS-232 Console Port
- Optional Redundant Power Supply: DPS-500
Stacking
- 2 HDMI Stacking Ports
- 6 Number of Unit Per Stack (Max)
- Bandwidth/Topology
Up to 10Gbps (Linear Topology)
Up to 20Gbps (Bi-Directional Redundant Ring Topology)
Performance
Switch Capacity
116Gbps
64-Byte Packet Forwarding Rate
86.31Mpps
MAC Address Table Size
8K
Packet Buffer
1.5MB
Jumbo Frame (Max.)
10,240Bytes
Software Functions
L2 Features
- MAC Address Table: 8K
- Flow Control
802.3x Flow Control
HOL Blocking Prevention
- Jumbo Frame up to 10,240 Bytes
- IGMP snooping
IGMP v1/v2 Snooping
Suppor t 256 Groups
IGMP Snooping Fast Leave
- MLD Snooping
MLD v1/v2 Snooping
Suppor t 128 Groups
- Spanning Tree
802.1D STP
802.1w RSTP
802.1s MSTP
- Per port / per device BPDU fi ltering
- Loopback Detection
- 802.3ad Link Aggregation
Max. 32 Groups per device/8 Ports per group
- Port Mirroring
Support One-to-One
Many-to-One
VLAN
- VLAN Group
Max. 256 Static VLAN Groups
Max. 256 Dynamic VLAN Groups
- 802.1Q Tagged VLAN
- GVRP
QoS (Quality of Service)
- 802.1p Class of Service
4 queues
- Queue Handling
Strict
Weighted Round Robin (WRR)
Strict + WRR
- CoS Based on
Switch Port
VLAN ID
802.1p Priority Queues
MAC Address
Ether Type
IPv4 Address
DSCP
Protocol Type
TCP/UDP Por t
- Bandwidth Control
Por t-based (Ingress, min. granularity 3500Kbps; Egress, min. granularity 64Kbps)
Security
- SSH v2
- SSL v3
- Port Security: up to 16 MAC address per port
- Broadcast/Multicast/Unicast Storm Control
- D-Link Safeguard Engine
AAA
- 802.1X
Port-Based Access Control
MAC-Based Access Control
- MAC-Based Access Control (MAC)
- Guest VLAN
- Authentication for Management Access Support RADIUS/TACACS+
Management
- Web-based GUI
- Command Line Inter face (CLI)
- Telnet Server/Client
- TFTP Client
- SNMP v1/v2c/v3
- SNMP Trap
- System Log
- RMON v1
- Suppor t 1,2,3,9 Groups
- BootP/DHCP Client
- DHCP Auto-Configuration
- Dual Image
- Dual Configuration
- CPU Monitoring
- SNTP
MIB/IETF Standard
- RFC1213 MIB-II
- RFC1493 Bridge MIB
- RFC1907 SNMPv2 MIB
- RFC1757, 2819 RMON MIB
- RFC1643,2358,2665 Ether-like MIB
- RFC2674 802.1p MIB
- RFC2233, 2863 IF MIB
- RFC2618 RADIUS Authentication Client MIB
- RFC2925 Ping & Traceroute MIB
- D-Link Private MIB
- RFC768 UDP
- RFC783 TFTP
- RFC791 IP
- vRFC792 ICMP
- RFC793 TCP
- RFC826 ARP
- RFC854 Telnet
- RFC951, 1542 BootP
- RFC2068 HTTP
- RFC2138 RADIUS
- RFC2139,2866 RADIUS Accounting
- RFC1492 TACACS
- RFC1157 SNMPv1
- RFC1901, 1908 SNMPv2c
- RFC2570,2575 SNMPv3
Fiziksel Özellikler
Power Input
100 to 240 VAC, 50 to 60 Hz Internal Universal Power Supply
Power Consumption (Max)
102.63W
Dimensions
440mm x 310mm x 44mm
19-inch Rack Mount Width, 1U Height
Weight
5.50kg
Heat Dissipation
350.19 BTU/hr
MTBF
103,924 hrs
Operating Temperature
0 to 40 C (32 to 104 F)
Operating Humidity
-10 to 70 C (-14 to 158 F)
Storage Humidity
10% to 90% non-condensing
Storage Temperature
5% to 90% non-condensing
EMI/EMC
FCC Class A, ICES-003 Class A, CE, C-Tick, VCCI Class A
Safety
cUL, CB
Ürünler | Destek  | Haberler  | Hakkında |
