DGS-3200-16EOL EOS
Tanımlama
The DGS-3200 series includes the DGS-3200-10 and the DGS-3200-16 Security Gigabit Switches. These switches offer a new generation of intelligence and defense delivered through their high-performance, fexible, and robust security. This switch secures the network from viruses using the ACL, IMPB (IP-MAC-Port Binding) and SafeGuard Engine functions.
The DGS-3200-10 is built with a fan-less technology. The compact, 11-inch switch produces and emits less heat and noise than standard switches.
Mean while, the DGS-3200-16 comes with smart fan feature that has heat sensors and a fan that maintains the temperature of the device for optimum performance. To minimize noise reduction, the fan is switches off by default.
The DGS-3200-10 and DGS-3200-16, compared to any other model, are ideal for an offce environment or circumstances that require silence.
Comprehensive Security
The DGS-3200 series offers a complete list of endpoint security features to add confdence and assurance towards your network. It executes from network security and comes with user-based identity control by implementing host-based 802.1x authentication/authorization, along with clientless Web-based Access Control (WAC) and MAC-based Access Control (MAC) for easy deployment. The incorporation of sophisticated ACL user-defned* functionality secures the internal IT network against viruses and worms from invading the LAN to provide better security. Innovative IP-MAC-Port Binding prevents ARP spoofng and man-in-middle attacks by disabling users from manually confguring their own IP or MAC address, and allowing administrators to assure that the IP information on the syslog server or frewall log is correct. Other security features like port security
and traffc segmentation provide granular control to business environments, allowing administrators to enhance network security. D-Link’s joint security provides admission control and real-time defense through Microsoft’s NAP (Network Access Protection) and D-Link’s ZoneDefense*
respectively. D-Link’s built-in ZoneDefense technology allows businesses to integrate their switch with D-Link’s NetDefend frewall to implement full coverage and a proactive security architecture.
IPv6 Technology
D-Link’s DGS-3200 series embraces Microsoft Network Access Protection (NAP) which supports both IPv4 and IPv6 protocol versions. NAP is a policy
enforcement technology built into the Windows Vista® operating system that allows customers to better protect network assets from unhealthy computers by enforcing compliance with network health policies. The IPv6 multicast host, the latest in protocol technology, enables maximum hardware performance. Features such as MLD snooping enhance effciency in selective distribution by forwarding multicast data to ports that receive data, rather than fooding all ports in a VLAN. Features such as ACL based on IPv6 fow label and traffc class, as well as QoS-based on IPv6 help provide faster and an effcient service. Under IPv6 Management, we support Web, telnet and SNMP over IPv6.
Resilience/Performance Enhancement
To enhance network resilience, the DGS-3200 series provides Spanning Tree protocols including 802.1D, 802.1w, and 802.1s for redundant bridge paths. 802.3ad Link Aggregation provides aggregated bandwidth between switches or servers to increase redundancy for higher availability. Quality of Service (QoS) incorporates multilayer function that supports 8 queues including 802.1p priority and packet classifcation based on TOS, DSCP, MAC, IP, VLAN ID and L4 TCP/UDP ports enabling Internet voice, video and streaming media applications to run smoothly. The DGS-3200 series also provides a Safeguard Engine for network protection to increase switch’s reliability, serviceability and availability.
Traffc Control
Network administrators can defne throughput levels for each port to allocate its essential bandwidth. Broadcast storm control and fow-based bandwidth control can reduce the level of damage from virus attacks or P2P applications to the network.
Single IP Management
The DGS-3200 series simplifes and speeds up your management tasks as multiple switches can be confgured, monitored and maintained from any
workstation running a web browser through one unique IP address. This virtual stack is managed as a single object, having all units maintained by one IP address.
Manageability
The DGS-3200 series supports standard-based management protocols such as SNMP, RMON, Telnet, Console, web GUI and SSH/SSL security authentication.
Genel Özellikler
Device Interfaces
+ 14 10/100/1000BASE-T Gigabit Ports
+ 2 Combo 10/100/1000BASE-T/SFP Ports
+ RS-232 DB-9 Console Port
Performance
+ MAC Address Table: 8K
+ Switch Capacity: 32Gbps
+ Maximum Packet Forwarding Rate: 23.81Mpps
+ Switching Method: Store and Forward
+ Packet Buffer Memory Size: 128Kbytes
Flow Control
+ 802.3x Standard in Full Duplex Mode
+ Back Pressure in Half Duplex Mode
EMI
+ FCC, CE, VCCI Class A, C-Tick
Safety
+ UL, CB Report
SOFTWARE FUNCTIONS
Stackability
+ Virtual Stacking
Support D-Link Single IP Management
Up to 32 devices per virtual stack
L2 Features
+ Flow Control
802.3x Flow Control
HOL Blocking Prevention
+ Jumbo Frame up to 10,240 Bytes
+ IGMP snooping
IGMP v1/v2/v3 Snooping
Support 256 Groups
IGMP Snooping Fast Leave
+ MLD Snooping
MLD v1/v2 Snooping
Support 256 Groups
+ Spanning Tree
802.1D STP
802.1w RSTP
802.1s MSTP
+ Per port / per device BPDU fltering
+ Loopback Detection
+ 802.3ad Link Aggregation
Max. 5 Groups per device/8 Ports per group
+ Port Mirroring
Support One-to-One
Many-to-One
Flow-based Mirroring
VLAN
+ VLAN Group
Max. 4K Static VLAN Groups
Max. 255 Dynamic VLAN Groups
+ 802.1Q Tagged VLAN
+ GVRP
+ 802.1v Protocol VLAN
QoS (Quality of Service)
+ 802.1p Class of Service
+ 8 queues
+ Queue Handling
Strict
Weighted Round Robin (WRR)
+ CoS based on
Switch Port
VLAN ID
802.1p Priority Queues
MAC Address
IPv4/IPv6 Address
DSCP
TCP/UDP Port
Protocol Type
IPv6 Traffc Class
IPv6 Flow Label
User-Defned Packet Content
+ Bandwidth Control
Port-based (Ingress/Egress, min. granularity 512Kb/s)
Flow-based (Ingress, min. granularity 64Kb/s)
ACL (Access Control List)
+ Up to 200 access rules
+ ACL Based on
802.1p Priority
VLAN ID
MAC Address
IPv4/IPv6 Address
DSCP
Protocol Type
TCP/UDP Port Number
IPv6 Traffc Class
IPv6 Flow Label
User Defned Packet Content
+ Time-based ACL
+ CPU Interface Filtering
Security
+ SSH v2
+ SSL v1/v2/v3
+ Port Security: up to 16 MAC address per port
+ Broadcast/Multicast/Unicast Storm Control
+ Traffc Segmentation
+ IP-MAC-Port Binding
Support 128 address binding entries per device
Support ARP / ACL Mode
+ D-Link Safeguard Engine
+ Microsoft
® NAP (Supports IPv4/IPv6)
AAA
+ 802.1X
Port-Based Access Control
Host-Based Access Control
Dynamic VLAN Assignment
+ Web-Based Access Control (WAC)
+ MAC-Based Access Control (MAC)
+ Guest VLAN
+ Authentication for Management Access Support RADIUS/TACACS+
+ RADIUS Accounting
Management
+ Web-based GUI (Supports IPv4/IPv6)
+ Command Line Interface (CLI)
+ Telnet Server/Client (Supports IPv4/IPv6)
+ TFTP Client (Supports IPv4/IPv6)
+ ZModem
+ SNMP v1/v2c/v3
SNMP over IPv6
+ SNMP Trap
+ System Log
+ RMON v1
Support 1,2,3,9 Groups
+ RMON v2
+ Support ProbeConfg Group
+ BootP/DHCP Client
+ DHCP Auto-Confguration
+ DHCP Relay
+ DHCP Relay Option 82
+ Dual Image
+ Dual Confguration
+ CPU Monitoring
+ SNTP
+ ICMPv6
+ IPv6 Neighbor Discovery
MIB/IETF® Standard
+ RFC1213 MIB-II
+ RFC1493 Bridge MIB
+ RFC1907 SNMPv2 MIB
+ RFC1757, 2819 RMON MIB
+ RFC2021,RMONv2 MIB
+ RFC1643,2358,2665 Ether-like MIB
+ RFC2674 802.1p MIB
+ RFC2233, 2863 IF MIB
+ RFC2618 RADIUS Authentication Client MIB
+ RFC2925 Ping & Traceroute MIB
+ D-Link Private MIB
+ RFC768 UDP
+ RFC783 TFTP
+ RFC791 IP
+ RFC792 ICMP
+ RFC793 TCP
+ RFC826 ARP
+ RFC854 Telnet
+ RFC951, 1542 BootP
+ RFC2068 HTTP
+ RFC2138 RADIUS
+ RFC2139,2866 RADIUS Accounting
+ RFC2620, RADIUS Accounting Client MIB
+ RFC1492 TACACS
+ RFC1157 SNMPv1
+ RFC1901, 1908 SNMPv2c
+ RFC2570,2575 SNMPv3
Çözümler
Sipariş Bilgisi
DGS-3200-16 14 Ethernet 10/100/1000 Ports + 2 combo 10/100/1000Base-T/SFP ports L2 Managed Switch
